Old 12-12-2012, 04:27 PM   #43
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I drove the XP10/XP8 combo on the street for about 5,000 miles. Did you have some other track pads on the same rotors previously? Just trying to figure out any differences.
For the XP10s I used the same rotors I used for the S2000's OEM pads.
For the RP2s I used new rotors.
Same squealing noise, no real difference.
Old 12-12-2012, 05:28 PM   #44
CSG Mike
CSG Mike's Avatar
http://www.s2ki.com/s2000/topic/9544..._fromsearch__1
Old 12-12-2012, 06:52 PM   #45
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
That just means that the pads have been heated up to the proper temp. It doesn't mean that you have a proper transfer layer.
Personally, I've never bought the pre-bedded pads, and I don't recommend it to anyone either; you can bed them in fine at the track, and unlike some other pads, you certainly won't lose a session bedding them in.
Yeah I don't see how you can buy "pre-bedded" pads since bedding pads means heating the pads up enough to transfer a thin layer of material to the rotor and then letting the rotor cool down. That way future braking will have the brake pad materials working together. So essentially both a rotor thing and a brake pad thing.
Aznsky is offline   Reply With Quote
The Following User Says Thank You to Aznsky For This Useful Post:
amram (03-28-2014)
Old 12-13-2012, 08:03 AM   #46
WolfpackS2k
Good to know for the future. However I don't leave my track pads on for daily driving so the noise isn't a big deal for me.
Old 01-02-2013, 02:04 AM   #47
ayau
Drives: Some rust bucket
When replacing OEM pads with track pads, should one resurface the OEM rotors before installing the track pads?
Old 01-02-2013, 02:55 AM   #48
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The most accurate answer is: "it depends"
The long and short of it is... Just slap them on and go. You'll be fine.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
amram (03-28-2014), CSG Mike (01-02-2013)
Old 01-02-2013, 04:18 PM   #49
CSG Mike
CSG Mike's Avatar
Theoretically? Yes.
Unless there's some REALLY funky grooving, we just slap em on and go.
amram (03-28-2014), ayau (01-02-2013)
Old 01-02-2013, 04:39 PM   #50
Hanakuso
Brake Pad Manufacturer (F/R): Hawk/OEM
Caliper (F/R):
Essex AP Racing Sprint Kit(AP Racing CP8350)/OEM
Compound (F/R): HPS/OEM
Tires: 215/45/17 OEM Michelin Primacy
Feedback:
Characteristics seem very close to the OEM pads. Very low dust, great cold initial bite and zero squealing. Have not notice any wheel or paint damage due to dust. These pads will only be used for street use so it will be incomplete for track usa.. The pads do have a little movement but i'm guessing that is more to do with the calipers being designed for track use only. These are basically perfect for the Essex AP Racing kits when you want to run on the streets that won't see any hard usage.
Will update later with extra info on pad lifespan and other info.
Hanakuso is offline   Reply With Quote
Old 01-11-2013, 01:43 AM   #51
zkubidu
Drives: SWP BRZ
Brake Pad Manufacturer (F/R): Porterfield/OEM
Caliper (F/R): OEM/OEM
Rotor Size (F/R - IE OEM or specify): OEM/OEM
Compound (F/R): R4S/OEM
Tires: 245/40-17 RS3
Feedback:
Feels similar to stock brakes but does noticeably dust more. I never took the stock brakes to the track, but running a 1:33 pace at SOW CW in 50F weather this setup held up well(haven't been on a track on 4 wheels in almost 10 years). Never noticed any fade at all, and braking was very consistent and easily modulated. On the street, I get no noise whatsoever and braking is effective even when fully cold. Although SOW CW isn't a brake intensive track IMO, I feel these would be a good alternative to stock pads for those looking for an occasional track day.
Scores:
Dusting (1=high-10=low): 3
Cold bite (1=low-10=high): 5
Hot bite (1=low-10=high): 6
Modulation (1=low-10=high): 6
Noise (1=extremely loud-10=quiet): 10
Pad Lifespan (1=short-10=long): est 10 track days
Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? (Y/N) Not that I know of.
Brake ducts: (Y/N) No.
Note: My ratings are based comparisons from vehicles with CCM setups that never shown fade, JFYI.
zkubidu is offline   Reply With Quote
Old 01-17-2013, 04:30 PM   #52
sw20kosh
Drives: 2013 Black FR-S
Not many talking about the F/R: HP+/HPS combo.
Are Hawks not good?
I will be on RCE yellows and am wondering if I should stagger or just get one pad for all 4 corners.
Old 01-17-2013, 04:40 PM   #53
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Are Hawks not good?
HPS aren't a track pad, HP+ is a lighter duty track pad. Most of us use heavier duty (higher MOT) pads.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-18-2013, 11:58 AM   #54
sw20kosh
So in your opinion is there any benefit to going with HP+ over the other heavier duty pads.
I want a pad that I can drive around on daily (noise and dust are an issue), that wont disintegrate at the track like the stockers.
Old 01-18-2013, 12:30 PM   #55
CSG Mike
CSG Mike's Avatar
Any good pad will dust pretty heavily. Noise is dependent on the pad. The higher the MOT, the more likely it is that you'll have noise.
Properly bedding *most* pads will reduce the noise to a minimum.
Old 01-21-2013, 10:15 AM   #56
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Brake Pad Manufacturer (F/R): Stop Tech
Caliper (F/R): FACTORY FRONT AND REAR
Compound (F/R): Street Performance Pad front and rear
Tires: Michelin 245/35/18 on weds
Feedback:
I installed these pads along with some Motul 600 for my first track day. I noticed that pads worked much better than stock right off the bat. After three track days and 7500 miles the pads are done on the front. The rear how ever still look very good with at least 75% life left For the price you can beat it.
I currently have a stillen big brake upgrade coming. I would like to point out that I notice a small crack appear on my rotor thats why I order the BBK. Other than that these brake felt great and never faded once. The Brake fluid has now changed colors(brown) too so I have a feeling it's been heated pretty high.
Scores:
Dusting (1=low-10=high): 7
Cold bite (1=low-10=high): 7
Hot bite (1=low-10=high): 7
Modulation (1=low-10=high): 7
Noise (1=quiet-10=extremely loud): 1
Pad Lifespan (1=short-10=long): (estimate/actual)front 4, rear 6
jdzumwalt is offline   Reply With Quote
The Following User Says Thank You to jdzumwalt For This Useful Post:
amram (03-28-2014)
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2698 02-14-2024 11:55 PM
Gundam Universe - General All Discussion Thread poormans_LFA Off-Topic Lounge [WARNING: NO POLITICS] 273 03-23-2014 11:45 PM
S2000 vs BRZ at the track: track oriented discussion CSG Mike Tracking / Autocross / HPDE / Drifting 33 01-13-2013 06:54 PM
Track/Racing Discussion Allch Chcar Tracking / Autocross / HPDE / Drifting 9 05-26-2012 04:39 PM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
