#253 |
Drives: Some rust bucket
#254 |
#255 |
My VTEC fluid is full
Drives: EFF JAY
How's the engine holding up? Reliable?
#256 |
#257 |
#258 |
#259 | |
Site Moderator
Drives: Stuff
Up front camber using OEM control arms = crash bolts and camber plates. Rear will have more than enough with a reasonable lowering, and the solutions there are obvious. Personally I want to see some adjustable UCAs instead of the LCA solutions.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | ayau (12-28-2012) |
#260 |
Site Moderator
Drives: Stuff
What happened to the engine? Lean and popped?
-Dave
#261 | |
what's the advantage of an ajdustable upper control arm vs lower control arm? |
#262 |
It was actually misfiring (losing charge through the failed seal under load, into the intake manifold...), but we caught it really early, so there was no permanent damage.
However, FHI wanted the engine for teardown, and replaced ours... Only happens when the engine is FULLY heated up (not just the temp gauge in the "normal" spot), and only under 3500 RPM or so. |
#263 | |
My S2000 was supercharged though, so a SC/turbo would definitely be in the BRZ's future, assuming one is extensively tested on the track. Lots to think about, just need to make up my mind. |
#264 | |
Drives: EFF JAY
| The Following User Says Thank You to iLuveKetchup For This Useful Post: | goldenfri (12-28-2012) |
#265 | |
Site Moderator
Drives: Stuff
LCAs will change the track by pulling the wheel inward (slightly, but still), UCAs can just push the top of the wheel back out.
-Dave
#266 |
Hmmm our car was uneven from the factory as well... by 0.4 too. Did you end up evening it out by tolerances or arms?
| FR-S vs S2000 | vang | FR-S / BRZ vs.... | 436 | 09-19-2012 05:52 PM |
| E36 M3 vs FR-S vs S2000 (for me) | RearDrive | FR-S / BRZ vs.... | 48 | 07-02-2012 11:46 PM |
| S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 03:01 AM |
| S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 10:05 PM |
