Old 12-16-2012, 12:58 AM   #43
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by serialk11r View Post
Whoa whoa whoa, you have ethanol free 94? Blend it up to 10% (or even 20%) ethanol and get some ~96!
yeah we have ethanol free 94. i prefer not to have ethanol in my gas. unless i'm running boost and i'd rather run 30% toluene and get ~102 octane.
FreshFRS is offline   Reply With Quote
Old 12-16-2012, 09:12 AM   #44
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by subatoy View Post
I've been wondering this for a while now so I would like to hear an answer from the experts.
It has been said many times that high compression ratios are not good for boost but when you lower the compression then you have to run more boost to achieve the same power so whats the advantage of a lower compression?
Lets say you have the a 2.0 engine with 12.5:1 compression ratio and you run 5 psi and you achieve 250whp.
Then you take the same engine an lower the compression ratio to lets say 9.5:1 but you now have to run 10-12 psi to achiave the same 250 whp.
It seems like the strain you are causing to the engine is still the same so why not just stay with the high compression with lower boost?
all the numbers I used ARE NOT accurate i'm just using an example.
at sea level
air is at 1 bar at sea level = 14.5 psi
+5 psi = 20.5 psi + 12.5:1 compression = 256.25 psi after compression
256.25 / 10.5:1 compression = 24.4 psi - 14.5 (1 bar) = 9.9 psi
so.... at 12.5:1 compression you would need to run 9.9, so pretty much twice the psi to make the same power BUT heres the other factor, when you lower compression you INCREASE the amount of volume you can compress in the cylinder, = more air = more fuel can be used = more power
so with the same gas
12.5:1 + 5psi of boost = 250whp
10.5:1 + 8.5 psi = 250whp because you can use more gas
another advantage of using lower compression is there is less heat involved in the actual compressing processes, which means cooler combustion chamber temps before the spark...
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following User Says Thank You to carbonBLUE For This Useful Post:
subatoy (12-16-2012)
Old 12-16-2012, 11:04 AM   #45
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by carbonBLUE View Post
at sea level
This is awesome but my concern is Torque, not whp, so my question is if there's a way to calculate/estimate torque based on compression ratio differences and what we know about this car.
subatoy is offline   Reply With Quote
Old 12-16-2012, 11:11 AM   #46
carbonBLUE
Reverse Burnouts
I'm not sure, you would have more tq but not by much, best way to get tq is modifying bore and stroke
If it were up to me, i would increase bore and stroke but keep compression
(wont forget you)
2011 Infiniti G37x
Old 12-16-2012, 12:22 PM   #47
gmookher
try a different r&p ... for high TQ early on in the power band you want a turbo
Im not sure why you would want that type of power curve
Old 12-16-2012, 01:28 PM   #48
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Driving > 4500 rpm into redline is the best feeling ever.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 12-16-2012, 01:59 PM   #49
subatoy
subatoy's Avatar
Drives: subatoy
usable real world power, I don't want to need to down shift 2-3 gears just to get ahead on the highway.
I come from a WRX and GTI background which both have great instant torque, I also owned an integra GSR and 370z and I just couldn't live with them.
Old 12-16-2012, 03:35 PM   #50
gmookher
This is why I am supercharging!
The Following User Says Thank You to gmookher For This Useful Post:
ngabdala (12-16-2012)
Old 12-16-2012, 07:39 PM   #51
cf6mech
Drives: FRS Silver LS1 swapped.
Seems silly to me to dwell on torque from a four cylinder that lives for high revs to make HP,..... but my prior cars were 07 Shelby Mustang and then a Boss 302,.....
cf6mech is offline   Reply With Quote
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
Mr.Jay (12-17-2012), ngabdala (12-16-2012)
Old 12-16-2012, 08:40 PM   #52
carbonBLUE
Reverse Burnouts
Well tq wins races, but weighing 1000 lbs less you only need 3/4 ths of the tq to create the same propulsion, so a turbo kit with 300 tq is just as good as a car 1/4 th more heavy that has 400 tq
(wont forget you)
2011 Infiniti G37x
Old 12-16-2012, 08:47 PM   #53
ngabdala
Old 12-16-2012, 10:44 PM   #54
serialk11r
Drives: '06 AM V8V Coupe
Then you need a positive displacement blower. A low end focused turbo sucks balls IMO, you don't have high end power, efficiency is not great, and response can never be as good as a supercharger. Positive displacement blower can be thought of as roughly having the effect of adding more displacement.
Remember boost pressure only means something in the context of temperature. What matters is intake air density and quantity. Torque is roughly how much air mass the engine takes in per revolution, ignoring efficiency changes. 1 bar boost, room temperature is double the air, and thus double the torque, approximately.
As far as efficiency goes, at higher charge density, the engine sees more friction but typically less as a proportion of power, more energy lost to exhaust as a proportion of power, more energy lost to coolant as a proportion of power, more efficient combustion, possible lost efficiency due to changes in tuning needed to accomodate the boost, and various other factors. The balance between these determines how efficiency changes.
Old 12-17-2012, 12:12 AM   #55
cf6mech
I love torque,....just being realistic about the capabilities of this engine and concentrating on it's attributes and not its inherant weaknesses.
Old 12-17-2012, 12:28 AM   #56
cf6mech
Well tq wins races,
Consider Formula One engines,....light cars granted,.....but so is the FT86 in the scheme of things. F1 engines develop very little torque but high horsepower.
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Turbo FR-S Mino Engine, Exhaust, Transmission 24 12-16-2011 08:42 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
turbo yes BMWDAD BRZ First-Gen (2012+) — General Topics 79 12-06-2011 12:58 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
