Old 12-30-2012, 10:39 PM   #71
ScionFrsFan
Since our car requires premium wouldnt we all fall under premium?
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 12-30-2012, 11:45 PM   #72
cruzinbill
Drives: Argento 6spd FR-S
Not really, perhaps someone wants race gas or e85.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
ScionFrsFan (12-30-2012)
Old 12-30-2012, 11:50 PM   #73
ScionFrsFan
does the "stock tune" take away that torque dip?
ScionFrsFan
Old 12-31-2012, 08:24 AM   #74
Dynotronics1
Every ECU that is to get an ECUTek flash, requires a license to be purchased.
ECUTek goes as follows:
ECUTek license ~$250 (one time charge)
ECUTek tune ~$350 (you pay for every time you get a new tune, updates to one same flash are usually free from the tuner)
ECUTek cable (optional) ~$300
Depends on the calibrator/ tuner.
Tune files are in the 125-150 range
Dynotronics1 is offline   Reply With Quote
Old 12-31-2012, 08:28 AM   #75
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Well, I wrote ~$350 being conservative based on Visconti (350) FA20Club (250) Local ECUtek tuner Dynamic turbo (300). Who has an ECUTek flash for 125-150? That is a STEAL!
Old 12-31-2012, 09:30 AM   #76
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Unichip Jack View Post
... without leaving any footprint for the OE dealership to see you’ve been messing around with the car…
Dealer’s looking for “flashed”ECU’s…” While its true dealers probably don’t spend a lot of time looking for flashed ECU’s, every time your car goes in for service, the dealer downloads data from the ECU.
Visconti already went over this in one of his threads (actually, might've trickled into one of the other tuner's threads as well). According to the ECUTek guys, if you reflash back to stock, the dealer has no way of seeing what you've done. The # of OEM writes remain the same. From how it was described, ECUTek uses a different register to keep track of # of ECUTek writes, and the OEM uses its own register to keep track of dealer writes. ECUTek doesn't touch the OEM one. If you don't reflash back to stock and the dealer attempts to read the ECU, they'll run into errors because the ECUTek flash locks everyone else (including OEM) out. They'll either assume it's a faulty ECU and insist on replacing it, or if they're mod-friendly, they'll hopefully ask you to reflash back to stock. Of course, anyone with an ECUTek tune should always reflash back to stock before bringing the car in for service.
This all being said, are you rejecting the ECUTek claim that they leave no footprint when reflashed back to stock? Would love to see some proof one way or the other, as I've always wondered about this myself.
Old 12-31-2012, 09:50 AM   #77
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
The dealer can't tell if you reflash back to stock using their normal diagnostic tools, but there is a way that Subaru (not dealers from my understanding) can tell how many times the ECU has been flashed but they have to be speciffically looking for this.
Old 12-31-2012, 10:10 AM   #78
bakerr6
Drives: 2013 raven black fr-s
To be honest though, they should be able to see if you are running different fuel grades or different oil viscosities anyways, which the majority of people running tunes are probably doing one or both of these things.
bakerr6 is offline   Reply With Quote
Old 12-31-2012, 11:49 AM   #79
Foobar
SLO NO MO
Foobar's Avatar
I thought I saw a poll somewhere on here that showed most of the ECUTek tunes were 91-93 rather than E85. Even if that's the case, I suspect once the FlexFuel kit is widely available, we'll see a lot more ECUTek customers move to E85.
As for oil viscosity, I haven't seen any data. I'm still on stock and don't intend on changing that as I have to deal with northern cold winter climates.
Right, that's what my understanding is as well, but if we're strictly referring to the footprint that the dealer can detect, ECUTek claims to be "clean" so long as you reflash to stock.
Old 12-31-2012, 12:22 PM   #80
jeebus
How do you buy the cable to tune the car yourself? Is it hard?
FYI, before I started tuning my car, I read as much as I could about what was necessary to do so. I suggest this book if you are interested.
[ame="http://www.amazon.com/Engine-Management-Advanced-Greg-Banish/dp/1932494421"]Amazon.com: Engine Management: Advanced Tuning (9781932494426): Greg Banish: Books[/ame]
jeebus is offline   Reply With Quote
The Following 2 Users Say Thank You to jeebus For This Useful Post:
ScionFrsFan (12-31-2012), swift996 (02-02-2013)
Old 12-31-2012, 12:59 PM   #81
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
From
http://www.ft86club.com/forums/showthread.php?t=21715
Originally Posted by FT-86 SpeedFactory View Post
Tune Only
This is a tune only. You need to already own a cable and license or be able to mail in your ECU.
$225
Bolded the important part. I also contacted Jeremy a while back to verify. @FT-86 SpeedFactory if he wants to chime in, but this thread is going off topic.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 12-31-2012, 01:34 PM   #82
Anorax
Drives: '13 BRZ SS
Unichip - The plug and play kit does *not* include the map download cable which is required to get additional maps from your database on to the unichip.
Please confirm, thanks.
Anorax is offline   Reply With Quote
Old 12-31-2012, 01:35 PM   #83
Dynotronics1
Not to hijack, but our Ecutek files are always 125-135.00.
Btw, the unichip is a damn fine unit. We have worked with several over the years on Porsche, and BMW. Good alternative to a factory ecu remap/ re calibration
The Following 4 Users Say Thank You to Dynotronics1 For This Useful Post:
6-Shift (03-18-2013), bakerr6 (12-31-2012), Sportsguy83 (12-31-2012), Unichip Jack (12-31-2012)
Old 12-31-2012, 01:41 PM   #84
Sportsguy83
Drives: Limited BRZ
Originally Posted by seven View Post
The small letters below the bolded part say:
"This is a tune only. You need to already own a cable and license or be able to mail in your ECU."
The mail the ECU part, only replaces the cable. Even if you mail it in, you still need a license.
WoW... Amazing Price. I will search for more info.
END
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
