Old 01-01-2013, 12:48 AM   #253
ohbebe80
That's unpossible!
ohbebe80's Avatar
Drives: 2013 Scion FR-S, 6 MT, Asphalt
Originally Posted by Khánh View Post
what paint did u guys use?
Personally, I like to use Krylon Fusion Paint. It's practically made for an application like this. No primer, no sanding. Designed to fuse to finished plastic surfaces. I've used it on headlights in the past with the same success. It masks off well too, if you're thinking of leaving chrome accents.
ohbebe80 is offline   Reply With Quote
Old 01-01-2013, 03:08 AM   #254
Mo707
Mo707's Avatar
Anyone with a whiteout paint theres white?
Mo707 is offline   Reply With Quote
Old 01-08-2013, 02:15 PM   #255
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
Originally Posted by TotsGT86 View Post
Thank you again Darren Driven LOL.
Yeah, you're just too lazy to go one page backwards...
Jared0934 is offline   Reply With Quote
Old 01-14-2013, 05:53 PM   #256
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
what LED's did you use? looks spectacular mate
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 01-14-2013, 06:18 PM   #257
Mo707
Mo707's Avatar
+1
Old 01-14-2013, 07:44 PM   #258
Khánh
Khánh's Avatar
Drives: sc00ter
Originally Posted by ohbebe80 View Post
I went with the full RetrofitSource Morimoto Kit. So, after installing the new projector, I had the old one laying around. I chopped it up with a dremel. I cut off the three legs, and a bit of one side to fit it into the DRL housing space. Then I made three bracket legs using metal hanger straps. I painted the black plastic housing chrome. I used screws and nuts to bolt the new projector into place (tied floss to the end of the screws so that I could pull them through the holes I drilled in the DRL housing). Here are some pics, this was while I was mocking it up before I painted it chrome.
Hope that helps. I love trying to do something unique. But it can be effing freaky to mess with a brand new car!
from my understanding, it loooks like you use the front half of the projector only and not the base.. and use the stock reflectors to beam out the the new projector lense, am I right?
Khánh is offline   Reply With Quote
Old 01-14-2013, 07:54 PM   #259
Cody
Cody's Avatar
Drives: White Fr-S
You dont have to remove the side markers.
If you use a flat object ( i used the handle of a screwdriver) and put it on the top of the push pin you can undo the pin without removing the reflector.
Doing it this way i didn brake anything and it reinstalled easily.
Cody is offline   Reply With Quote
Old 01-14-2013, 08:53 PM   #260
TotsGT86
TotsGT86's Avatar
Drives: Toyota
They are, EURO LITE LEDs!
TotsGT86 is offline   Reply With Quote
Old 01-18-2013, 04:00 PM   #261
ohbebe80
That's unpossible!
ohbebe80's Avatar
Correct. The stock reflector under the projector is still silver. But the rest is blacked out. They aren't as bright anymore, but they're just DRLs anyways. They still turn on with the high beams, but the bi-zenons are so good that they are unnecessary.
Old 01-23-2013, 12:44 AM   #262
ettorres15
Jedi Member
ettorres15's Avatar
Drives: Scion Fr-s White out
Where did you get those led's ?
Nice job man. I just got my Fr-s and this is the first mod i wish to do. I've been shopping around for LED's like yours but i havent found nice looking ones. Where did you get yours?
Thanks
ettorres15 is offline   Reply With Quote
Old 01-25-2013, 01:54 AM   #263
Yruyur
Yruyur's Avatar
In the middle of installing my leds now. Paint is going on as well. Body shop already had the bumper off so I had them give me the headlights.
The Following User Says Thank You to Yruyur For This Useful Post:
SkAsphalt (03-05-2013)
Old 01-25-2013, 02:40 AM   #264
Mo707
Mo707's Avatar
What are you using for that??
Old 01-25-2013, 10:23 AM   #265
Yruyur
Yruyur's Avatar
How did you wire them in, switch, highbeam, lowbeam? Thinking of having the dealer disable the drl and running these as them instead.
Old 01-25-2013, 10:26 AM   #266
Yruyur
Yruyur's Avatar
Ill take a pic of them when I get home. Jist got them from an auto shop around here.
HID Headlight Upgrade KIT - 1st MOD completed SpecPer Exterior Parts - The Rest 76 08-03-2012 10:13 AM
Is Anyone Else Tired of SOA Information Blackout geb2391 BRZ First-Gen (2012+) — General Topics 23 04-21-2012 09:37 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 02:24 AM
TRS headlight mod RRnold Other Vehicles & General Automotive Discussions 0 12-24-2011 04:20 PM
