| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
The closest wheel to your measurement (assuming you measured the correct way. See below) is a 5x110 which is a common Saturn, Saab, and a few Pontiacs, but not the Vibe.
Can you confirm this is how you measured? ![]() 4 5/16 = 4.3125. Unfortunately that isn't a correct measurement. These are the two closest to what you're reporting. 5 x 4.33 is 5x110 5 x 4.25 is 5x108 For reference for when you recheck your measurements: 5 x 3.94 = 5x100 5 x 4.25 = 5x108 5 x 4.33 = 5x110 5 x 4.41 = 5x112 5 x 4.50 = 5x114.3
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
| The Following User Says Thank You to deucethemoose For This Useful Post: | Silp3 (01-02-2013) |
#16 | |
I Love custom Turbo kits
Drives: Limited BRZ
#17 | |
C'est la vie Thank you all who have helped me. |
#18 |
Drives: Rx7
A few thing to check
1. BRZ/FRS Hub Bore = 56.1mm 2. BRZ/FRS Bolt Pattern = 5x100 3. BRZ/FRS Lug Nuts Hole = M12 4. Offset should be around 40mm to 50mm, but based on the width of the wheel. I think there is a possibility that the wheel being 6.5 and high 50mm offset, it's hitting the inside suspension. Question 1. Did the wheel goes on the hub and studs but hitting somewhere ? Or it's not even going through the studs ? |
#19 | |
Given that he checked lug distance center to center on the wheel and came up with 4.31, I assumed the wheel didnt fit on to begin with. I too was originally thinking stud size or centerbore.
#20 |
Drives: Rx7
Toyota Matrix are indeed 5x100
| BBK Fitment Database? | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 164 | 02-09-2026 12:48 AM |
| Is this what they mean by panel fitment issues? | ahquit | Issues | Warranty | Recalls / TSB | 7 | 08-21-2012 03:19 PM |
| JDM clear sidemarker fitment issues | D1cker | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-27-2012 03:44 PM |
| Interior Fitment? | PecanSandies | BRZ First-Gen (2012+) — General Topics | 2 | 06-10-2012 07:21 PM |
| Wheel fitment | sfwg | BRZ First-Gen (2012+) — General Topics | 6 | 10-28-2011 06:33 PM |
