Drives: waiting on a 2021...
Naturally aspirated and 87 octane...
So, after reading on the Forced Induction forum about how much boost is safe to run on pump gas, I have a question. If you can run around 5lbs. of boost(roughly) on a stock motor with 93 octane, why couldn't the factory engineers have tuned the stock motor to run on 87 octane? If aftermarket tuners can deal with the increased cylinder pressure using pump gas, it seems that a N/A motor could run on 87 octane, even with 12.5 to 1 compression. I realize that there would be a loss in power, but technically it should be able to be done, right? And yes, I realize its a sports car, and yes, I like all the power I can get, and I don't mind paying for Premium, I was just wondering if its possible, and how much power it would give up. Any tuners ever try this?
#2 |
Drives: Argento 6spd FR-S
Why would you even spend the time and money to tune for 87? Its less than 5$ difference to fill up. Since its on average 250$ for a tune. It would be a complete waste of money to detune the car to save a few dollars.
Personally I wish they would just change to 93 octane only everywhere and get rid of this 3 tier bs. If you want to do a tune to have cheaper fill ups then go with e85, then you get more power and a lower fillup. Actual MPG tho I have seen everywhere from better to worse on the car. Also people are running 7-8.5 psi on pump gas, maybe more I havent really looked that far. But Im gonna go with yes.... if you really wanted to spend the money on a tune Im sure someone like Visconti could make a map. |
#3 |
Drives: subatoy
between 87 octane and 93 octane you only save $3 per gas tank, if you are that CHEAP go buy another car.
#4 | |
I Love custom Turbo kits
Drives: Limited BRZ
#5 |
Ok, what part of this:
" I like all the power I can get, and I don't mind paying for Premium, I was just wondering if its possible, and how much power it would give up. Any tuners ever try this?" did you not understand? I'm not saying I want this, I'm wondering how much power you would actually lose. I'm also not cheap, I stated very clearly that I did not have a problem putting 93 octane gas in my car. It was more of a technical question. Last edited by zooki; 01-06-2013 at 09:38 PM. |
#6 |
Custom User Title
Drives: Asphalt FR-S MT
Is it really a question worth answering though? I think that is a better question.
If you (factory and tuners) are going to spend the time and money to do it, spend that time to improve it to its best.
#7 |
Drives: Subaru BRZ Limited
I'm going to drive backwards to work tomorrow. I wonder what my MPG will be like?
#8 |
Well, here's my train of thought...if the aftermarket can get the electronics to cope with increased cylinder pressures of FI through tuning while still using 93 octane gasoline, why can't the engine be tuned to use 87 octane at the decreased cylinder pressures that a N/A motor has. It's not like 93 octane has any more power potential than 87, in fact it may have less power potential do do its slower burn rate. I think direct injection motors have a lot more leeway in the compression/octane relationship due to the way fuel is introduced into the cylinders. If you can get the same amount of power with lower octane gas, why wouldn't you? I'm talking about from the factory. I wouldn't spend the money on an aftermarket tune to get the motor to produce 200 HP on 87 octane. But I think the factory could do it. So, just to be clear. I am not looking for an aftermarket tune for 87 octane, I am fine with the car the way it is, I have no problem buying 93 octane either. This is just a thought experiment on what I've seen boosted motors doing with 12.5 to 1 compression and pump gas.
#9 |
this motors CR is not for 87
#10 |
Just...nevermind.
#11 |
Drives: infiniti g37x
ha, that was entertaining.
#12 |
Drives: lexus es 350
i think its a good question
#13 |
Drives: 2013 FRS, Raven, Auto
When you bought your FR-S/BRZ, the dealer probably put 87 in it and your car didn't blow up. The Mustang 5.0 pulls timing and runs on 87 fine; just less HP. Until we have the software available for logging, we just don't know. The logic might be there now.
I'm not sure if ECUTEK found the memory location where timing is stored. If they did, we can look at the difference between the exptected timing and actual. See if the timing is pulled with 87 octane once pinging is detected. The Turbo Subaru's have a software tool called Learning View that does this. |
#14 |
Drives: '06 AM V8V Coupe
If you really stay off the throttle you might even be able to burn a whole tank of 87 and not have the car misbehave...
It might be possible to save gas money by blending in 1 gallon of E85 into each tank, especially since the motor is direct injected you can raise the knock resistance quite a bit. For best results use a new ignition map of course, but it shouldn't be off by too much. |
| Naturally Aspirated - Backpressure | phenom86 | Engine, Exhaust, Transmission | 16 | 03-19-2014 12:07 AM |
| 93 Octane | Smokinbuffalo | Northwest | 20 | 09-02-2012 05:24 PM |
| 110 octane | EZWood | Engine, Exhaust, Transmission | 19 | 06-29-2012 08:12 PM |
| Who is happy the engine will be Naturally Aspirated? | Ryephile | Engine, Exhaust, Transmission | 491 | 05-02-2012 10:10 PM |
| 93 Octane? | ashtray | BRZ First-Gen (2012+) — General Topics | 175 | 04-04-2012 12:22 PM |
