go_a_way1
Old 01-17-2013, 06:18 PM   #323
CSG Mike
CSG Mike's Avatar
u mean a 08 GPWCR? IIRC, all the 09GPWCRs are either totalled or exported out of NA....
Old 01-17-2013, 06:30 PM   #324
Canyoncarver
Drives: MY04 S2000 (LEXY)
That's not what they dyno at (as in a chassis dyno).
Chassis dyno? Whats the difference?
Canyoncarver is offline   Reply With Quote
Old 01-17-2013, 06:32 PM   #325
Canyoncarver
Where did u get this info?
Cr hardly has any performance differences its more cosmetic.. (hardtop.front cr lip
Old 01-17-2013, 06:42 PM   #326
Canyoncarver
Does not compute... unless he has a F20C3... and a 2.5L stroker was put in all 02+
False 00-03 :2.ol 04-09 2.2l
Old 01-17-2013, 06:43 PM   #327
Canyoncarver
Originally Posted by MattZ28 View Post
Excellent post. I've decided I'm going to get rid of my S2K within the next few months for a BRZ Limited. It will be far more practical to have as a daily driver, and the only reason I'm letting this S2K go is because it has 100,000 miles. Later on, I'll get a lower mileage one to have as a weekend car. I've decided an S2K is something I don't want to live without, but I don't want to have it as my only car...and if it's going to be a garage queen / weekend car, it'd better be a pristine example of one
This is wat ima do tooo:happy0180:
Old 01-17-2013, 06:54 PM   #328
OrbitalEllipses
Drives: Attitude
Did you need to post 4 times in a row? Good god! I barely understood that either. CSG Mike, translate please?
Old 01-17-2013, 06:56 PM   #329
CSG Mike
CSG Mike's Avatar
Too much carving, not enough comprehension... lol
Old 01-17-2013, 07:04 PM   #330
Coaster
Coaster's Avatar
Drives: Civic
How would the s2000 compare to a SuperCharged Miata with sway bars?
Never been in a S2000 but I like that car a lot.
"if Formula One engineers built a sports car. Well, they did, and it's Honda's new S2000."
Coaster is offline   Reply With Quote
The Following User Says Thank You to Coaster For This Useful Post:
WolfpackS2k (01-24-2013)
Old 01-17-2013, 07:16 PM   #331
Khánh
Khánh's Avatar
Drives: sc00ter
Originally Posted by Canyoncarver View Post
I own a gpw 04 s2k ..Im still debating to get an 06+gpw cr or new frs/brz..my s2k is n ot flashpro comp. Becuz its mechanical throttle
i'm pretty sure CR didn't exist until '08 model
the crank (stock rating) 240 is what the engine itself puts out.. i was asking power to the wheel..
Khánh is offline   Reply With Quote
Old 01-17-2013, 09:21 PM   #332
avox
Drives: 2013 Scion FR-S, Raven
Originally Posted by FreshFRS View Post
your car (unless it has a stroker kit which is not stock) is a 2.0L L4 F20C with 240hp and 155lb/ft(IIRC) redlining at 8800, Fact i had one.
I sold mine only for the fact that i was cramped in the seats, i'm well over 6' and put up with it for 4 years. Stock for stock i'd say from my test drive the FRS given great tires and some power (not much) could compete with a bone stock S2K. that being said, to sit comfortably in something that small was a great achievement for toyota.
my bad on the engine size i had the 2.5 boxer on my brain from having a convo with fellow techs at work and yes the redline is 8,800 but dosn't cut out till 9k-9,100 not possitive havent driven the car for almost 5 months due to weather in ohio >.<, been really busy working 55 hours every week and going to school for 20 ontop of that /sigh.
avox is offline   Reply With Quote
Old 01-17-2013, 09:32 PM   #333
CSG Mike
CSG Mike's Avatar
Sure!
Chassis dyno, vs engine dyno
I own a CR
The sarcasm got lost. Canyoncarver also seems to be unaware of the variants of the F20C/F20C.
He's gonna have seller's remorse.
Old 01-17-2013, 09:33 PM   #334
avox
Stock ap1 or 2: 240hp
AP1 99-03: F20C inline 4-cylinder DOHC-VTEC engine producing from 240 hp (179 kW) to 250 hp (184 kW), and from 153 lbf·ft (207 N·m) to 22.2 kg·m (218 N·m) of torque depending on the target market.
AP2 04-09:The AP2 also included the introduction of a larger version of the F20C for the North American market. Designated F22C1, the engine's stroke was lengthened, increasing its displacement to 2,157 cc (132 cu in). At the same time, the redline was reduced from 8,800 rpm to 8,000 rpm with a cutout at 8,200 rpm, mandated by the longer travel of the pistons. Peak torque increased 6% to 162 lbf·ft (220 N·m) at 6,800 rpm while power output was reduced to 237 hp (177 kW) at a lower 7,800 rpm.
after checking the new car sticker on mine it was some how rated at the 250HP range not sure why as it seems most here in the USA were the 240hp....?
Old 01-17-2013, 09:35 PM   #335
CSG Mike
CSG Mike's Avatar
Completely subjective. Who cares about WHP? I only care about my gain vs my own baseline.
I've had my car read as high as 240whp, and as low as 180whp, depending on the dyno
OrbitalEllipses (01-17-2013)
Old 01-17-2013, 10:14 PM   #336
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
My 06 had a 1.4L since they kept getting smaller I guess. It was a F20C-F.6C8. It used an allison transmission out of a dodge truck.
You guys need to learn S2000s.
I loled
goldenfri is offline   Reply With Quote
FR-S vs S2000 vang FR-S / BRZ vs.... 436 09-19-2012 04:52 PM
E36 M3 vs FR-S vs S2000 (for me) RearDrive FR-S / BRZ vs.... 48 07-02-2012 10:46 PM
S2000 or MX-5 balance Other Vehicles & General Automotive Discussions 10 11-01-2011 02:01 AM
S2000 from hell CyberFormula Other Vehicles & General Automotive Discussions 13 07-09-2010 09:05 PM
