Old 12-13-2012, 05:17 PM   #15
gmookher
how will this benefit my brz chassis on the tarmac? will it help my times?(yes, devils advocate mixed with genuine curiousity)
Old 12-14-2012, 01:55 AM   #16
Silverpike
popular among the JDM
Silverpike's Avatar
Drives: 2014 BRZ Limited
It's a chassis reinforcement strategy. It benefits you the same way a roll cage or other load point reinforcement bars would. I've never been in a car that was foamed, so I can't say how good it is compared to the more traditional methods. All things being equal, the traditional cages would probably achieve the best results.
Silverpike is offline   Reply With Quote
Old 12-14-2012, 06:45 AM   #17
solma
Drives: Raven FRS
I thinks the real question here is how much(in %) will it stiffen the chassis vs weight penality. After that everybody can decide if they need or not a stiffer chassis.
And I agree with silverpike, roll cage would be way better for stiffening the chassis but again unless you are going for a full race car its not a solution unless you want to crack your skull in a road accident(no helmet).
solma is offline   Reply With Quote
Old 12-20-2012, 12:47 AM   #18
SOneThreeCoupe
Drives: 1992 Nissan 240SX
Don't do it unless you're completely sure, because if you do it right, it's damn near irreversible. It sticks to EVERYTHING and is tenacious as all hell.
I did it to my 240SX; I don't care if it never comes out- I live in SoCal (no rust worries) and the car's being built (slowly) into a dedicated track rat. It made a significant difference in the car's stiffness, but the car also started out much less rigid than a ZN/ZC6.
As far as weight goes, the foam I used weighed relatively little- about ten pounds did my lower radiator support, both frame rails, my seat cross bars, my B pillars, my A pillars and my C pillars. I did this a while back and didn't quite think it all through perfectly, so I may have wasted some pounds.
It makes far more sense to just install a well-built and properly designed cage, because it will not only stiffen the chassis but provide safety in case of off-track excursion.
SOneThreeCoupe is offline   Reply With Quote
The Following User Says Thank You to SOneThreeCoupe For This Useful Post:
JDMSushi (12-20-2012)
what is chassis number for 86? AE25 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 07-15-2013 01:31 AM
Chassis Brace(s) d1ck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-05-2013 08:58 AM
Is there a chassis code system? jabbajaw99 BRZ First-Gen (2012+) — General Topics 9 09-03-2012 04:44 AM
Help with chassis upgrade yomchi1989 AUSTRALIA 52 08-19-2012 06:15 PM
FR-S Chassis Code mediumbrown Scion FR-S / Toyota 86 GT86 General Forum 2 08-01-2012 10:04 AM
