Old 11-30-2012, 04:03 AM   #43
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Originally Posted by Dezoris View Post
I plan on SC in spring so when I get around to it will update this if someone does not beat me to it.
Im planning to get one one jan or feb, but i dont have the mechanical know-how to place which hose to where. well, i'll just ask around if ever.
JackSmiley is offline   Reply With Quote
Old 12-03-2012, 06:31 PM   #44
Dezoris
Dezoris's Avatar
Can 3/4 Full at 3000 Miles:
Old 12-03-2012, 10:49 PM   #45
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
It's been a while, but I'd like to return to post some of my install photos from the catch can. Thanks @Dezoris for the guide. Worked a charm.
Product Shot
20121106-RadiumCatchCan-01 by VictorN07, on Flickr
Dipstick to check your levels
20121106-RadiumCatchCan-02 by VictorN07, on Flickr
The atomic cutout was a nice touch
20121106-RadiumCatchCan-03 by VictorN07, on Flickr
The smaller barb as listed in the guide. 0.425". Well made and has the o-ring to seal. Inlet from the PCV valve.
20121106-RadiumCatchCan-04 by VictorN07, on Flickr
20121106-RadiumCatchCan-05 by VictorN07, on Flickr
20121106-RadiumCatchCan-06 by VictorN07, on Flickr
The larger barb as listed in the guide. 0.5". Outlet to the intake manifold
20121106-RadiumCatchCan-07 by VictorN07, on Flickr
This is where I differed from the guide. Saw D3PE's design for the mount of the catch can and decided to borrow that. I would make a L bracket that wedges underneath the battery. This picture is the battery removed. Discovered it sat on the tray
20121110-RadiumCatchCan-08 by VictorN07, on Flickr
Here is the plastic tray the battery sits on
20121110-RadiumCatchCan-09 by VictorN07, on Flickr
Bummer. The tray has nipples that slot into the holes shown a few pictures above. Keeps the battery from sliding about. Time to bust out the cutter
20121110-RadiumCatchCan-10 by VictorN07, on Flickr
Here is the bracket I fabbed. Bent a 6x18" piece of steel 90 degrees and painted it with rustoleum to prevent rust. I wanted aluminium but derped at the store. Drilled out holes for the battery tray and catch can. I did leave room in case I wanted to go dual catch can
20121110-RadiumCatchCan-11 by VictorN07, on Flickr
Lined the bottom with pipe insulation tape to prevent scratching of the painted surface this will sit in
20121110-RadiumCatchCan-12 by VictorN07, on Flickr
20121110-RadiumCatchCan-13 by VictorN07, on Flickr
My dad found some hardware to mount the can to the bracket. Good times with the old man.
20121110-RadiumCatchCan-14 by VictorN07, on Flickr
20121110-RadiumCatchCan-15 by VictorN07, on Flickr
Everything ready to go. Used 3 of the stainless filters as suggested in the guide
20121110-RadiumCatchCan-16 by VictorN07, on Flickr
Rather than use PCV hose, I used more sturdy transmission hose. Rated for 250 psi vs 50 psi of PCV hose. Just peace of mind for me.
20121110-RadiumCatchCan-17 by VictorN07, on Flickr
Good shot of the smaller 11/32" transmission hose hooked up to the PCV valve on the rear of the engine. Used a hose clamp for security.
20121110-RadiumCatchCan-18 by VictorN07, on Flickr
The larger 1/2" Transmission hose goes on the intake manifold. They only had red so I rolled with that.
20121110-RadiumCatchCan-19 by VictorN07, on Flickr
Shot of the can installed under the battery.
20121110-RadiumCatchCan-20 by VictorN07, on Flickr
Finished
20121110-RadiumCatchCan-22 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 12-03-2012, 10:57 PM   #46
F1point4
Photo Specialist
F1point4's Avatar
@Dezoris, with respect I am concerned for your engine. I've had my can on for about 2500 miles and have caught less than a teaspoon of oil (I have 7000 mi as of this writing). I'm happy we are both catching oil, however you seem to have an alarming amount.
May I ask what kind of driving conditions you put your car through?
Old 12-03-2012, 11:11 PM   #47
Dezoris
Dezoris's Avatar
Very very hard driving. How many screens did you install?
Great pictures and mounting solution, looks very well done and also super easy to empty. How do you like the quality?
Old 12-03-2012, 11:20 PM   #48
F1point4
Photo Specialist
F1point4's Avatar
I put in 3 screens as you suggested. I guess I don't drive it as hard as you. 95% of the time I keep it under 4.5k RPM.
Thanks! I can't really fit both hands in there to unscrew, but there is plenty of room to get one in there to unscrew. Just have to go slow so I don't drop it on the exhaust.
As for quality, I understand why the Lotus people like Radium so much. This bit is good kit.
Old 12-03-2012, 11:41 PM   #49
Dezoris
Dezoris's Avatar
I had a track day on it as well, and did not empty after.
Keep the post updated when you empty the can after a longer period.
Radium is hard core, I wish that RLS (Really Light Stuff) had parts for the FRS/BRZ their Lotus parts are off the charts.
Old 12-15-2012, 07:34 PM   #50
Supermassive
Supermassive's Avatar
Thank you guys so much for bringing this kit to my attention, I'm going with the dual can setup since my turbo arrives next week and after seeing the amount of oil this thing actually catches, I have a feeling that it will be worth it's weight in gold.
Supermassive is offline   Reply With Quote
Old 12-17-2012, 05:19 PM   #51
Dezoris
Dezoris's Avatar
Before asking further questions please review the following technical article by Toyota on the purpose of PCV systems:
http://www.ft86club.com/forums/attac...3&d=1355781670
Old 12-17-2012, 06:00 PM   #52
OrbitalEllipses
Drives: Attitude
No shit? Wow.
Old 12-17-2012, 06:11 PM   #53
Dezoris
Dezoris's Avatar
No shit? Wow.
Keep in mind I had a track day on that.
Old 12-17-2012, 07:03 PM   #54
OrbitalEllipses
Drives: Attitude
Gotcha.
The 90 degree 2pc, is that the 3/8" one Radium sells as an option for their can or one you had laying around?
Old 12-17-2012, 07:40 PM   #55
Calum
That Guy
Drives: 2013 asphalt FRS MT
1. Full Throttle and high RPM = Lower Intake Manifold Vacuum, High Engine Blow By.
[/B]In this condition the PCV Valve is forced full open. If there is too much blow by then the breather hose will also be used to vent into the intake hose. This will only occur under high load situations.[/FONT] [FONT=Century Gothic]
2. Lower Throttle, Cruising = Moderate Intake Manifold Pressure, Lower Blow By.
In this condition PCV Valve is half open
3. Idle or De-Acceleration = High Intake Manifold Pressure, very low blow by.
In this condition the PCV valve is virtually closed.[COLOR=#ff0000][SIZE=3]
Awesome right up, thanks.
You should replace pressure with vacuum.
Old 12-20-2012, 12:28 AM   #56
Dezoris
Dezoris's Avatar
Gotcha.
I had to email and request this one:
90 Degree 2 Piece 0.425"
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 05:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 06:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-02-2012 11:11 PM
