Old 12-16-2012, 08:25 AM   #2353
BRZnut
Drives: BRZ DGM Limited
Originally Posted by hankster View Post
Yup, started noticing in the past month or two (had it about 5.5 months) that when I come to a quick stop rpms drop to 400-500 then bounces right back up to 600-700. Doesn't seem to happen with more gradual stops.
Hope it's not a sign of problems to come. I'm kind of dreading my first oil change.
I've continued to notice it but no rough idle since it always stays at 500 and above.
Yesterday I was driving in manual mode (have the auto) and I down shifted & the idle jumped to 3800 RPM, then I hit the brakes and came to a full stop...idle over shot the 700 rpm (mine idles at 650-700 now) went to 500 and quicklly back to 700. Weird
Thankfully, no stalls and no Cels, yet!
Old 12-17-2012, 07:02 PM   #2354
TurnOne
Drives: BRZ Ltd. WR Blue 6MT
I've got good luck and bad luck. My FR-S was bought back by the dealer. I'm #34 on the list. I bought a BRZ Limited and it was running perfectly until today. A couple of idle drops then it gave me the dreaded CEL. I just reset. We shall see what it is when it comes back. I'm too busy tomorrow to drop at the dealer. But Wednesday. 6500 miles (1500 after oil change) VIN 6034**
So, have Toyota and Subaru figured this out yet?
Chris
TurnOne is offline   Reply With Quote
The Following User Says Thank You to TurnOne For This Useful Post:
eurospeed (12-17-2012)
Old 12-17-2012, 07:46 PM   #2355
Yruyur
Yruyur's Avatar
Chris
That sucks man. Good luck.
Sent from my flux capacitor using Taptalk
Old 12-17-2012, 07:53 PM   #2356
BRZnut
Chris
If your VIN is in the 6034** range then you may need a ECU flash or replacment to correct the idle/Cam issue. Dealer should know
Old 12-17-2012, 08:55 PM   #2357
traybelles
Drives: GT86
GT86
Yesterday had my 86 back at the dealers workshop and was fitted with modified ECU. Looks like problem solved, fingers crossed
Just an update 20/2/2013) car running beautifully since modified ECU fitted. Finally have my dream car Love it so much!
traybelles is offline   Reply With Quote
The Following User Says Thank You to traybelles For This Useful Post:
Old 12-18-2012, 10:22 AM   #2358
FT86Dubai
FT86Dubai's Avatar
Drives: 2013 Toyota 86
I should have received my car today but, they said that the new ECU did not arrive yet. However, it should be installed by this Thursday.
2013 Toyota 86 (Sold it and regretting)
FT86Dubai is offline   Reply With Quote
Old 12-18-2012, 11:27 AM   #2359
Red Shift
Drives: Blue BRZ
Red Shift reporting in on CEL problem #204 on the list:
They replaced the ECU and returned the car to me on Friday Dec 14. It has run beautifully since then (150 miles, 4 days). They estimated 3-4 weeks but got it done in less than 2. I'll wait a few more weeks before scheduling the party, but it's really promising. I hope they've figured this thing out. It would be terrible if all the great word-of-mouth publicity gets cancelled by reliability issues. Thanks for maintaining this thread. It was a real help to have a source of information.
Red Shift is offline   Reply With Quote
The Following User Says Thank You to Red Shift For This Useful Post:
eurospeed (12-27-2012)
Old 12-18-2012, 10:47 PM   #2360
fender2819
Drives: Scion fr-s
Had my car in the shop one day on 12/17. They just had the ECU re flashed for the check engine light. Everything seems to be ok besides it being down on power and a crappy throttle response. I'm assuming it'll get better after I put some more miles on it?
Why are some people getting their ECU's replaced and others getting a reflash for the fr-s? Does it just depend on your VIN? I read through most of this thread and i don't seem too confident in this re flash working out. Love the car but maybe I should of stuck with honda! Eh, first year problems...
fender2819 is offline   Reply With Quote
The Following User Says Thank You to fender2819 For This Useful Post:
Old 12-19-2012, 11:21 AM   #2361
ebphoto
Drives: FR-S, NA8, S13
Originally Posted by ebphoto View Post
have had the hunting idle issue for a while now.
have had the car stutter and instantly stall twice.
car stuttered today after spirited driving. once it was turned back on the CEL was on with the slip light on as well.
ebphoto, FR-S, ~7700mi, FL
code p0017
dealership is supposed to get the ECM today and replace it and i should have my vehicle back.... hopefully the issue is gone.
ebphoto is offline   Reply With Quote
Old 12-19-2012, 11:36 AM   #2362
Alienate
Drives: 2013 Scion FRS
I had my ECU reflashed and it was/is NOT down on power, nor does it have crappy response. I don't believe it will magically get better. Good Luck getting it back to the way it was.
Scionara to you
Alienate is offline   Reply With Quote
Old 12-20-2012, 01:06 PM   #2363
ebphoto
Originally Posted by eurospeed View Post
210. ebphoto, FR-S, 7700mi, FL
replaced ecu. power is back and no cel on as of yet.
took 2.5 days including them removing the crickets.
The Following User Says Thank You to ebphoto For This Useful Post:
Old 12-20-2012, 10:07 PM   #2364
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
tuckdaddy number 209 on the list and have an update: cam gears came in yesterday and am getting the car back hopefully before new years with the holidays.
tuckdaddy is offline   Reply With Quote
Old 12-20-2012, 11:19 PM   #2365
traybelles
Drives: GT86
5th day of driving car with modified ECU. Runs beautifully. Workshop/Dealer only had car for 2 hours and were very open to my thoughts and ideas (thanks to this forum site) about replacing ECU. Feel like I have a brand new car again
Old 12-21-2012, 02:23 AM   #2366
FT86Dubai
FT86Dubai's Avatar
Exclamation
Seeing that there are different approaches of repairing the CEL/SL/Idle issue
1. Cam gear sprocket replacement
2. ECU replacement
3. ECU reflash
Isn't it now possible to create different lists containing the production dates of vehicles and the fix required. Or is that just depending on dealership experiences?
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
