| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
wide/square 235 or normal 245/255 look nice on a 9"....
#16 | |
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#17 |
Drives: '13 BRZ in WRB--let's mod!!!
Uh... My wide wheels (9" w/ 245s), are all abt performance. A beefier look is a side benefit. My .02...
#18 |
if youre running 225s you can even save weight and rock a 7.5...
| The Following User Says Thank You to gmookher For This Useful Post: | LSxJunkie (01-17-2013) |
#19 | |
Hot Dog
Drives: quicker than arghx7
Some OEM examples: Miata & MINI use a 205 on a 7" wheel New C7 Covette uses a 245 front on a 8.5" wheel Lotus Exige uses a 195 front on 6.5", 225 rear on 7.5" VW Golf TDI uses 225 on 7" wide wheel Evo IX uses a 235 tire on 8" wheel Subaru STI 18"s are a 245 tire on a 8.5" wheel [same as Corvette front] You can see there is a range, but a general trend. The 86's 215 tire on 7" wheel isn't abnormal, it's average. Of course, if you want some stretch to look good, you'll do it. A certain amount of stretch will improve steering response, but too much affects the contact patch beyond the scope of the tire design. It goes the other way too; too wide a tire on a narrow wheel looks balloonish and negatively impacts contact patch performance. Cheers, Ryan
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#20 |
#21 |
#22 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Lies. I think you understand the words "Stock car" as well as NASCAR car builders do.
| The Following User Says Thank You to Kido1986 For This Useful Post: | CSG Mike (01-15-2013) |
#23 |
Drives: 2013 genesis rspec
after seeing that 18x9.5 pokes on everybody car, i changed my mind and getting 17x9, its just a more practical looking and flush, rpf1 17x9 + 35, something like that
#24 |
Drives: Skoda Yeti DSG diesel 4x4
265/40-17 would be a perfect fit on those and only 2.9% or 18mm larger dia which is nothing and will make your speedo just about spot on. Just a bit over still.
#25 |
#26 |
A Very Annoying Person
Drives: Subaru Impreza :( Hopefully BRZ
I'm really liking the looks of the EV5 and SR6 Enkei's on TireRack.
![]() ![]() Sadly, I'm not too good with wheels, so I'm fairly lost here. |
#27 |
Drives: 2013BRZ Premium St Silver Metallic
#28 |
Just because wider wheels are available and with a specific bolt pattern, does not mean they were all designed for the BRZ.
| Aftermarket wheels in Calgary | Davetherave | CANADA | 4 | 12-03-2012 10:30 PM |
| For those guys with wide wheels | jkonquer | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 11-02-2012 02:18 PM |
| Light, wide wheels with good fitment | coyote | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 02-10-2012 04:27 PM |
| Aftermarket wheels? | Levi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-06-2011 07:19 AM |
