Old 12-20-2012, 08:26 AM   #1
_F-R-S_
Drives: 13 whiteout scion frs
Rough start but no tune....
So the temp this moring was around 35 degrees.. And i go to start my car and it wont turn over.. Try it again and the same issue finally on the 3rd attempt it starts roughly.. Then as im about to leave i notice a knocking sound almost like the oil hasnt been changed.. But it has lol so i drive to work and the car is back to normal.. Im just assuming this might be from the cold.. Atleast i hope.. No tune or anything runnin just 93 .. From sunoco
_F-R-S_ is offline   Reply With Quote
Old 12-20-2012, 10:04 AM   #2
gily25
Drives: Silica BRZ 6MT
How much gas was in the tank? Had it been in the 20's the night before? You might consider a fuel additive (or dry gas) but you need to check the manual and some threads here (read: I'm not doing this it's a generic suggestion) if you need to park the car outside and have a long commute before you park it. Or maybe you're already using a fuel additive...in which case you might be adding too much.
gily25 is offline   Reply With Quote
Old 12-20-2012, 11:53 AM   #3
_F-R-S_
Full tank no additive and 34F
Old 12-25-2012, 08:04 AM   #4
be6sti
be6sti's Avatar
Drives: 2013 scion frs
I've noticed this car doesn't like to crank in cold weather.... Is it possible the 0w20 oil is so thin it sort of gels up over a cold night? Or another possibility is that our oem batteries don't have much cca... I've noticed that when its sub 32f and I sit in the car with the engine off but the light and or the radio on for more then 10-15 min that car doesn't like to start right up.
"Fuck it lets go!"
be6sti is offline   Reply With Quote
Old 12-25-2012, 08:06 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thousands if not millions of other cars use 0w20, definitely has nothing to do with 0w20 oil.
Old 12-25-2012, 11:16 AM   #6
J MaM 86
Automotive Technician
J MaM 86's Avatar
Drives: AE92 GTS & Asphalt FR-S 6MT
If anything 0W20 should be better in cold temperatures.
http://www.ft86club.com/forums/image.php?type=sigpic&userid=8787&dateline=1331758  628
J MaM 86 is offline   Reply With Quote
The Following User Says Thank You to J MaM 86 For This Useful Post:
Jesse (12-26-2012)
Old 12-25-2012, 12:50 PM   #7
be6sti
be6sti's Avatar
Then I'm gonna lean toward the battery
"Fuck it lets go!"
Old 12-26-2012, 12:26 AM   #8
mashal
DADA
mashal's Avatar
Drives: 2013
Mine did it for like a week , the tint shop left all the doors open and the lights didn't kill the battery but drained it pretty well. After a week or so it was fine .
mashal is offline   Reply With Quote
Old 12-26-2012, 03:05 AM   #9
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Whew! So I'm not the only one! I've had this happen twice. I pulled out of my garage and drove up the street less than a mile..."REDBOX return mission."
When I got back into my car (stereo on, heater set to LV.1) there was a hesitation. I was like wtf? I believe the outside temp. was 43F to 40F degrees. I'm not digging this at all. I sincerely hope this does not become a trend.
Wolfking is offline   Reply With Quote
Old 12-26-2012, 03:06 AM   #10
OrbitalEllipses
Drives: Attitude
I've had no problems starting in the cold and I'm not far from the OP (my car lives outside as well). The OEM battery is a Group 35 size; it has more than enough CCA.
Old 12-26-2012, 10:39 AM   #11
Opposed
Drives: 2013 Asphalt FR-S
I also have had zero issues with cold starts. And I know cold starts! It was -1 out this morning and if fired up fine. However, When in the single digits, I notice it knocks on start up also. This concerns me being so new.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 12-26-2012, 12:07 PM   #12
Realm
Drives: Scion FR-S
I had problems starting when it first got cold here...
Some post I read said to engage the key first and light up the cluster of warning lights. You will hear many noises, one of which supposedly pumps the gas into the ignition (fuel pump I presume). After 5 seconds or so just continue and start the car. It's never had a problem like before when I did this.
Realm is offline   Reply With Quote
Old 12-26-2012, 12:45 PM   #13
OrbitalEllipses
Drives: Attitude
Turn key to ON, wait several seconds, crank. That is EXACTLY how to prime the fuel pump.
DarkCard (01-05-2013)
Old 12-26-2012, 09:18 PM   #14
be6sti
be6sti's Avatar
I'm not saying the car won't start in the cold. It just takes a bit more effort. Also I've noticed the car misses at high idle while cold.
"Fuck it lets go!"
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
sema rough nixeighty6 BRZ Photos, Videos, Wallpapers, Gallery Forum 0 11-01-2012 04:30 AM
Looks like CEL/Rough Idle is getting a lot more attention. wawro569 Scion FR-S / Toyota 86 GT86 General Forum 11 10-06-2012 12:24 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 10:28 PM
CEL and Rough Idle Issue Autonews.com article Yruyur Issues | Warranty | Recalls / TSB 11 10-04-2012 03:34 PM
