Old 01-06-2013, 02:31 PM   #43
xwd
Originally Posted by twincamRob View Post
Doesn't turning off the traction control by holding the button for 5secs do the same thing as this or am I missing something? I noticed no weird brake "interference" when I did that at the track...
It's a little different than just holding the Trac button for 3 seconds. It turns off the same things those systems turn off but then also turns off the brake functions which are electronic brake-force distribution and brake assist (panic stop). It doesn't seem to turn off ABS, and I'm not sure what else it might turn off.
EBD is used to make sure wheels do not lock up under braking and also works with the VSC system. Instead of having a prop valve setting F/R bias the system can figure out how much force is needed at each wheel.
The brake assist will monitor the rate you are pushing the pedal down and if it's a high enough rate, it will apply the brakes full on for you since it assumes you are trying to stop the car.
I was going to create a cheat sheet for the sequence to put in the car, but after you do it a couple times it's pretty quick.
Anyone know how it determines if the vehicle is "warmed up?" I assume it's based off coolant temp/oil temp or both.
The Following 2 Users Say Thank You to xwd For This Useful Post:
hmong337 (02-08-2014), kevaughan (06-02-2025)
Old 01-06-2013, 05:57 PM   #44
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
the water temperature is a dummy gauge.
water temp don't even go up unless you run your engine moderately hard...and then have it sit still at a light.
Currently in cold weather, i could be driving on the high way, and then park the car and the water temperature don't even reach 110deg.
CyberFormula is offline   Reply With Quote
Old 01-06-2013, 06:25 PM   #45
CSG Mike
CSG Mike's Avatar
I've noticed the ECT gauge goes up really slowly, but the sequence *only* has worked for me when the gauge is at its "normal" position.
How quickly the gauge goes up for me really depends on how I'm driving when the engine is cool. Gotta remember guys, the DI really helps keep the engine cool, especially when you're driving under low load and it's ONLY using localized lean burns.
Old 01-06-2013, 07:12 PM   #46
xwd
I'm not talking about the dash gauge, I'm talking about the ECT sensor itself which is a thermocouple which reads fairly precisely. If you had a real water temp gauge in the car you could know exactly when to perform the sequence.
Old 01-07-2013, 10:56 PM   #47
simpleisbest
Senior Citizen
Drives: Scion FR-S
Originally Posted by cobrabyte View Post
So, now someone with Arduino smarts should create a little board that performs the 'dance' with the push of a button. I dread having to do this before every track session interval.
Thanks for the info, OP!
I know first hand that something of the sort is in the works! Have yet to see one first hand though...
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
cobrabyte (01-07-2013)
Old 01-07-2013, 11:23 PM   #48
gmookher
did my pedal dance, worked awesome, easy as pie
soooo cooool
wow
thanks OP
Old 01-08-2013, 09:40 AM   #49
xwd
Yeah once you do it a couple times it's not difficult at all and takes about 10 seconds. I'm definitely going to have to test it out at an autocross to see what the differences are between using it and the normal disabling of the VSC/Trac. I haven't really noticed any brake intrusions in my previous autocrosses.
Old 01-08-2013, 10:02 AM   #50
gmookher
more front bias under hard braking, my nose seems to 'dip' more..
Old 01-08-2013, 10:08 AM   #51
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I noticed a difference doing a "mini time-attack" this weekend (think less technical autocross with multiple hotlaps). I could trailbrake into the corner much better and get rotation. I was on the OEM tires for this so they rotate really easy as is (new track tires are on order) but when attempting to trail brake before the pedal dance, the pedal would go hard like a normal car's ABS pulsing, annoying.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 01-09-2013, 06:19 AM   #52
JiB
JiB's Avatar
Drives: GT86
Cheers for the sequence
JiB is offline   Reply With Quote
Old 01-09-2013, 06:20 AM   #53
Walldodger
Walldodger's Avatar
Drives: Four wheels, two seats, etc
Are you sure it's not just confusing the ECU and causing the car to throw a fault code?
Walldodger is offline   Reply With Quote
Old 01-09-2013, 09:52 AM   #54
gmookher
sure.
Old 01-15-2013, 08:34 PM   #55
JiB
JiB's Avatar
Drives: GT86
Originally Posted by TOMIMOTO View Post
I don't know why, but the process reminds me of this.
This reminds me of the cheat for the old sega console game Mortal Kombat 1 for blood mode, ahhh the good old days
Old 01-16-2013, 07:38 AM   #56
Jeffsu350
Drives: Frs
[ame="http://www.youtube.com/watch?v=CWXv7UNA7hg&sns=em"]FRS Pedal dance - YouTube[/ame]
My pedal dance testing
Jeffsu350 is offline   Reply With Quote
The Following 12 Users Say Thank You to Jeffsu350 For This Useful Post:
Aznsky (01-16-2013), Blokatos (05-15-2016), Bristecom (06-09-2013), chanomatik (01-24-2013), dave77 (01-05-2014), djdnz (03-06-2013), Ganthrithor (03-23-2013), jcw99 (06-13-2018), juliog (03-16-2013), Ramster (08-14-2015), Sargy (01-19-2013), whataboutbob (01-17-2013)
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
