Old 12-14-2012, 06:33 PM   #85
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Originally Posted by subiestar View Post
After reading a few sources, they all claim 12.0v is 25% battery charge. And 11.8v is 0% charge. But then cars can normally crank as low as 10v.
I was gonna return my PMP, but now I think I'll keep.
BTW, if anybody is looking for Power Magic Pro with a lower voltage cut-off. Newegg has one with 11.6v, 11.8v, 22.8v, and 23.2v settings.
I've set mine at 12V... For a new battery it should be good enough... Unless you are planning to leave it on while parked for a long long time.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-17-2012, 09:29 AM   #86
atledreier
Drives: GT86 DGM
So, is there any rason NOT to go direct to the battery (through a fuse) for the hot lead, and get the accessory lead from the outlet in the glovebox? That would keep the entire installation away from the fusebox and ECU area.
atledreier is offline   Reply With Quote
Old 12-17-2012, 09:37 AM   #87
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
If we go directly to the battery (assuming there is no PMP) then the camera will continue to draw from the battery. At some point the car won't start anymore. If no fuse is used, then connecting to the battery is a fire hazard.
F1point4 is offline   Reply With Quote
Old 12-17-2012, 10:14 AM   #88
DaJo
FT86Club Vancouver
DaJo's Avatar
If no fuse is used, you risk damage (fry) to the BlackVue device from the amperage spike.
Don't risk it with a $200+ camera...
Bridge it through the fuse on the opposite side of the live wire via the fusebox; or get some "Add-A-Circuit".
2000 MR-S 5MT
2010-2012
Old 12-17-2012, 11:16 AM   #89
atledreier
Drives: GT86 DGM
I mean through an inline fuse on the hot wire of course. My way we wouldn't have to go into the fuse box at all.
Old 12-17-2012, 11:25 AM   #90
DaJo
FT86Club Vancouver
DaJo's Avatar
It'll work; just that some of us rather not splice into the factory lines for easy removal.
2000 MR-S 5MT
2010-2012
Old 12-17-2012, 12:09 PM   #91
atledreier
Drives: GT86 DGM
Same here, I was just suggesting an alternative for those reluctant to go near the fuse box or ecu for warranty purposes.
Old 12-23-2012, 08:12 PM   #92
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Thanks F1point4 for the install guide. I got mine all wired in today and set up. Looks great and seems to be working. I need to mess around with parking mode sensitivity, and maybe work on stealth of the camera, but so far I'm happy with the end result.
I have one question and I haven't been able to find anything out about this online. The camera records in dates from April 2011. I have no idea how to update this. I've already updated settings and time zone on the configuration but the camera is still stuck in the wrong date. Does anyone know how to set it to the correct date/time so my recordings are actually correct?
thorlius is offline   Reply With Quote
Old 12-23-2012, 11:58 PM   #93
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Doesn't it just use the GPS date/time for that? Has it gotten a good GPS fix yet?
b.e is offline   Reply With Quote
Old 12-24-2012, 05:50 PM   #94
thorlius
Canadian
That would make sense. One of my test videos had the right location data when I checked on the laptop after, but it was in a garage at the time.
Old 12-24-2012, 06:02 PM   #95
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Some of the empty/open slots on our fuse boxes are hot slots (always powered) so you don't have to tap into your brake light fuse.
Another fun reason for a dash cam:
[ame="www.youtube.com/watch?v=66Va1t7OF1U"]Lightning caught on my DashCam - YouTube[/ame]
PRO86 | WTCC | STL
Old 12-26-2012, 01:56 AM   #96
sc0urge
sc0urge's Avatar
Drives: 2013 BRZ CBS
Thanks for creating the excellent guide, F1point4! Very thorough, informative, and complete with pictures. Like someone mentioned earlier, it really helps with those (like me) who are unfamiliar with the car wiring/electronics.
I was actually looking into the GoPro cameras for internal and the occasional external mounting, but given the benefits of having a hard-wired dashcam, a Blackvue seems more logical for my needs. Again, thanks for the write-up.
sc0urge is offline   Reply With Quote
The Following User Says Thank You to sc0urge For This Useful Post:
F1point4 (01-07-2013)
Old 01-07-2013, 09:44 PM   #97
F1point4
Photo Specialist
F1point4's Avatar
Another Gem:
Person decides to jump out into the open lane when the light is green just to get ahead. Demonstrates the suspension work i've been doing
[ame="http://www.youtube.com/watch?v=T8xDuqVytjw"]Near Miss.mp4 - YouTube[/ame]
Old 01-07-2013, 10:58 PM   #98
thorlius
Canadian
Originally Posted by F1point4 View Post
Another Gem:
I hate when it happens so fast you don't even have time to get mad at the dumbasses. By the time you want to lay on the horn or flip the bird, you're already way off in the distance.
blackvue, dashcam, diy, dr400g-hd, power magic pro
Dash Cam Installation (BlackVue DR400G-HD) DarrenDriven DIY (Do-It-Yourself) Guides 93 05-01-2018 09:54 PM
R-Magic & Rasty build 86 toxicdrift FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 08-10-2012 12:24 AM
R Magic Parts List quik1987 Engine, Exhaust, Transmission 9 07-30-2012 01:55 PM
R-Magic Demo Car (Exhaust video too!) ttknf Engine, Exhaust, Transmission 5 06-06-2012 02:20 AM
