Old 01-07-2013, 03:42 PM   #1
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
Eibach Pro-Kit vs RCE Yellow
Looking for a subtle drop on my car. What's the differences between these two?
itisthumper is offline   Reply With Quote
Old 01-07-2013, 03:51 PM   #2
wheelhaus
wheelhaus's Avatar
You're gonna get a lot of flak for this, springs are a commonly discussed topic and can quickly be searched for lots of info.
To prevent this from turning into another "OMG forum etiquette" thread, what are you looking to achieve besides a mild drop? Looks only? Track days?
The specs of each spring set are really easy to find, so what kind of comparison are you looking for?
The Following User Says Thank You to wheelhaus For This Useful Post:
whataboutbob (01-07-2013)
Old 01-09-2013, 04:09 AM   #3
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Also a good idea to add if you plan on replacing shocks or not.
Having stock shocks vs, say, Koni Yellows. Will be a difference.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 01-09-2013, 06:44 AM   #4
nonicname
Drives: it has 4 wheels and a motor
nonicname is offline   Reply With Quote
Old 01-09-2013, 10:28 AM   #5
Turn in Concepts
Turn in Concepts's Avatar
The RCE springs work great on the stock shocks/struts as would the Eibachs. Difference through is that the prokit is designed to lower the car without really increasing performance. The RCE springs will lower the car and increase performance dramatically.
Tony
Turn in Concepts is offline   Reply With Quote
The Following 5 Users Say Thank You to Turn in Concepts For This Useful Post:
ATL BRZ (01-09-2013), Marchy (04-25-2014), suaveflooder (10-01-2013), UPSed (01-09-2013), whataboutbob (01-09-2013)
Old 01-09-2013, 04:41 PM   #6
toysub
Drives: DGM
Tony,
Would you say "increase in performance" at the sake of comfort? Is there a compromise on handling vs road comfort on poor road conditions between the two brands?
Thanks for your input.
toysub is offline   Reply With Quote
Old 01-09-2013, 05:06 PM   #7
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Tony
I disagree with the Eibach springs not increasing performance. Both springs will increase performance...just in different ways. Not every driver will set up their cars the same way. It's like saying your car is wrong because it's painted blue and not black.
The RCE springs are more of a square set up with similar front and rear rates.
The Eibach springs have a rear biased spring rate like the OE BRZ and FR-S springs do.
The difference comes down to driver preference. Ironically, the RCE springs are made by Eibach as mentioned in their post below. You can't go wrong with either.
http://www.ft86club.com/forums/showt...?t=9936&page=2
Jackson is offline   Reply With Quote
The Following 4 Users Say Thank You to Jackson For This Useful Post:
Captain Insano (01-09-2013), itisthumper (01-12-2013), mines13 (01-09-2013), rs999 (08-20-2014)
Old 01-09-2013, 05:07 PM   #8
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by toysub View Post
Tony,
I only went for a ride once in a car with RCE yellows but it was a very bumpy road. Seemed just like stock, maybe a tiny bit harsher but that's probably more placebo than anything.
@Phaedrus29 can chime in hopefully!
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 01-10-2013, 12:50 PM   #9
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
For your BRZ, the RCE Yellows are 66% firmer in front and 28.5% firmer in the rear, and the drop is roughly 3/4 of an inch all around.
The Eibach are about a full inch all around, and as Jackson stated, keeps a rear bias (33% firmer in front, 40% firmer in rear).
Personally, I liked that the Eibachs matched the stock setup's spring rate ratio more, and offered a tiny bit more drop. From what I remember reading about spring rates in RWD cars, firmer rear rates increase your ability to slide the tail, which is something I wanted after putting wider, stickier tires on my new wheels that I installed at the same time.
While I'm sure there's not a significant difference between the 2, my guess is that the RCEs would make oversteering a tad more difficult, which is probably better for speed on a track, but less fun when you want to get sideways.
Smudgeous is offline   Reply With Quote
The Following 2 Users Say Thank You to Smudgeous For This Useful Post:
itisthumper (01-12-2013), thatWESguy (01-10-2013)
Old 01-10-2013, 01:36 PM   #10
stockysnail
Just the tip
stockysnail's Avatar
For me and a couple other guys in my area the Eibach Pro-kit dropped the car 7/8", not a full inch. Pretty close though. I think the pro-kit is similar to stock handling wise as far as rear end kick out except it feels a hair bit better in a corner.
Old 01-11-2013, 08:23 AM   #11
Smudgeous
Smudgeous's Avatar
I found the same to be true for myself, though I did not measure the exact drop amount. I kind of wish there was an option for the back to be closer to a 1 1/4" drop, as I'm a sucker for symmetry and the rear still looks high compared to the front, but overall it's much better than stock.
That symmetry is something I notice with the wheels as well. While I wanted to go with the same wheels at each corner, I can't help but wonder if I should have gone +35s only in the rear, and dropping to +45s for the fronts..
Old 01-11-2013, 11:51 AM   #12
Turn in Concepts
I guess it really depends on what you want. If you are looking for outright grip and lap times on a road course I think the RCE would be a bit better. Lowering too much on a strut based car is never a good thing especially when strut travel is limited and non adjustable.
Tony
Old 01-11-2013, 05:19 PM   #13
Jackson
Jackson's Avatar
Tony
Again, this is all relative. I would love to hear your personal on track driving impressions of both kits. Have you driven and tracked both the RCE and Eibach springs?
Old 01-11-2013, 05:23 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tony
Please explain how you came to that conclusion?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Help removing yellow spots MattR Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 56 06-04-2016 01:17 AM
White n' Yellow. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 08-02-2015 04:01 AM
Does this mean a Yellow BRZ/GT-86 will be in Initial D Stage 6? LeeMaster BRZ Photos, Videos, Wallpapers, Gallery Forum 43 06-23-2015 01:53 PM
Yellow fog tint looks awesome! DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 37 11-07-2012 03:40 AM
