Old 10-24-2012, 04:37 PM   #71
burt
Drives: 2012 Tacoma TRD Sport
TRS carries two different kits for the FRS - Mini H1 projectors or FXR projectors. The FXR is much better in terms of output in my opinion and price is not that much more.
As far as using a different bulb, the relay harness that comes with the retrofit will take care of that. You use one of your existing H11 plugs simply for signal (other not used). The power will be drawn directly from the battery and the harness has new plugs that go to the ballasts that then have wires to the bulb.
Anyone in SoCal that needs help with these, hit me up.
burt is offline   Reply With Quote
Old 10-24-2012, 04:59 PM   #72
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
FXR projectors, really?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-24-2012, 08:36 PM   #73
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yea, they mention it on the front page of their website but Im not seeing the listing itself.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 10-24-2012, 09:39 PM   #74
tonystewart
Terrific, they take a great kit and make it even better
Old 10-26-2012, 03:16 PM   #75
burt
For make sure you get the FXR kit, I would call in to order.
Old 10-26-2012, 03:55 PM   #76
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
damn too late now
retrofitted and installed
Thanks again for this DIY @civicdrivr
The gap bugs me but its really isn't something you see unless you know about it
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following User Says Thank You to Mr.Jay For This Useful Post:
civicdrivr (10-26-2012)
Old 12-25-2012, 06:47 PM   #77
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
The back of my headlight looks nothing like the ones posted in pictures here... I'm stuck with high beams until I can figure out what's wrong. The headlights posted here seem to have some sort of a plastic dome behind the low-beam... mine doesn't have that and I think that's why I'm having trouble. The back of my headlight looks like this:
raul is offline   Reply With Quote
Old 12-25-2012, 07:13 PM   #78
tonystewart
Those look stock to me, you need to modify them to look like the ones in the thread
Old 12-25-2012, 09:04 PM   #79
raul
Lap time enthusiast
raul's Avatar
Ok, but the TRS kit doesn't specify any modifications, nor does it come with parts that look remotely like that.
Old 12-25-2012, 09:54 PM   #80
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The dome is the rubber boot that comes with the kit to cover the rear of the projector after you swap it in. There are two different kits they offer, the base kit and the compete kit. I'm not sure if the base kit includes the boot. The TRS kit requires modifications in order to work.
To answer your other question, the high beam is the reflector based beam (the one on the right of your picture).
Sent via telepathy
Parting out HERE
Old 12-25-2012, 10:01 PM   #81
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Are the FXRs bolt in or do you have to do any cutting to make them fit?
Cade01 is offline   Reply With Quote
Old 12-25-2012, 11:43 PM   #82
raul
Lap time enthusiast
raul's Avatar
Sent via telepathy
There's only 2 options for the retro-quik kit. $150 for brackets and projectors only, and $300 for the complete kit. I bought the latter. My kit came with projectors, brackets, relay, bulbs. I've never heard any mention of that rubber boot in any DIYs or any of the TRS guides in the website. I'll talk to Andrew from TRS tomorrow, something isn't right.
http://www.theretrofitsource.com/pro...roducts_id=254
This kit says specifically that there's little to no cutting needed, and no modifications needed. The only problem is that the instructions supplied are for a Mazda 6.
Old 12-26-2012, 12:57 AM   #83
tonystewart
Everything is right
Old 12-26-2012, 01:25 AM   #84
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Maybe saying "this kit requires modification to work" wasn't the correct thing to say. I was a bit confused with your picture as it's the back of a stock headlight, so by modification, I meant that you need to take the headlamp apart.
The two rubber boots/caps should have been included with your kit.
Parting out HERE
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 08:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 10:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 08:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 07:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 04:16 PM
