Old 11-26-2012, 10:07 PM   #15
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
Originally Posted by JoeBoxer View Post
Amazon has a good price on them, i got Gorilla ones for $9.
I found some cheap ones on eBay. The PF01 has a 75mm bore and gorilla doesn't make that size. The aluminum ones were $12 each so I passed for now. Ill keep looking around.
fender9530 is offline   Reply With Quote
Old 11-26-2012, 10:16 PM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Never seen a 75mm bore, might check with TireRack they should have them since they sell PF01's.
Old 12-09-2012, 02:13 AM   #17
NickFRS
Drives: 2013 Asphalt FRS
Sorry guys car has been in the shop for 3 months. Yes they are hub cent. They are ebachi. Car is coming back monday from the shop and coils are FINALY going on Sat. Not today but next Sat.... Can't wait.
NickFRS is offline   Reply With Quote
Old 12-09-2012, 11:07 AM   #18
_F-R-S_
Drives: 13 whiteout scion frs
Side shots
_F-R-S_ is offline   Reply With Quote
Old 12-10-2012, 03:35 AM   #19
NickFRS
Get the car back in 10ish hours. I'll get some shots for you guys.
The Following User Says Thank You to NickFRS For This Useful Post:
ShoShin (12-10-2012)
Old 12-11-2012, 02:50 AM   #20
NickFRS
Got the car back with more problems then when it went to the body shop..... If I shift from 1st to 2nd at redline my tranny shakes horribly.... my trunk button doesn't even work.... and they never fixed my steering wheel..... i'm pissed... but I have the car back in my possession. I'll snap some pictures tomorrow of side shots and hopefully have coils on soon.
Old 12-11-2012, 11:19 AM   #21
fender9530
fender9530's Avatar
Nick, Where did you get spacers? Did you need anything else to run them?
Thanks!
Old 12-12-2012, 08:59 PM   #22
NickFRS
I ordered the spacers from PRE racing in Oregon. They are a big Subaru Performance shop over here. Been busy between shuffling the car around back to the body shop and to the dealership to make sure everything is okay with the car and work. Uploading those pictures on Friday when I get off and can finally relax and have the car back.
Old 12-17-2012, 09:55 AM   #23
ft_sjo
Drives: GT86
Did you have to use the spacers for clearance? Or did you try and fit the wheels without spacers and have no issues?
Old 12-17-2012, 10:17 AM   #24
NickFRS
Uploading picks of drop after coilovers! No spacers required. I used spacers in rear to flush out the wide body rear end. Looks great. Wheels deff clear brakes fine.
Old 12-17-2012, 10:18 AM   #25
NickFRS
I'll get some higher res pictures soon @Darren took these
Old 12-17-2012, 10:19 AM   #26
ft_sjo
Drives: GT86
Thanks Nick. I want to retain as close to OEM offset as possible for handling reasons. Just need to ensure that there is adequate clearance around the suspension components and arches. If you have any photos of those areas you could share that'd be great!
Old 12-17-2012, 10:32 AM   #27
NickFRS
This weekend i'll be changing my ride height a bit so i'll take loads of photos. Everything clears perfectly and I can fit my fingers in my fenders atm! This is also a good close to stock upgrade if you look at my math. basically the same weight just some more contact patch with the slightly wider rim/tire plus a way better look!
P.s car handles amazing now! No body roll! I'm almost debating not upgrading sway bars but I may get the Perrin front n rear just for kicks n giggles.
Old 12-18-2012, 03:19 AM   #28
ft_sjo
Drives: GT86
Hm.. I wonder if I could get away with a 245/40!
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 02:00 AM
Wheel Directory: Enkei PF01 17x7.5 +38 FRSFirestorm Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-19-2017 10:36 PM
Wheel Directory: Enkei RS+M 17x8.0 +35 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 02-12-2014 04:26 PM
Wheel Directory: Enkei Kojin 17x8 +45 abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-29-2013 04:24 PM
Wheel Directory: Enkei GP5 17x8 +45 Books Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-09-2013 03:46 PM
