Old 12-13-2012, 06:16 PM   #113
gmookher
Money in hand...cant pull out my pillars till I get my car back..
Old 12-15-2012, 01:23 AM   #114
root
Drives: Raven FR-S
Originally Posted by PrimeMotoring View Post
By the way if you or anyone is interested I may be producing these kits, however at the moment they will have to be hand made by myself. It was an experiment that came out I think awesome so we may get these injection molded and mass produced to shorten time and lower price for the customer.
If you produce replacement parts so we can keep the originals in case ever want to go back, I'm definitely in! This is the nicest setup so far! Honestly, this car really should have come from the factory with more gauges.
root is offline   Reply With Quote
Old 12-15-2012, 01:56 AM   #115
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Nailed the cluster design!!! I'd even say a button relocation package would be a hit too if its necessary to mount the new cluster piece...
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 12-15-2012, 08:39 PM   #116
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Tough thing is that the brz has that panel used up already for the headlight leveling. I have to figure out a spot I can move it to elsewhere in the car but most likely it would need a harness extension.
PrimeMotoring is offline   Reply With Quote
Old 12-16-2012, 12:42 AM   #117
getbent
Drives: 2013 FR-S Blue MT
You should definitely consider making two versions, one with gauge pods on both sides and another with just the right side. I personally would rather keep the buttons where they are and use a multifunction gauge on the right side of the cluster.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
The Following 2 Users Say Thank You to getbent For This Useful Post:
shiro (08-26-2013), Sportsguy83 (12-16-2012)
Old 12-16-2012, 09:49 AM   #118
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
This will also be very popular, I would lean towards this too.
Old 12-16-2012, 01:05 PM   #119
Turbowned
Turbowned's Avatar
Heres my solution to relocating the buttons from the cluster
That's brilliant!
Old 12-16-2012, 01:16 PM   #120
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Yeah id defiantly go with 2 gauges on the pillar and then the single on the right hand side of the gauge cluster.
Tansey86 is offline   Reply With Quote
Old 12-16-2012, 02:42 PM   #121
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
One of the manufactures on here had gauges you could mount on the steering wheel, maybe it was perrin. The name escapes me.
Exhaust is offline   Reply With Quote
Old 12-16-2012, 04:49 PM   #122
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Definitely interested in the single gauge option!
kmbkk is offline   Reply With Quote
Old 12-16-2012, 05:03 PM   #123
Supermassive
Supermassive's Avatar
I'm all for dual gauge, pillar pods look chintzy, and scream "racer boi" to cops when you're pulled over. The dual gauge surround is perfect because it's stealthy, the gauges are right in line of sight and in my case with the AEM Truboost gauge i can easily reach it to adjust my boost pressure...
Supermassive is offline   Reply With Quote
Old 12-16-2012, 05:59 PM   #124
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
If I go with this, I'm in for the single gauge option, using an AEM Failsafe gauge.
The Following 2 Users Say Thank You to kmbkk For This Useful Post:
Old 12-16-2012, 06:09 PM   #125
Sportsguy83
Drives: Limited BRZ
^^ This!
Old 12-16-2012, 06:17 PM   #126
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
^^ This!
Let me know if you want one of the AEM gauges. I can talk to my shop in Miami to see what kind of deal I can get.
The Following User Says Thank You to kmbkk For This Useful Post:
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 07:19 PM
Gas Gauge Issue Jruex22 Scion FR-S / Toyota 86 GT86 General Forum 12 04-04-2013 11:28 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
