#29 | |
Reverse Burnouts
Drives: 2013 Argento FRS
im going to assume its using a TRD supercharger and crazy slicks to bring that down 6 seconds off the hks , seems legit...
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
| The Following User Says Thank You to carbonBLUE For This Useful Post: | LeeMaster (01-12-2013) |
#30 |
Drives: BMW E84
My goodness... I want that underbody aero...
#31 |
Drives: FRS Silver LS1 swapped.
Somebody is dreaming!
#32 |
Drives: Starlet
#33 |
OK I'm impressed. Consider:
1:01.87 -- Griffon 86 -- 2276 lbs / 200 hp = 11.38 lbs/hp 1:03.54 -- KTM X-Bow -- 1916 lbs / 241 hp = 7.95 lbs/hp 1:04.24 -- Lotus 2-Eleven -- 1707 lbs / 256 hp = 6.67 lbs/hp 1:05.88 -- Lotus Exige Cup 260 -- 1958 lbs / 260 hp = 7.53 lbs/hp Obviously tires and aero play a role, but that is a large weight/hp disadvantage to overcome. The Griffon is not only making less power, but it's also heavier than the other cars listed. That is quite a feat. Now throw some FI on it.
2022 BRZ Build 2013 FR-S Build |
#34 |
Hot Dog
Drives: quicker than arghx7
Tires make an enormous difference. Street tire vs. track tire is no contest even with a massive power deficit. Put all the cars on the same tires and you have a reasonably fair comparison.
That said, congrats to TRD for shaving big weight off the car and making a big media splash.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#35 | |
Drives: Some rust bucket
#36 |
Even accounting for the difference in tires, it's still an impressive feat given not only the large power deficit, but also the weight disadvantage.
Edit: To explain further, one former race engineer estimated that racing slicks made a 3.2% difference in lap times over DOT R-compounds (and 7.1% over a non-shaved street tire). http://malcolmstrachan.wordpress.com...-racing-tires/ Applying that rough conversion: 1:01:51 -- KTM X-Bow -- 1916 lbs / 241 hp = 7.95 lbs/hp 1:01.87 -- Griffon 86 -- 2276 lbs / 200 hp = 11.38 lbs/hp 1:02.18 -- Lotus 2-Eleven -- 1707 lbs / 256 hp = 6.67 lbs/hp 1:03.77 -- Lotus Exige Cup 260 -- 1958 lbs / 260 hp = 7.53 lbs/hp This is what I mean when I say that -- even accounting for tires -- it's still hugely impressive what the engineers have done with the Griffon 86.
2022 BRZ Build 2013 FR-S Build Last edited by DarkSunrise; 01-11-2013 at 11:06 AM. |
#37 |
Bring a Ferrari or Lotus with factory support and factory driver to the track then compare times. Its a small track in Japan. Most super cars would never use that as a bench mark ever.
Take the Griffin to Mugello or Silverstone. Its just not objective this post.
| Bolt on 6 horsepower for about $50. | MillersOilsUS | Engine, Exhaust, Bolt-Ons | 29 | 01-10-2013 08:53 PM |
| 6 horsepower, 4 lb-ft from an oil change | MillersOilsUS | Mechanical Maintenance and Tools | 1 | 01-03-2013 11:21 AM |
| horsepower goal | jdmboss86 | Engine, Exhaust, Transmission | 96 | 11-20-2012 05:02 AM |
| ft86.com has some serious horsepower! | MrBRZ | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 03-22-2012 07:45 PM |
