Old 12-20-2012, 02:28 PM   #309
Burrcold
Drives: Subaru BRZ Limited
Mine makes the same noise. I sprayed wd40 a few weeks back and it didn't help. I tried pushing down on the shelf to see if it was loose and nothing. It's really annoying.
Old 12-20-2012, 02:33 PM   #310
Sargy
Long Distance Driver
Sargy's Avatar
mine made this popping/cracking noise for months, then transformed into a different noise, and after a few weeks, it went away all together.
I did absolutely nothing.
Sargy is offline   Reply With Quote
Old 12-20-2012, 03:31 PM   #311
Jayde
Jayde's Avatar
Mine is really only audible when the music is a low or during a low point of a song. But it is really annoying. It's been more pronounced as of late, so I'm hoping it'll go away, like yours. Going to see how the grease worked when I leave for home later today. Might go apply a little more in a bit, since I only applied a very little amount, but what I did apply seemed to work fine.
Jayde is offline   Reply With Quote
Old 12-20-2012, 05:39 PM   #312
Jayde
Jayde's Avatar
Yeah the noise is still there, just not as frequent. It's really quite annoying.
Old 12-20-2012, 05:57 PM   #313
Ben_G
Drives: Blue BRZ
ok...so I don't know if this has been asked, but it's hard to search for this....
Does anyone know if the noise is actually BAD for the car? Like, if you have the noise and you don't have the TSB done, the welds in the area will eventually fail or something crazy like that? if it's just noise, I can live with that...
Ben_G is offline   Reply With Quote
Old 12-20-2012, 06:27 PM   #314
Jayde
Jayde's Avatar
I highly doubt thw noise is bad, or else they would've done a recall. Then again, only time can tell if it'll turn into a problem, but I don't think it will.
Old 12-21-2012, 01:02 PM   #315
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Originally Posted by Jayde View Post
Also, does the top of your rear deck move a lot (area that the third brake light attaches to)? Like I can push on the top of it and it tilts. Easier to lift with seat down, since you can grab it. All the clips are attached and I know the tinter who took it out previous put all 4 tabs back in that make a loud noise.
I just tried it last night. Yes, it moves a lot. I could press it down with only about 5 lbs of force.
Old 12-21-2012, 01:05 PM   #316
Sigh-on-Rice
Here's a vid of the noise before any grease was applied.
Yes, that's the noise! Yours is making the noise more frequently than mine. Is it ok if I put this vid on my first post? I didn't take any vid before I got rid of the noise.
Old 12-21-2012, 01:07 PM   #317
Sigh-on-Rice
I just updated my first post. Can you try spraying WD40 that way instead of spraying into the pocket?
Old 12-21-2012, 01:10 PM   #318
Sigh-on-Rice
I really doubt that this noise does anything bad for the car. It's just the 2 pieces of painted metals rubbing each other making the noise. It only gives you stress and makes you live shorter life.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Rayme (04-04-2013)
Old 12-21-2012, 01:38 PM   #319
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
I would try using a thicker lubricant (motorcycle chain lube worked for me).
TennisHsu is offline   Reply With Quote
Old 12-21-2012, 02:22 PM   #320
Jayde
Jayde's Avatar
That's good to hear that I'm not the only one who has this. Thought something might have got damaged somehow.
You can!
The Following User Says Thank You to Jayde For This Useful Post:
Sigh-on-Rice (12-21-2012)
Old 12-27-2012, 10:25 PM   #321
mact
Drives: 13 GTI
I sprayed some WD-40 in the areas described and the popping is gone!!!
mact is offline   Reply With Quote
The Following User Says Thank You to mact For This Useful Post:
Sigh-on-Rice (12-27-2012)
Old 12-27-2012, 10:34 PM   #322
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
My little fix is still working just fine. Great place to store a putty knife, non invasive and chemical free.
CircuitJerk is offline   Reply With Quote
The Following 5 Users Say Thank You to CircuitJerk For This Useful Post:
fuddbutter (01-07-2013), jpit (05-01-2013), Sigh-on-Rice (12-27-2012), Sportsguy83 (12-28-2012), Subie (12-27-2012)
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
