Old 11-19-2012, 03:01 PM   #57
Racecomp Engineering
Originally Posted by Kido1986 View Post
I assume (I don't know much about RCE so forgive me) that the revalves will be very well matched to the RCE springs? They (Springs) are on my short list of springs to do STX autocrossing until I can afford JRZ/KWs.
Yes, we (actually our sister company GTWORX) worked with Bilstein for a custom valved full strut for Impreza matched to RCE springs and that's something we plan on doing for the BRZ and FRS. It takes time though.
Bilstein vs. Koni is a tough call with advantages to both. Bilstein being a quality inverted front monotube with gas pressure that's easily and cheaply revalved vs. Koni being a quality twintube that's damping adjustable and has tons of support as well. I run Koni Yellows on my personal car. While some are "Koni til I die!" or vice versa I know that I would be very happy with Bilstein sports too.
- Andrew
AZP Installs (11-19-2012)
Old 11-19-2012, 05:04 PM   #58
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by Calum View Post
Nice, I wish you guys were near me.
You gotta appreciate that something like this could be intimidating to someone that's never done it before.
Definitely. It can be pretty intimidating but there are a lot of DIY writeups and it isn't terribly bad, also if you can find a shop that is pretty reasonably priced it's worth it.
And FYI we don't even sell Konis so this isn't a sales pitch either.
-mike
AIM: AZP Installs
E-mail: paisan@azpinstalls.com
725 Fairfield Ave (Rear)
Kenilworth, NJ 07033
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 11-19-2012, 05:05 PM   #59
AZP Installs
I'm sure the guys at RCE will have a very nice setup. I've known them for a long time and always have quality suspension parts.
-mike
The Following User Says Thank You to AZP Installs For This Useful Post:
Racecomp Engineering (11-19-2012)
Old 11-19-2012, 05:07 PM   #60
AZP Installs
- Andrew
100% agree, both are great setups and I would say the RCE custom valved setup is probably even better than the Konis, the only downside as you said is the adjustability and availability.
-mike
Old 11-19-2012, 05:16 PM   #61
Calum
That Guy
Drives: 2013 asphalt FRS MT
-mike
AIM: AZP Installs
NICE, :happy0180:
The Following User Says Thank You to Calum For This Useful Post:
Old 11-19-2012, 05:30 PM   #62
AZP Installs
We just have used em for a long time and hope to help out folks who may have less experience in tracking/modding in general.
-mike
Old 11-19-2012, 05:49 PM   #63
AZP are good peoples!
- drew
Old 12-13-2012, 11:21 PM   #64
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
I had an 02 WRX wagon so inserts were the only way to go. It wasn't the funnest mod experience, but the results were more than worth the effort involved. The were very well-matched to the Prodrive springs I was running and offered comfort, performance, and feel that few WRX suspensions could match. Driving my car was enough to convince several guys with high dollar coilover suspensions to go back to a strut and spring combination. In suspension tuning, sometimes less is more, and simpler is better.
I would do Koni shocks again in a heartbeat, even if all they offered were inserts.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
The Following User Says Thank You to WolfSongX For This Useful Post:
AZP Installs (12-13-2012)
Old 12-13-2012, 11:29 PM   #65
gmookher
coilovers are cake, get a quality set you can afford if going beyond rce yellows+ inserts or whatever
Old 12-13-2012, 11:54 PM   #66
AZP Installs
We will likely be offering pre-built Koni inserts for the BRZ once they become available. Depending on how much we can get the front housings for.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
Old 12-14-2012, 12:24 AM   #67
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
-Mike Paisan
Offer a discount for return of OEMs, like a core charge refund? Keeps your supply higher, keeps customer cost down as well.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
AZP Installs (12-14-2012)
Old 12-14-2012, 01:59 AM   #68
Silverpike
popular among the JDM
Silverpike's Avatar
Drives: 2014 BRZ Limited
Can someone answer this for me:
I thought that BRZ struts are dimensionally equivalent to 05+ STI front struts, and rears are equivalent to 08+ STI struts. If this is true, then can't any existing Koni insert for those years work? I'm sure the valving is different, but revalving isn't that hard.
Actually, that means coilovers should be directly portable also, ignoring spring rate and damping forces.
Silverpike is offline   Reply With Quote
Old 12-14-2012, 08:59 AM   #69
AZP Installs
That is the plan as well.
-Mike Paisan
Old 12-14-2012, 11:03 AM   #70
TRev
-Mike Paisan
Exactly what I would be looking for. I have no desire to do the inserts myself. Do you have a waiting list? If so, please sign me up. Thanks
TRev is offline   Reply With Quote
Performance Brake Components from ECS Motorsports Hawk | StopTech | DBA & More! AJ@ECSMotorsports Brakes, Suspension, Chassis 32 03-09-2014 11:18 AM
86Drift Exhaust Systems and Components 86drift Engine, Exhaust, Bolt-Ons 11 10-09-2012 04:58 PM
2 way possible in BRZ?? - JBL MS-62C 2 way components stevan Electronics | Audio | NAV | Infotainment 0 09-27-2012 05:35 AM
Components to upgrade for forced induction wbradley Forced Induction 12 09-24-2012 01:11 AM
Boston Motorsports: >>>Whiteline Suspension Components! Boston Motorsports Brakes, Suspension, Chassis 6 07-24-2012 01:07 PM
