Old 01-10-2013, 07:29 PM   #29
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Originally Posted by Scooby South View Post
I think its going to depend on the course and venue.. I am going to have both.. RS3's and the Z2's ..
Baller
GTB/ZR-1 is offline   Reply With Quote
Old 01-10-2013, 07:35 PM   #30
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by whataboutbob View Post
You must have a _good_ connection.
Hmmm Not sure..
Ahh I see the difference.. .. mine are 255 ...and you guys are checking 245, which, according to TireRack is the 03/08/13 date...sorry
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
whataboutbob (01-10-2013)
Old 01-10-2013, 07:39 PM   #31
Eric1855
Drives: LP DSP / CSP '13 BRZ
You all are talking two different sizes
The 255/40s are coming in January, but the 245/40s not until March.
Scooby South, what wheels and offset are you running with the 255s?
I want to go with 255s on 17x9 +42 RPF1s but I am worried about rubbing up front, do yours clear ok with coilovers? I saw Vorshlag had rubbing issues with 255s, but that was with oem sized coils.
Eric1855 is offline   Reply With Quote
The Following User Says Thank You to Eric1855 For This Useful Post:
Scooby South (01-10-2013)
Old 01-10-2013, 07:39 PM   #32
ayau
Drives: Some rust bucket
Tire Rack Getting the Z2 instock here soon...AND ordered..
http://www.tirerack.com/tires/tires....el=Direzza+ZII
ayau likes this.
Old 01-10-2013, 07:45 PM   #33
Scooby South
Conedancer
And yes I figured that out also.. 2 different sizes........ same for rims 17x9 42.. same as I am running the RS3's on.. only a bit lighter..
Bill
Old 01-10-2013, 07:47 PM   #34
Scooby South
Conedancer
Originally Posted by GTB/ZR-1 View Post
Baller
only if you say so...
Am I in your head yet... :happy0180:
Old 01-10-2013, 08:25 PM   #35
Scooby South
Conedancer
From Toyko Autosalon... HOW APPROPRIATE..
Old 01-11-2013, 12:51 AM   #36
whataboutbob
AutoX-10/10ths every run
Hmmm Not sure..
Wasn't trying to be a jerk, just confused. :happy0180:
Please let us all know once you get yours how they are!
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Scooby South (01-11-2013)
Old 01-11-2013, 12:55 AM   #37
Scooby South
Conedancer
its all good...I promise..
Old 01-11-2013, 05:24 PM   #38
Scooby South
Conedancer
Rule of the Day:
Any LSD can be used
AND then theres This:
looking forward to getting this installed at some point..
Old 01-11-2013, 09:33 PM   #39
EN2_Squirrel
EN2_Squirrel's Avatar
What about pulleys? Subframe braces?
Thanx in advance
Sent from my SCH-I510 using Tapatalk 2
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 01-11-2013, 10:01 PM   #40
whataboutbob
Thanx in advance
Don't answer his questions, he beat me in STX last time out.
Build thread:Here
Old 01-11-2013, 10:05 PM   #41
Scooby South
Conedancer
Braces....not at all..
Pulley-
H. Any accessory pulleys and belts of the same type (e.g., V-belt, serpentine)
as standard may be used. This allowance applies to accessory
pulleys only (e.g., alternator, water pump, power steering
pump, and crankshaft drive pulleys). It does not allow replacement,
modification, or substitution of pulleys, cogs, gears, or belts which
are part of cam, layshaft, or ignition drive or timing systems, etc.
Any crankshaft damper or pulley may be used. SFI-rated dampers
are recommended. Supercharged cars may not change the effective
diameter of any pulley which drives the supercharger.
hope that answers your question..
Bill
Old 01-11-2013, 10:08 PM   #42
Scooby South
Conedancer
Strut Braces and Sub-frame connectors:
G. Strut bars (per Section 12) are permitted with all types of suspension,
subject to the following constraints:
1. a two-point strut bar may be added, removed, modified, or substituted,
but only with another two-point strut bar.
2. A triangulated (3-point) strut bar may be removed, modified, or
substituted; substitution may be with either a triangulated or a twopoint
strut bar. The connection to the chassis (i.e., firewall, bulkhead,
etc) must be in the standard location.
3. Lower suspension braces must be attached to the lower suspension
pickup point locations on the chassis within 2 inches (2”, 50.8
mm) in any direction of the actual suspension attachment to the
chassis.
4. Except for standard parts, no connections to other components
are permitted.
Additional holes may be drilled for mounting bolts. Only bolt-on attachment
is permitted. Interior trim panels may be modified to allow
installation of strut bars. Holes or slots may be no larger than necessary
and may serve no other purpose. This does not permit any
modifications to the frame or unibody beyond the allowed mounting
holes.
H. Longitudinal (fore-aft) subframe connectors (“SFCs”) are permitted
with the following restrictions:
1. They must only connect previously unconnected boxed frame rails
on unibody vehicles.
2. Each SFC must attach at no more than three points on the unibody
(e.g. front, rear, and one point in between such as a seat
mount brace or rocker box brace).
3. SFCs must be bolted in place and not welded.
4. No cutting of OE subframes or floorpan stampings is permitted.
Drilling is permitted for mounting bolts only.
5. No cross-car/lateral/triangulated connections directly between the
driver’s side and passenger’s side SFCs are permitted. Connections
to OE components such as tunnel braces or closure panels
via bolts are allowed and count as the third point of attachment.
No alteration to the OE components is permitted.
14. Street Touring® Category — 83
6. SFCs may not be used to attach other components (including but
not limited to torque arm front mounts or driveshaft loops) and
whataboutbob (01-11-2013)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
