| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2012 honda civic ex
Automatic Transmission Fluid Change
just found out froma toyota dealer that the "slush" box
tranny fluid requires a change-out at 100,000 miles initially,and then every 30,000 miles thereafter!.can anyone verify this?..thanks! |
#2 |
Drives: 2012 WRX Sedan
Given my luck with automatics, I'd change it out a bit sooner for piece of mind. YMMV.
#3 |
Drives: Attitude
#4 |
Doing it wrong.
You're not going to hurt it by changing it too often. I'd agree with others saying sooner is better than later.
#5 |
thanks for the input! wondering what the manual says! got a feeling
it ain't 100,000 miles for initial dump! dealer 'knows" i am considering the "slush" and "may" be tryin' to hit me with a s**t storm! i'm with you guys,change should be sooner! anyone know what's in the manual?..thanks! |
#6 |
I haven't checked the manual either, but I recall back in the day my mecahnic always told me to change the AT fluid around 30k miles. But I figure with the advancement in fluid technology these days should have improved that a bit? Maybe 50k miles is a good figure.
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#7 |
Drives: Whiteout FR-S
Yeah 40-50k should be good, the auto trans is one thing I do recommend sticking with the factory fluid. Do not use any ATF labeled "global" for sure.
#8 |
So you shouldn't use something from motul or Royal Purple for the AT fluid? Hmm I'll keep that in mind.
#9 |
I'm not going to, however if you end up with much higher than stock hp and torque you may want to use a high performance fluid i just don't know if there is anything compatible.
#10 |
Drives: 2013 FR-S Blue MT
If you want your slushbox to last you should probably change it frequently.
Many of the auto makers with "lifetime" ATF fluids are really only designed for ~100K miles. By that point they are out of warranty and not their problem anymore. In any slushbox cars I own, I would change every 30K for peace of mind. |
#11 |
Trim the Fat & add Boost
Drives: sometimes I fly
If you plan on doing this yourself... good luck changing it out correctly.
The process is harder than launching nuclear missiles. I remember reading the instructions and thinking... WTF!!! ![]() IT'S NO JOKE AND NOT AS SIMPLE AS DRAIN AND REFILL! Check out the online BRZ shop manual listed in the sticky section of this thread for the instructions. Again... good luck. |
#12 | |
#13 |
AutoX-10/10ths every run
I've just been reading up on the AT fluids in our twins. It appears to be hygroscopic. Given that I've been AutoXing my car and done a dyno pull or 3 on it I'm thinking that I want to get it changed. Right now I have just over 20K on the car.
Can some of the more knowledgeable members chime in on what mileage would be best for a change interval?
#14 |
I plan on doing mine at 30k, its cheap insurance and even if you drive like a grandma i would still do it at 45k. I drive mine pretty hard so changing the rear diff every 12-15k and trans fluid every 30k is a good idea if you plan to keep the car a long time.
This is just my opinion, no real data to back it up. I have been doing parts on the dealership level for 10 years now so i do have a little experience. |
| DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
| Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 02:23 PM |
| Mt transmission fluid swap | bdanisi | Engine, Exhaust, Transmission | 8 | 02-08-2013 02:09 PM |
| Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
