Old 10-15-2011, 12:13 AM   #1
Aldo the Apache
Drives: accord v6 (ft86 downpayment)
STI engine
What's going on guys? New to the site here. I'm very excited for the ft86 it looks amazing! I'm VERY concerned that they will manage to **** it up before the production car but let's keep our fingers crossed.
So who here thinks it will be relatively easy to drop an sti motor in here? I thought this car was going to be turbocharged stock. Hell when I drive one I might very well find they picked the right motor from the start. But just for S&G who thinks it will bolt up or do you reckon itll need some fabrication?
Aldo the Apache is offline   Reply With Quote
Old 10-15-2011, 01:50 AM   #2
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It will need fabrication.
At the very least you'll need modified wiring harness, custom headers, oil pan, downpipe, IC piping, IC mounting (and/or bumper beam if you want anything of worthwhile size). On the plus side, the EJ257 longblock should bolt right up to the stock motor mounts and bellhousing.
But, there won't be enough room between the engine and the firewall to plumb the exhaust in the same way as it has always been done on the Impreza. The turbo will need to be mounted out front like on a 2010+ Legacy GT. The problem is that the EJ will be ~1" longer than the stock engine (EJ = Timing Belt, FA = Timing Chain), and there might not be enough room left to stick a turbo between the accessory belt and the radiator.
old greg is offline   Reply With Quote
Old 10-15-2011, 08:30 PM   #3
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
I wonder if any parts will be sharable between the 2 engines. EJ207 and FA20
EJ207
FB20
FA20
Where the engine sits
quik1987 is offline   Reply With Quote
Old 10-16-2011, 05:02 AM   #4
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
just put a porsche engine in ...and make a custom exhaust to come out from the front fenders.
CyberFormula is offline   Reply With Quote
Old 10-16-2011, 05:58 AM   #5
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
And light pedestrians on the sidewalks ablaze.
ryun84 is offline   Reply With Quote
Old 10-16-2011, 08:39 AM   #6
S13Kuro
Will it drift?
S13Kuro's Avatar
Drives: Nissan Silvia S13
Just as long as I can spray close spectators with my nitrous as Luda admires my timely arrival I'll be happy.
Okay no but seriously fairly sure there'll be turby ones later down the track anyway. Haven't they already released that there's a possibility of a 1.6T a year after initial release?
S13Kuro is offline   Reply With Quote
Old 10-18-2011, 06:29 PM   #7
Aurex
Aurex's Avatar
Drives: 2006 WRX STi, 1994 Mazda 323
What the hell? Does anyone else think that the oil filter that is mounted on the FB20 and concept car looks like a disaster waiting to happen? That looks like it will make a mess of the engine bay. I notice that there is a lip there, but it can't possibly hold all the oil that will come out of that filter?
That was the best thing about the EJ series motors, the oil filter was mounted on the bottom of the motor pointing straight down...
Aurex is offline   Reply With Quote
Old 10-18-2011, 07:10 PM   #8
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Never seen recent V engine trucks? they have filter like that & it's working perfectly
Old 10-18-2011, 07:44 PM   #9
Aurex
Aurex's Avatar
I haven't. I don't really pay any attention to trucks at all. I'm also not 100% up to date with current\future Subaru tech.
My concern when I saw the above picture(s) was that the filter would still be full of oil and when you take it off it would drain out of the filter, fill that recessed area and spill down the block.
When you shut the motor off the oil must drain out of the filter then?
Old 10-18-2011, 08:02 PM   #10
ichitaka05
Site Moderator
ichitaka05's Avatar
Under the oil filter mount, there is a small nipple which you can pull off to drain that catch area. Some put a small disposable bottle or cup directly under it to catch the oil that drips out. Some others have even gone as far as to run a hose all the way down by the oil pan.
Old 10-18-2011, 08:23 PM   #11
Aurex
Aurex's Avatar
Perfect! Thank you sir, for taking the time to explain how it works.
Old 10-18-2011, 08:27 PM   #12
ichitaka05
Site Moderator
ichitaka05's Avatar
No problem :happy0180:
Old 10-18-2011, 08:33 PM   #13
Marrk
Drives: Honda Fit
Slightly OT: Anybody have a guess as to whether the cams on the FT-86 will be chain driven or belt driven? What does Subaru usually use?
Marrk is offline   Reply With Quote
Old 10-18-2011, 08:39 PM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
^Expect to have it chain. Older model was belt, but recently been chain
