#57 | |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
#58 |
Drives: Brz
has anyone actually tried to remove the metal bar? without cutting it off, but just unscrewing it or something?
or is it a permanent metal bar to support something? i've been looking at this thread. http://www.ft86club.com/forums/showthread.php?t=8336 and it looks like the metal bar isnt there, or i just cant see it in the photos. I wish I had the car already so I could have a look myself |
#59 | |
#60 |
Meh!
Drives: Satin White, 86, Manual
Problem is that everything seems to screw onto that metal bar. So you might end up with creaks from the dash if you cut it. I don't use CD so why not just relocate the faceplate.
#61 | |
Grip>Slip
#62 |
Meh!
Umm I have tipped the faceplate and headunit but not done the wiring bit yet. It pretty easy but I'd recommend you tip both wire and headunit before soldering to avoid heat transfer. Plus you should apparently use untwisted pair cat5e. Not sure why though.
| The Following User Says Thank You to MaXimus For This Useful Post: | CxG (04-01-2017) |
#63 | |
Drives: Whiteout FR-S
Thanks! |
#64 |
Drives: '13 GBS Subaru BRZ
If your referring to UTP CAT5 it Unshielded Twisted Pair, not "untwisted pair". I have no idea why it would matter if it were shielded or not.
#65 |
Meh!
Me neither, I know guys have had issues with using printer cables n stuff like that. I don't think it should be an issue since I'm only going to need 12-14in extension. One thing I hate is that the face plate connector is 20 pins.
#66 |
Drives: Megane 2
Any news on ELA release ?
#67 |
Drives: Scion Tc
I wonder of anyone will make progress now the dock is out and they are outputting audio with the touch pins
#68 |
#69 |
Grip>Slip
#70 | |
Drives: Toyota 86 Turbo, Lexus NX300H
yes. there is. Someone of korean 86 forum done it. He opened all front panel . & removed that metal bar . so nothing happened. everything is ok. =) You can see picture from here http://cafe.naver.com/area86/3338 |
| Nexus 7 Tablet | Lefty | Electronics | Audio | NAV | Infotainment | 63 | 06-13-2015 01:18 PM |
| Tablet Install Build Diary | Dezoris | Electronics | Audio | NAV | Infotainment | 98 | 03-13-2014 12:40 PM |
| Longo Scion Demo Build Journal - Car arrives next week | xravexboix | Member's Car Journals | 12 | 06-15-2012 12:00 AM |
