#29 |
Drives: Asphalt FR-S
The BRZ version which I have is 3.8/4.5, they are right in between Eibach and Racecomp. Stiffer in the front than most and a bit softer in the back than some.
The FRS version has a softer front spring much like the stock FRS. Some people prefer softer front springs and a heavier front bar. I just went for a 15 minute ride and the ride height on the front seems to have come down a bit. I don't have a perfectly even surface to check. The ride is not bad at all. Still patchy ice and sand on the roads, so no heroic driving. The rear spring is the one with a slight bit a variable rate, the front is linear from what I can tell.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 |
#30 |
So my memory or measurements of "before" the install may be suspect, but the shop documented all the changes. Vorshlag Motorsports will publish an in depth report with lots of details/pictures on the their build blog soon.
What the shop measured from center of wheel to bottom of fender opening: Before / After LF 14.5" / 13.75" RF 14.5" / 13.5" LR 14.5" / 13.5" RR 14.5" / 13.38" So the ride height did drop about an inch. Again, I used the BRZ spring part number not the FRS part. Edit - added a picture after proper alignment With the front Whiteline bolts and rear control arm bushings, this was the best result: -1.25 front camber -2.23 rear camber (a bit more than I would like for daily driver)
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 Last edited by bpracer; 12-29-2012 at 10:17 AM. |
#31 |
Vorshlag Motorsports build thread with my car includes spring rate graphs for stock FRS and BRZ springs and the Swift "BRZ" spring.
http://www.vorshlag.com/forums/showt...7516#post57516
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 Last edited by bpracer; 12-31-2012 at 11:14 PM. Reason: changed link to exact post |
| The Following User Says Thank You to bpracer For This Useful Post: | philstar (01-13-2013) |
| Prototype Swift Springs for FR-S | mines13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 137 | 09-17-2013 09:36 PM |
| StopTech BBK Prototype Install | benjoke | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 03-31-2013 11:31 AM |
| Swift Springs Fitting - SoCal Only | schtebie | Southern California | 16 | 11-29-2012 03:29 PM |
| Installed the Swift Racing Strut Tower Triangulation Bar | mechaghost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 10-10-2012 04:01 PM |
| FS: Swift Motorsports Motorized Plate Holder | kanundrum | Exterior Parts (Aero, Lighting, Etc.) | 4 | 06-12-2012 01:12 AM |
