Old 01-16-2013, 01:25 PM   #1541
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Originally Posted by johatan25 View Post
This decision is getting a little harder to make. While I am wanting to lower my car for looks, I want to keep in mind that I don't want to compromise its performance, but improve it, even if its slightly. (Basically looks + a little performance improv, I'm sold). I know little about vehicle modifications, so I rely mostly on other people's experience. @Ricepuddin, I am still solid on the springs. But if I can get even more details, I'd really appreciate. I would like to add, I am running 235/35/18 Falkens on all 4 wheels. I appreciate all the insight and advice from all of you!
As I said before, no pressure.
The drop is mild so you won't be riding on the bump stops like you will with some of the more aggressive springs. You also won't have to cut your bumps as the RCE's come with new ones.
The spring rates are 250 lbs/in front and rear, so the car should retain the stock balance of you're BRZ but you (should) notice less body roll and dive.
My question to you would be have you noticed any yaw after switching tire?.
Also, RCE claims the ride is a little smoother with these on the car but grain of salt. I can tell you on the WRX this is 100% true, but the WRX was a terrible suspension.
This plus Konis or Billisteins (if RCE releases them) should make a less expensive coilover alternative that will actually be better than cheap coil overs in the the long run.
Mind you I haven't run these on the car so I'd advice PMing some folks who have (http://www.ft86club.com/forums/showthread.php?t=16102) and asking them what they think long term.
Also @aaronosaurus has brought up a lot of good points, so please don't dismiss it because of my last post.
Last thing, if you decide you want to spend this money on go-fast bits instead of springs ATM, I would say a tune is where it's at.
Ricepuddin is offline   Reply With Quote
Old 01-16-2013, 01:38 PM   #1542
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
This is a good debate going on suspension. I have to agree most people jump into suspension mods without knowing what the effects will be. To appreciate each mod one should wait to get to know the car, then mod based on what you feel needs attention, based on the experience you now have gained driving your car often enough and to its limits. There is also lots of reviews on setups, to each their own (some like a little comfort, others more track like without any comfort). I have the buddy club racing coilovers cause I wanted to lower it (due to body roll), chamber adjustment and overall rebound of the shocks. Remember too low can negitively effect a car and cause it to handle terribly. Yes, I have done track days with this car. Make sure you do your research. For anyone doing springs, I implore you to get front chamber plates, front crash bolts and rear chamber kit. This will allow you to fix the alignment issues, since stock has no adjustability. Sadly the engineers did not do the greatest job on the overall alignment, if you dont believe take your car stock to have the aignment checked each wheel is different (some by over .8 deg of chamber, toe is different too).
- Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
Old 01-16-2013, 04:07 PM   #1543
mx5 2nr
Drives: FRS/NA1/'12 Mustang/'97 4Runner
Originally Posted by FrsRN View Post
Where should i go and how much to get opti coated
Man, you guys are going to make me want to join the "opti coat club"! In all honesty, I hadn't heard about it until hearing all you guys talking about it & seeing Got3n's car in person - it's amazing! Got3n & Ocho-Seis, could we handle another Opti-Coated Raven?
BTW - agree with Boosted, good discussion on suspension. I encourage those that are new to the car to wait & "feel" the suspension before throwing parts at it. I have many friends that have "ruined" their cars by installing new springs/coilovers/whatever without really understanding what they are doing. I also echo Boosted's comments on encouraging those that are updating their suspension to get camber plates/crash bolts/etc to be able to adjust alignment settings.
'90 Miata - weekends
'13 FRS - weekdays
'97 4-Runner - grunt work
'12 Mustang - wife's
mx5 2nr is offline   Reply With Quote
Old 01-16-2013, 05:02 PM   #1544
dpgdave
Mark me down as another happy customer of Jays. I had my whiteout done last week and Jay did a great job. He's also a real good guy and knows his stuff.
Here's before and after shots to check out if you're seriously considering getting your car opti coated.
dpgdave is offline   Reply With Quote
Old 01-16-2013, 06:27 PM   #1545
mRdeMs83
mRdeMs83's Avatar
Drives: Argento FR-S 86
My ride needs this. Maybe next weekend.
Argento ate6
mRdeMs83 is offline   Reply With Quote
Old 01-16-2013, 06:51 PM   #1546
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
omg stupid wheels have a weird bore and now I can't find a ring for it...need a 63mm->56mm.....jahshfjfksbdh
Got3n is offline   Reply With Quote
Old 01-16-2013, 07:26 PM   #1547
Dynotronics1
Don't worry about it, we never run the center rings on the aftermarket wheels, even on the race cars
Dynotronics1 is offline   Reply With Quote
Old 01-16-2013, 07:51 PM   #1548
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
I just dont want to get any vibration, Maybe Ill get the tires mounted then bring them to you to install ^_^
Old 01-16-2013, 08:46 PM   #1549
johatan25
johatan25's Avatar
Drives: Lightning Red BRZ - Premium 6MT
So... Anybody switched their overhead/front pipe? I'm wanting to add bolt ones before getting a tune. @ft86speedfactory has given me a quote for an Invidia catless frot pipe and Perrin overhead pipe for a great price, but I wanted to run it through my fellow brz/frs owners for opinions! I doubt I'll switch my intake, but I may switch the filter with a drop in. @Dynotronics1 any gains on bolt on + tune that to can speak of?
Mods done (RED), Mods to come(BLACK): LED Swap, GReddy SP Elite Exhaust, Leather Seats, TSW 18x8.5 + 235/35, MOTIV Over & Catless Test pipe, EcuTek 93 Octane tune, PERRIN Lightweight Pulley, PERRIN Intake Inlet + drop-in filter,, e85 fuel map, 5axis Spoiler?, Borla UEL Headers?
johatan25 is offline   Reply With Quote
Old 01-16-2013, 09:05 PM   #1550
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
Personally I'd suggest the Motive OP and FP combo, great price and looks fastastic. I got my tune already but not the pipes, once i get the pipes he can retune it for you. Im waiting till he gets his headers then ill do all 3 at once, as well as the drop in filter. Less work for him in the long run.
Old 01-16-2013, 09:36 PM   #1551
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Motiv or Nameless, I love my nameless setup but the wait time kinda sucks.
I wasted money on an intake, I'd advise against it (from my experience, at least stay away from airaid).
Old 01-16-2013, 09:37 PM   #1552
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Just in from JDMland
The Following User Says Thank You to Ricepuddin For This Useful Post:
Got3n (01-16-2013)
Old 01-16-2013, 10:52 PM   #1553
johatan25
johatan25's Avatar
Did you get any rasp on that set up?
Old 01-16-2013, 11:16 PM   #1554
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
I don't find it raspy at all.
[ame="http://www.youtube.com/watch?v=oO788ob70QA"]Nameless performance downpipe and axle back - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=tJ3Mzfywjs8"]20121022_184938.mp4 - YouTube[/ame]
I travel 130 almost every weekend and I hear more noise from my tires than my exhaust, it's also catted so it's not as bad as it could be.
If you come out to the one of the meets I'd be more than happy to take you for a ride so you can hear it in cabin, and I am sure someone with a different setup would be willing to do the same.
Official What are you listening to thread? TRDMAN Off-Topic Lounge [WARNING: NO POLITICS] 2321 12-24-2024 10:16 PM
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
The official hand drawn thread. LexusFman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 04-06-2013 05:11 AM
Official 2011 WRC Season Thread 4agze Other Vehicles & General Automotive Discussions 4 04-01-2011 04:13 PM
