Old 01-04-2013, 01:59 PM   #1037
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Originally Posted by CLM View Post
Anyone got the "Engine Idle Chirping" recall thing done to their car? If so which dealer? and how did things go? I just hate our local Toyota dealer by my place.. too many bad experiences with them..
There is a new Scion dealership in Brooklyn Center. It opened a month or two ago. Maybe try that one?
Starscream15 is offline   Reply With Quote
The Following User Says Thank You to Starscream15 For This Useful Post:
CLM (01-05-2013)
Old 01-05-2013, 07:16 AM   #1038
ToxicSneakers
Deleted
ToxicSneakers's Avatar
My chirps were cured at Rudy Luther's in Golden Valley, only because I showed up with a copy of the TSB in my pocket. Still good after 1,500 more miles today.
ToxicSneakers is offline   Reply With Quote
The Following 3 Users Say Thank You to ToxicSneakers For This Useful Post:
CLM (01-05-2013), LeeMaster (01-06-2013), Starscream15 (01-05-2013)
Old 01-07-2013, 11:52 AM   #1039
ayau
Drives: Some rust bucket
@neutron256, do you know if dealers have the ability to disable the TPMS light with their tools? Is your device basically the same device the dealers use? What's the latest info on disabling the TPMS light?
Thanks!
Old 01-07-2013, 12:07 PM   #1040
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Thanks!
Federal law prohibits dealers from disabling TPMS even though you as an individual are not required to have it in Minnesota. So even if they can do it they won't.
My tools can read, and reprogram the sensor ID's just like the Dealer or a well equiped tireshop can, but I can't disable them.
You can also reprogram sensors with Techstrem, but not if you have one of the cheap knockoff cables like mine.
I may have a solution for disabling TPMS. I'm currently running my winter wheels without TPMS and got an TPMS light shortly after I switched. I happened to have Techstream Connected for another reason, and I cleared the TPMS error. Since then the light has not come back on. I'd be curious to see if this is really the case so if you want to try it let me know. I'm temporarly without a Windows XP PC that will run Techstream, but I should have that fixed soon.
Old 01-07-2013, 12:11 PM   #1041
neutron256
neutron256's Avatar
Anyone interested in getting together sometime soon? I was thinking about maybe a Saturday, Sunday brunch. Pizza Luce in Richfield does a really nice weekend brunch, not to expensive, and they have Mimosas, and a Bloody Mary bar.
Interested? Other Suggestions?
Old 01-07-2013, 12:12 PM   #1042
ayau
So you're saying keeping Techstream plugged in might disable the light? I'd try it on mine but mine's currently in storage.
Old 01-07-2013, 12:20 PM   #1043
neutron256
neutron256's Avatar
No acutally I think that just connecting Techstream, and clearing the error prevents the light from coming back on. No need to keep Techsteam connected. This could just be a coincidence. since I don't drive a lot it might just have not cycled back on.
I have another theory that if you set all the sensor ID's to 00000 using Techstream that it will disable TPMS. Our car supports a spare tire sensor, but it's set to 00000 by default since we don't have a sensor in the spare. I can't test this one unless I get a better cable that supports all the Techstream features though.
Old 01-07-2013, 12:46 PM   #1044
ayau
Sensor in the spare? A little overkill, don't you think? What country require a sensor in your spare?
It sounds like setting it to 0 overrides/disables the TPMS. I know that the car doesn't include TPMS in other countries, which means there should be a way to disable it, or those cars run an entirely different ECU.
I'm sure a couple of us would be willing to chip in for the better cable if we can keep the TPMS light shut off.
Old 01-07-2013, 01:27 PM   #1045
Opposed
Drives: 2013 Asphalt FR-S
Im always down. I do work a handful of Saturdays and Sundays, but I have my schedule pretty far out in advance, so im sure we could make something work...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 01-07-2013, 03:34 PM   #1046
neutron256
neutron256's Avatar
I think the sensor in the spare would be for cars with a full sized spare insted of the little donut we have which is designed to be stored for long periods with little to no loss in pressure.
The DrewTech MongoosePro cable which is the officaly approved cable for Techstream is $500 which is way more then I would pay. There is the Tactrix Openport 2.0 which is $169 which works with Techstream, but I haven't been able to confrim if it can program TPMS ID's on our cars.
If I can confirm the Tactrix cable works I'll be more then happy to buy one.
The Following User Says Thank You to neutron256 For This Useful Post:
ayau (01-07-2013)
Old 01-07-2013, 06:34 PM   #1047
neutron256
neutron256's Avatar
The wheels and tires I bought from @_F-R-S_ arrived today.
Direzza Star Spec 235/40/17s on Sparco Assetto Garas.
They're not really that much wider then the stock tires but man that looks like one beefy tire.
The Following 4 Users Say Thank You to neutron256 For This Useful Post:
ayau (01-07-2013), Chupacabra (01-08-2013), LeeMaster (01-09-2013), _F-R-S_ (01-07-2013)
Old 01-07-2013, 07:40 PM   #1048
ayau
Wheel specs?
Edit: Nevermind, they're 17x7.5 according to this thread.
http://www.ft86club.com/forums/showthread.php?t=25117
They're a bit meaty for a 7.5" wide tire IMO. I'm sure you'll burn right through those Star Specs in no time though.
Old 01-07-2013, 08:36 PM   #1049
Starscream15
Very nice! Lots of grip there.
Old 01-07-2013, 08:42 PM   #1050
neutron256
neutron256's Avatar
Wheel specs?
Yeah I mostly wanted the wheels. The tires were a plus. But who knows, with as little driving I do they could last a couple years.
Check in, eh? NorthFool CANADA 24 02-23-2012 07:32 AM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 05:56 PM
how do you check a site 4agze Off-Topic Lounge [WARNING: NO POLITICS] 3 11-21-2009 09:27 PM
Video of FT-86 @ TMS from Edmunds. Check out how small the car is next to people. JDMinc FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 10-25-2009 08:53 PM
