#15 | |
Drives: '06 AM V8V Coupe
The heads and the direct injection are designed together for low end, if this involves more modification than replacing some components (aka, changing the ports) the low rpm behavior could really suffer. If it's just lighter valves, stiffer springs, bigger cams, shouldn't be too big of a deal. The cam phasing has a pretty wide range to deal with fat cams (if you add like 60 degrees duration on the intake though the idle is probably going to suck no matter what magic Toyota says direct injection can do with EGR, but if it's more modest like 30 degrees maybe not). Power peak at 9000rpm and E85 could hit 300hp. |
| The Following 2 Users Say Thank You to serialk11r For This Useful Post: | FA5 (02-09-2013), TouchMyHonda (12-15-2012) |
#16 |
Drives: Sonic Blue 86GT Manual
would be a shitload of fun despite my expectations of the costs involved
#17 |
Toyota Soul
Drives: 96 taco
Im pretty sure its gona cost way more to do the n/a high hp road, than to go with a simple bolt-on tc/sc kit...
No replacement for Displacement??? Tell that to the people with a 2JZ.
#18 |
DADA
Drives: 2013
He didn't just say 300 Hp NA !!!
I-Tapatalk |
#19 |
Vtec Jesus
Nothing is more fun that high revving, large NA Hp. You can't comparing it to boost.
| The Following User Says Thank You to TouchMyHonda For This Useful Post: | eljefe (12-27-2012) |
#20 |
wheel gap
Drives: whiteout frs, 04 xrs
if i can get 250+ whp N/A with a mild build, way worth it
| The Following User Says Thank You to Jesse For This Useful Post: | czar07 (12-14-2012) |
#21 |
Drives: Supercharged Saturn ION
good stuff, now you just need a solid cam option
| The Following User Says Thank You to NJA For This Useful Post: | TouchMyHonda (12-14-2012) |
#22 |
Administrator
Drives: Boxster 986
Thread cleaned up. Please keep it on topic and stay away from the NA vs. FI arguments.
| The Following 4 Users Say Thank You to Hachiroku For This Useful Post: |
#23 |
Drives: subatoy
#24 |
Drives: Attitude
#25 |
Drives: 2003 Subaru Outback
Ive heard Tomei and Perrin are both coming out with cams, excited to see how they help this car. And how these cars will sound with them most of all.
#26 |
250+ Hp NA on this car would be spectacular.
#27 |
Vtec Jesus
#28 |
Drives: Attitude
Perrin has never made cams for a Subaru...Jun, Tomei, even HKS I could see. I'm hoping for something more along the lines of Kelford, GSC, maybe Cosworth.
| Clutch Delay Valve? | ashtray | Engine, Exhaust, Transmission | 72 | 11-18-2015 12:10 PM |
| Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 08:53 PM |
| Valve Train Adjustments | @Art_Mighty | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 09-24-2012 09:10 PM |
| Valve Timing/Computer | miss paula | Issues | Warranty | Recalls / TSB | 3 | 09-20-2012 03:27 PM |
| Name that valve cover!!!! FA20???? | ESBjiujitsu | Engine, Exhaust, Transmission | 3 | 06-05-2012 09:42 PM |
