Old 12-11-2012, 03:22 PM   #113
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
Originally Posted by Turdinator View Post
@PERRIN_Chris my only concern that I haven't seen addressed anywhere yet is whether the question mark design allows for even cylinder filling. Was this tested? To me it seems possible at higher flow rates one side of the manifold will be getting more air than the other.
I think you may be over thinking this part a bit. If we were talking a whole intake manifold or something crazier, then this would be a concern. If anything our part has a smoother, larger air path to the throttle body, so its going to work better than the stock part to allow the pistons to suck air into the combustion chamber easier. This should make more HP in any setup.
We have dynoed this on a stock car and found almost no difference in HP, but on a Headerback car with an intake system it was worth about 4HP. This part really comes into play when bigger cams are installed and or higher redlines are had.
We will have some dyno results and pictures really soon!
PERRIN_Chris is offline   Reply With Quote
The Following 6 Users Say Thank You to PERRIN_Chris For This Useful Post:
Areddi (12-12-2012), kwood9000 (12-11-2012), ngabdala (12-11-2012), SkAsphalt (12-11-2012), tripjammer (02-25-2013), Turdinator (12-11-2012)
Old 12-11-2012, 10:36 PM   #114
bdi
Drives: 05 STi
People say the darndest things...
bdi is offline   Reply With Quote
Old 12-12-2012, 09:45 AM   #115
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
Thanks. I think this design is exactly what I am looking for in an intake options. Improves airflow slightly, but maintains the stock important elements and locations, and increases engine compartment appearance while deleting sound generator. The price is very fair as well. I figure I'll throw in a high-flow filter and I'll be good to go.
Looking forward to when you guys have this available!
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 12-12-2012, 10:01 AM   #116
BRZ FTW
Drives: 2017 Subaru BRZ
One thing that I don't see addressed(or maybe i'm just misinformed) on any of these intake duct replacement hoses is, does the hose flex under engine load/movement? The stock intake tube had an accordion for a reason. It needed to be able to flex/move under engine load so as not to move the intake box from it's fixed position. How does this replacement intake tube address that issue, or is it not really an issue at all?
BRZ FTW is offline   Reply With Quote
Old 12-12-2012, 10:59 AM   #117
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
Not an issue, it is flexible.
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 12-12-2012, 11:07 AM   #118
PERRIN_Chris
What he said! Silicone can bend so engine movement isn't going to be an issue.
Old 12-12-2012, 11:13 AM   #119
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Accordion is not always for flex many time it's their to prevent collapsing under vaccum. See other hose application than car and anything with outside hose pressure or inside vaccum has accordion. less material for same strength so cheaper to produce than a thick wall tube.
Mars2 is offline   Reply With Quote
The Following User Says Thank You to Mars2 For This Useful Post:
gmookher (12-13-2012)
Old 12-13-2012, 02:13 PM   #120
BRZ FTW
Awesome! Thanks for the responses guys!
Old 12-13-2012, 05:25 PM   #121
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
2-3 weeks as per Perrin "Customer Service 5" when I spoke to him last night.
Someone knows my secret identity
PERRIN_Mladen is offline   Reply With Quote
Old 12-18-2012, 10:16 AM   #122
SpeedmasterBRZ
Drives: Pearl BRZ Limited
Are these available?
SpeedmasterBRZ is offline   Reply With Quote
Old 12-18-2012, 10:19 AM   #123
OrbitalEllipses
Drives: Attitude
Call to order.
SpeedmasterBRZ (12-18-2012)
Old 12-20-2012, 05:08 PM   #124
OrbitalEllipses
Drives: Attitude
Originally Posted by JoeBoxer View Post
It removes the noise generator and they include a cap where it goes in to the firewall. The cap is a lot more substantial than the one that comes with the Dynosty kit, i have both so i will post a comparison photo with the rest of the pics tonight.
To be clear; we're talking about a vacuum cap that goes over the port the rubber hose connects to? That's what I got in my kit.
Old 12-20-2012, 05:13 PM   #125
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Correct, it would go over the little plastic elbow that TRD also sells as sound changers. I took mine out and have my power wire for my amp running through the grommet now.
The Following User Says Thank You to JoeBoxer For This Useful Post:
Anthonytpt (01-16-2013)
Old 12-21-2012, 11:44 AM   #126
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
Great Idea! That is a great pass through!
PERRIN_Jeff is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Jeff For This Useful Post:
JoeBoxer (12-21-2012)
Zeta Performance - Silicone Intake Pipings & Drop-in Replacement Air Filters ZetaPerformance Engine, Exhaust, Transmission 95 11-05-2014 07:42 PM
Maxracing dynamic intake duct Mars2 Engine, Exhaust, Transmission 123 09-23-2014 08:39 PM
AVO Silicone Intake and Sound Tube install and review ESC POD Engine, Exhaust, Transmission 38 05-21-2013 07:18 AM
Zeta Performance - Silicone Intake Pipings & Drop-in Replacement Air Filters ZetaPerformance Engine, Exhaust, Bolt-Ons 41 05-13-2013 02:00 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 04:58 PM
