Old 12-14-2012, 12:27 AM   #127
OrbitalEllipses
Drives: Attitude
Originally Posted by bpracer View Post
Thought the bolt pattern on the rotors were different, i.e not 5x100. I think you need 04 STI fronts and re-drill or buy aftermarket DBA rear rotors with dual pattern.
...and swap the bleeders...
08+ WRX will use 2004 STI fronts and 2008+ rears re-drilled; just the same as this car. All Subarus now have the STI 190mm parking brake so there's no need for conversion rotors (hence 2008 STI re-drilled rotors).
Old 12-20-2012, 05:48 AM   #128
knaa
Drives: FRS
can someone do a DIY for removing the grill on the FRS
knaa is offline   Reply With Quote
Old 12-20-2012, 06:43 AM   #129
alan.chalkley
Drives: 4wd zooks
DIY on how to lift/rotate motor and replace spark plugs. With discussion about the best tools/method and lifting brace.
alan.chalkley is offline   Reply With Quote
Old 12-21-2012, 01:26 PM   #130
CBR600RR
Drives: Raven Black
Originally Posted by Laika View Post
Do you or anyone else still need this? I'm quite a pro at it now. Probably takes about 3-4 minutes max. Getting them back in is actually a wee bit harder.
Anyone planning to a DIY for the stainless steel clutch line? If no one else does I may end up having to do it but I am certainly not the best person for this. Not even top 100.
I would love it if you put one together.
Old 01-07-2013, 09:49 AM   #131
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Anyone know how to completely remove the antenna from the roof? (the mount that is stuck on the roof)
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 01-08-2013, 12:24 AM   #132
RebornS14
RebornS14's Avatar
Drives: S14K
you have to remove the 2 plugs and 22mm nut holding it from the bottom. remove the dome light and you will see it.
RebornS14 is offline   Reply With Quote
The Following User Says Thank You to RebornS14 For This Useful Post:
fuddbutter (01-14-2013)
Old 01-15-2013, 03:45 AM   #133
aymen23q
aymen23q's Avatar
Drives: Pearl White Toyota GT86
can someone put some help on how to change the driving lights
aymen23q is offline   Reply With Quote
Old 01-15-2013, 03:47 AM   #134
Mo707
Mo707's Avatar
+1
Mo707 is offline   Reply With Quote
Old 01-18-2013, 06:20 PM   #135
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Looking to acquire/install a Koyorad performance radiator - anyone install one yet that can provide tips?
Much thanks in advance.
Anthonytpt is offline   Reply With Quote
Old 01-18-2013, 06:35 PM   #136
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Here: http://www.garagefrs.com/koyo-radiator-install/
post_break is offline   Reply With Quote
The Following 2 Users Say Thank You to post_break For This Useful Post:
Anthonytpt (01-23-2013), cobrabyte (01-19-2013)
Old 01-19-2013, 04:20 AM   #137
eckoflyte
Drives: Toyota 86 GTS
Want to remove the dash speaker grill.
Tried looking up a DIY for this (including this forums DIY library) but cant seem to find anything regarding removing the dash speaker grill.
I can't seem to remove it without forcefully wedging a flathead in there and scratching the dash trim. There is no space between the grill and the dash. There does seem to be enough space between the pillar but positioning a tool in there seems awkward.
Do i need a special tool or can someone advise a simple technique for
eckoflyte is offline   Reply With Quote
Old 01-19-2013, 08:09 PM   #138
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
Can anyone post a DYI for the CUSCO Oil Catch Can. It would seem the Instruction Manual is incomplete.
Margovincent_22x is offline   Reply With Quote
The Following User Says Thank You to Margovincent_22x For This Useful Post:
Mo707 (01-20-2013)
Old 01-21-2013, 05:15 PM   #139
SocalBurt
Is there a DIY for the front bumper removal?
SocalBurt is offline   Reply With Quote
Old 01-22-2013, 10:32 PM   #140
Spencer Strayer
Drifter in Progress
Spencer Strayer's Avatar
Drives: 2013 Ultramarine FR-S, MKV GTi
Originally Posted by Dark_Angle View Post
What would you like to see done in the DIY section?
Might be hefty but would really appreciate it... "How to matte vinyl wrap a body"
Spencer Strayer is offline   Reply With Quote
Going to Hermosa Beach this Saturday...Any requests? dookie11 BRZ First-Gen (2012+) — General Topics 97 03-16-2012 06:13 PM
Last second photo requests for TMS debuts? Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 40 11-30-2011 03:13 PM
Speedhunters article KyShro Scion FR-S / Toyota 86 GT86 General Forum 22 09-23-2010 06:09 AM
