orthojoe
Old 01-02-2013, 09:52 PM   #15
CSG Mike
CSG Mike's Avatar
A clutch bypass should have no effect on it; I've done it both holding and not holding the clutch down, as well as in gear and in neutral...
Old 01-02-2013, 09:57 PM   #16
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Originally Posted by Aznsky View Post
Wow those are some very helpful results!
I'm assuming the electronics go back to normal after you restart the car?
I wonder how this was figured out and whether or not we can make it simpler.
I know a tech who said there was a way to turn it all off but he wouldn't say how. I don't think they're supposed to divulge this info.
SubaSteve is offline   Reply With Quote
Old 01-02-2013, 10:37 PM   #17
celica73
Well, I did the pedal dance right. Mike's procedure worked for me, though it took a while because I kept trying before the car warmed up. It might be easier to use my techstream cable. I worry about pulling things from the OBD port when the engine is running, and I won't want the laptop in the car all the time.
Old 01-02-2013, 11:39 PM   #18
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
This should almost be a sticky thread.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 01-03-2013, 12:39 AM   #19
bpracer
Drives: Asphalt FR-S
Ah, now I get it! This is the third thread mentioning "the pedal dance" but not the real effect.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 01-03-2013, 12:39 AM   #20
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Good info!
Old 01-03-2013, 12:48 AM   #21
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
good info thanks!
Lee358 is offline   Reply With Quote
Old 01-03-2013, 01:05 AM   #22
RL_BRZ
Drives: BRZ WRB Pearl Limited Manual
Thanks for sharing... I vote to Sticky this Thread.... :-)
RL_BRZ is offline   Reply With Quote
Old 01-03-2013, 01:10 AM   #23
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
So, now someone with Arduino smarts should create a little board that performs the 'dance' with the push of a button. I dread having to do this before every track session interval.
Thanks for the info, OP!
cobrabyte is offline   Reply With Quote
Old 01-03-2013, 02:44 AM   #24
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
- I tried trail braking mid-turn with the "normal" electronic aids off, but without the pedal dance. This resulted in a spin; the car literally locked up the rear brakes.
This reminds me greatly of a scenario I experienced in my last Autocross (). Thanks for testing this out for us. I'll have to check it out myself the next time I go out.
FrX is offline   Reply With Quote
Old 01-05-2013, 11:16 PM   #25
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Ok the secret is out I guess...
Just be very careful as the FRS is a rapid responding car and if the driver isn't quick and accurate and very versed with dynamic car control, things can get hazardous pretty fast at high momentum inputs. We learned on analog cars like this in the past with older cars, but threashold was a lot more forgiving back then with moderate tires and compliant frames, chassis and suspension.
This car is like driving a Lancia Stratos or a Lotus Elise when it's fully analog, and if you ask anyone of age who know them, you'll understand what I am getting at here.
Go for it! But stay safe!!
Moto Miwa
www.club4ag.com
R&D Driving Engineer, Product Planning Consultant
Consulting Member at Cusco, OEM+, RS-R.
www.club4ag.com
Moto-P is offline   Reply With Quote
The Following 23 Users Say Thank You to Moto-P For This Useful Post:
Celicadude (01-23-2013), chanomatik (01-24-2013), CSG Mike (01-06-2013), CxG (08-03-2015), Fly Guy (04-26-2013), fooddude (04-06-2014), heeltoe86 (03-14-2013), HunterGreene (05-01-2013), IShouldStudy (03-14-2013), Magiclow (04-10-2015), mfbmike (08-31-2013), mixxxx (04-03-2018), mkiisupra (01-06-2013), mo8ius (03-22-2013), Nasty Sausage (02-06-2014), Pat.Thornton (05-10-2016), QFry (02-12-2013), Quentin (10-23-2014), TofuJoe (08-21-2018), TorontoNat (06-05-2018), virobloc (03-25-2013), why? (09-22-2015), zohare (01-17-2013)
Old 01-05-2013, 11:30 PM   #26
nix
nix's Avatar
Drives: AVO BRZ
This was posted in September by @086A who found it in the repair manual. This ft86 system is called auto lsd it's like a supplement to the diff where the electronics apply abs pulse to the loaded wheel when the lsd is struggling.
http://www.ft86club.com/forums/showt...186#post464598
It's already done. Search for 'VSC cut'. Autofactory was one of the earliest. http://www.autofactory.jp/product/to...?mode=s&seq=14
nix is offline   Reply With Quote
The Following 4 Users Say Thank You to nix For This Useful Post:
Bristecom (06-09-2013), cobrabyte (01-06-2013), Fly Guy (04-26-2013), MrAmalto (08-29-2014)
Old 01-05-2013, 11:38 PM   #27
Moto-P
Moto-P's Avatar
Just be very careful as the FRS is a rapid responding car and if the driver isn't quick and accurate and very versed with dynamic car control, things can get hazardous pretty fast at high momentum inputs. We learned on analog cars like this in the past with older cars, but threshold was a lot more forgiving back then with moderate tires and compliant frames, chassis and suspension.
Just wanted to add, Yes the normally available TRC/VSC full off will function almost the same.
The VSC intervention in the all off mode from 3 sec press of TRC switch, normally available will allow almost all but the largest of slip angles, and allows you to be sideways pretty much in most all situations...
What you get with this additional step is the ABS function to turn off, leaving you with fully analog car. But in most cases the ABS is a completely beneficial thing and unless you're training to be a better all-around driver, the ABS should be left on so you're not flat spotting tires or losing precious seconds off the lap by having it being off.
It's not a performance enhancing mode really, it is more a diagnostic mode for benching the car's performance without electronic intervention.
Moto Miwa
www.club4ag.com
www.club4ag.com
The Following 2 Users Say Thank You to Moto-P For This Useful Post:
CxG (08-03-2015), Magiclow (04-10-2015)
Old 01-06-2013, 12:02 AM   #28
nix
nix's Avatar
Drives: AVO BRZ
ABS is still active in this mode. What it does is disable VSC, TC, Auto LSD. I agree with you though people should be careful!!
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 12:24 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 09:55 AM
