Old 12-13-2012, 10:56 AM   #43
CSG Mike
CSG Mike's Avatar
Originally Posted by orthojoe View Post
Refer to here to see what mods the Evo X had:
http://www.evoxforums.com/forums/showthread.php?t=70895
I have not run the Evo X at MRLS with the NT01s because the car won't pass sound and the brakes overheat there even on street tires.
The 5 second drop at MRLS on NT01s was with my Boxster Spyder. The car is stock with the exception of adjustable lower control arms. Here's a video of the run:
Watching your car accelerate after T6 makes me jealous.
Old 12-13-2012, 11:02 AM   #44
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes and no. You can try ours for a session if you'd like
The AIM is a full standalone that polls at 10 hz, while the phone apps poll at 1 hz unless you get an external GPS.
More importantly, the data analysis software and predictive timing is key to REALLY utilizing a logger.
I use a Racepak G2X in my s2k, which I think is a better unit than the AIM (but also costs more than double...)
This.
<< Also uses an AIM Solo.
Oh and I'm one of the guys who ran R comps for years and moved back to street tires.
The cost and hassle was no longer worth it to me for an HPDE car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
rice_classic (12-13-2012)
Old 12-13-2012, 12:41 PM   #45
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Yes, the AIM SOLO is like $300-400 bucks BUT if you have the money I recommend getting the DL because of how it works with the OBD2 port... Lots more good information from that. I only have a regular SOLO because my racecar is OBD0 so the DL doesn't do me any good. Also, the AIM SOLO is a fraction of the cost of proper data acquisition system/devices (which are usually in the 4 digit price range) and the SOLO is very comparable, plus you don't need to setup a timing beacon at the track because it uses GPS.
Can you get good feedback and info from an iPhone app or Android app?.... Yes, yes you can but the internal G meters, GPS receivers and other items are not as robust so with something like the AIM you can really fine tune your feed back until you're improving your times by 10ths of a second or less.
Spend a few extra $$ and buy this: https://www.pegasusautoracing.com/pr...3FRecID%3D9542
This way you can use this from car to car.
Old 12-13-2012, 12:57 PM   #46
rice_classic
Hey Texas, whatever route you go with "getting data" just consider doing that, you won't regret it. Heck, just having a lap timer goes a LONG way on helping you improve while you're on track because if you keep everything on a lap the same but say, change how you approach 1 corner you have some way of measuring the effectiveness of that change.
Also Texas... what do you want to do or try next? Do you want to try different tires, suspension, brakes, sway bars, alignment settings, tire pressures or driving technique? All of those will keep you busy and excited about being at the track learning something new for quite some time. It will also keep you spending money
Remember: Make 1 change and measure. 1 change a time.
I'm a little jealous of where you are in your learning development Texas, I found that point in my development the most fun and the most rewarding. Heck, in 2011 I tried 5 different R-comps during my race season and this year (2012) I tried 5 different brake pad compounds. Very frustrating and rewarding couple of years but when it comes to Suspension, Brakes and Tires I'm very confident going into next year knowing exactly what I want, how I want it and how it will work.
The Following User Says Thank You to rice_classic For This Useful Post:
Texas BRZ (12-13-2012)
Old 12-13-2012, 01:17 PM   #47
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Agreed on getting the DL.
Similar to you, our racecar doesn't play well with the DL. It's a 96 Integra which I'm sure you know how completely worthless the OBD2 info is on that car so we also saved the money.
In hindsight I wish we would have gone with the DL simply because all of our DE cars are much newer and the DL would be very useful. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-13-2012, 02:56 PM   #48
CSG Mike
CSG Mike's Avatar
My DL isn't able to read off the OBDII on the BRZ. Did they release an update that I'm not aware of?
Old 12-13-2012, 02:58 PM   #49
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No DL so I haven't checked. Didn't realize the DL didn't support the FRS/BRZ yet
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-13-2012, 03:06 PM   #50
orthojoe
The DL needs to be configured specifically for the car. If you look under the ECU list, under Toyota there is a selection for GT86.
orthojoe is offline   Reply With Quote
Old 12-13-2012, 03:32 PM   #51
CSG Mike
CSG Mike's Avatar
Can you link me directly please? I swear their website is retarded and I can't google the ECU list; my manual with the URL for checking is at home....
Old 12-13-2012, 04:19 PM   #52
orthojoe
I'll get a screenshot of the setup screen that shows the GT86 protocol when I get home. AiM's website isnt working right now and I'm not sure if they added it to their website. I learned about it from Josh@AiM, who informed me that their lastest software update includes support for the GT86 ECU through the obd2 port.
I can't confirm that it works since I don't have my BRZ yet, but I can confirm that the protocol is an option
The Following User Says Thank You to orthojoe For This Useful Post:
CSG Mike (12-13-2012)
Old 12-13-2012, 05:12 PM   #53
CSG Mike
CSG Mike's Avatar
Very much appreciated! That'd be awesome if we could get full use of our DL this weekend.
Old 12-13-2012, 05:19 PM   #54
gmookher
neat!
Old 12-13-2012, 06:33 PM   #55
orthojoe
http://www.aim-sportline.com/downloa...12_100_eng.pdf
Old 12-13-2012, 07:11 PM   #56
CSG Mike
CSG Mike's Avatar
ECU_1 GT_RPM RPM
ECU_2 GT_SPEED Vehicle speed
ECU_3 GT_THROTTLE Throttle position sensor
ECU_4 GT_BRAKE_PRESS Brake pressure
ECU_5 GT_STEER_ANGLE Steering angle
ECU_6 GT_BRAKE_SW Brake switch
I suppose that's better than nothing....
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
top speed JLMtm Scion FR-S / Toyota 86 GT86 General Forum 56 10-30-2012 09:23 AM
D-SPEED ANREX Cosmetic Modification (Interior/Exterior/Lighting) 2 10-29-2012 07:47 AM
BRZ top speed speedracer38 BRZ First-Gen (2012+) — General Topics 66 07-08-2012 03:37 PM
speed eindio Scion FR-S / Toyota 86 GT86 General Forum 4 06-27-2012 10:59 AM
