Old 01-10-2013, 03:02 PM   #15
miwialex
Drives: 2013 Whiteout FRS
Originally Posted by Scooby South View Post
the way its setup... you can run one or the other.. Personally I am going to run a Catless header...overpipe and catted midpipe and open cat-back with a turn down.. if you wanted to you can run a Catted header, overpipe and non catted midpipe.. Both Achieve the same goal..and Time will tell which is more Efficient..
Bill
This might not exactly be true. I haven't exactly looked too closely at the exhaust system yet, and don't know how far apart the two cats are from each other, but if you are going from 2 down to 1, the replacement cat has to be no more than 6 inches from the exit of the last cat.
E. Catalytic Converters - Any high flow catalytic converter(s) are allowed,
but must attach within six inches of the original unit. Multiple
catalytic converters may be replaced by a single unit. The inlet of the
single replacement converter may be located no further downstream
than 6” along the piping flow path from the original exit of the final
OE converter.
This means that the replacement cat, has to be within 6 inches of the one in the midpipe. If the cat in the header is within 6 inches, its fine. If not, then you can't do it.
miwialex is offline   Reply With Quote
Old 01-10-2013, 03:05 PM   #16
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Just so everyone is clear, that is the FARTHEST it can be downstream is 6" past the last cat. You can however put it within 6" of the upstream one instead. Given the design of the stock header and aftermarket headers we have seen so far it would be vary hard to not meet this rule.
TomR
ABQautoxer is offline   Reply With Quote
The Following User Says Thank You to ABQautoxer For This Useful Post:
Scooby South (01-10-2013)
Old 01-10-2013, 03:35 PM   #17
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
http://cms.scca.com/documents/Solo%2...categories.pdf
STX class on page 2; <5.1 na or <2.0 fi
Factory Supercharged only?
I'm not replacing the front pipe cat - I'm deleting it and have only the one in the header.
Amadeus is offline   Reply With Quote
Old 01-10-2013, 03:54 PM   #18
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Tire Rack Getting the Z2 instock here soon...AND ordered..
http://www.tirerack.com/tires/tires....el=Direzza+ZII
Scooby South is offline   Reply With Quote
Old 01-10-2013, 03:55 PM   #19
miwialex
ah makes sense. the wording I guess was just a bit confusing to me
Old 01-10-2013, 05:01 PM   #20
Scooby South
Conedancer
yes Factory only.. ...like a Cobalt...
not applicable to an aftermaket unit..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
Amadeus (01-10-2013)
Old 01-10-2013, 06:18 PM   #21
whataboutbob
AutoX-10/10ths every run
245/40R17 Z2 on order here too. Est avail is mid March 2013.
Build thread:Here
Old 01-10-2013, 06:25 PM   #22
Scooby South
Conedancer
nope...might want to check again... Shipment is coming in on the 16th of Jan.. at least thats what I am told... they are in Customs now..
Bill
FRSfan111 (03-09-2013)
Old 01-10-2013, 06:30 PM   #23
OrbitalEllipses
Drives: Attitude
Expensive! Let me know how that wet traction is.
Old 01-10-2013, 07:10 PM   #24
whataboutbob
Bill
That would be AWESOME!
Build thread:Here
Old 01-10-2013, 07:22 PM   #25
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Would like to see a back-to-back w/ the R-S3s to see which one is faster. Also, why is the 245/40-17s heavier than the 255s?
GTB/ZR-1 is offline   Reply With Quote
Old 01-10-2013, 07:25 PM   #26
whataboutbob
Bill
You must have a _good_ connection.
Build thread:Here
Old 01-10-2013, 07:27 PM   #27
Scooby South
Conedancer
I think its going to depend on the course and venue.. I am going to have both.. RS3's and the Z2's .. both mounted up.. so I will have a choice..
Bill
Old 01-10-2013, 07:28 PM   #28
GTB/ZR-1
GTB/ZR-1's Avatar
Scooby South IS the connection... lol
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
