Old 12-28-2012, 01:09 PM   #1
itdansharpe
itdansharpe's Avatar
Auto Fitment Calculator
Hi all, I've compiled a ton of information floating around on this forum, and used some of my coding experience to pull together a real-time fitment calculator.
The way it works is, it defaults to the stock tire size, and allows you to compare tires. You can also select front or rear fitment.
http://frsproject.magiclabs.io
Feel free to ask questions.
- 1 pixel equals 1 millimeter.
- 1" drop = 2/5mm offset tuck. (f/r)
*UPDATED*
I have added:
- Verification (FT86 Users can now vote!!!!)
- Fender Gap distance.
- Offset From Flush distance.
- Camber
- Wheel Width
- Graphics!
- Comparison Line
- Ability to view: Wheel, Tire, Hub, or Rotor (more accurate version coming soon..)
I'd appreciate anyone confirming these numbers.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 12-28-2012, 01:12 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
Cool. Good job
mashal is offline   Reply With Quote
Old 12-28-2012, 01:17 PM   #3
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
AWESOME JOB! Is there any way to include camber in your calculator? That would really complete it.
Thank you!
GTB/ZR-1 is offline   Reply With Quote
Old 12-28-2012, 01:22 PM   #4
ayau
Drives: Some rust bucket
nice job!
there's one downfall about tire measurements though. a 215 oem tire will have slightly different tread width than a 215 sticky tire. i'm not sure how tire manufacturers choose to measure their tire width.
Old 12-28-2012, 01:30 PM   #5
itdansharpe
Thanks guys. There's definitely room for error, so don't take this as the be all end all. It is purely to get an idea of how different tire sizes, offsets, and ride height relate to the fender.
I'd be happy to try and calculate camber, but would need a good technical source on how to calculate it.
Old 12-28-2012, 01:42 PM   #6
Dezoris
Dezoris's Avatar
Really cool alternative to the miata tire calculator.
Old 12-28-2012, 01:51 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Something's wrong. It shows the outside of a 245/40-17 with stock +48 offset being at the same location as the outside of the stock 215/45-17 on +48. The two should be centered, with the 245 having the outer sidewall 15mm further outboard, and the inner sidewall 15mm further inboard.
Should look like this:
http://www.willtheyfit.com/index.php...&Submit=Submit
Old 12-28-2012, 02:30 PM   #8
itdansharpe
Thanks for the tip. I did recall this during the coding process, but forgot about it after the fact. I've fixed this.
Old 12-28-2012, 02:32 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Kickass
Old 12-28-2012, 04:44 PM   #10
mugen79
mugen79's Avatar
Drives: Ultramarine FRS(MT), IS350(sold)
You are a genius sire!!!!!
mugen79 is offline   Reply With Quote
Old 12-28-2012, 05:06 PM   #11
jeebus
I like it, but it should really have rim width as a factor in there somehow....
jeebus is offline   Reply With Quote
Old 12-28-2012, 05:10 PM   #12
jeebus
also, the fender gap calculation can't be right. I just picked a tire that was 9mm taller in diameter and the fender gap shows 9mm less...shouldn't it be 1/2 that?
Old 12-28-2012, 05:35 PM   #13
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
seven is offline   Reply With Quote
Old 12-29-2012, 04:17 AM   #14
NSV
RWD forever !
NSV's Avatar
Drives: Toyota GT86 SWP
Awesome !
NSV is offline   Reply With Quote
BBK Fitment Database? F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 164 02-09-2026 12:48 AM
Auto Fitment Calculator itdansharpe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-28-2012 01:09 PM
FR-S Speed/RPM Calculator FR-S #2637 Engine, Exhaust, Transmission 8 09-19-2012 11:41 AM
Spring Rate Calculator yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-28-2012 11:31 AM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
