Old 12-12-2012, 05:16 PM   #1
Ben_G
Drives: Blue BRZ
Frozen window solution?
Ok....i'm fairly certain that this is going to get all to hell, BUT, has anyone ever tried using a battery powered heater like this:
http://www.sportsimportsltd.com/port...defroster.html
I know that anything battery powered probably wouldn't put out a lot of heat, but I don't think a lot of heat is needed to prevent frost from forming on the windows and jamming them in the morning??
Ben_G is offline   Reply With Quote
Old 12-12-2012, 05:21 PM   #2
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
why don't you lay a towel across the window instead?
Ranatsu is offline   Reply With Quote
Old 12-12-2012, 05:32 PM   #3
Ben_G
Drives: Blue BRZ
Oh, I wasn't really thinking about the windshield.... more for preventing the door windows from jamming from icing overnight.....
http://www.ft86club.com/forums/showthread.php?t=23159
Old 12-12-2012, 06:09 PM   #4
Ranatsu
Cone basher
Right, but couldn't you do something similiar? Maybe a car cover or a blanket draped across the top of the car? I don't have to experience snow/ice like those up north so these are simply uneducated ideas.
Old 12-12-2012, 09:11 PM   #5
Ben_G
Drives: Blue BRZ
I've thought about that before, but a small blanket/towel would get blown away and I don't want to deal with a large car cover every morning.....
Old 12-12-2012, 10:57 PM   #6
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Biggest problem is water getting in the door while you're warmed up and then parking = FROZEN
No blanket is going to protect from that.
Need some way to identify the freeze points exactly, and address those points accordingly. Problem with that is, this assembly seems particularly susceptible to abnormal water retention (that is, what I believe to be longer or more than normal)
I noticed this the first time I washed the car. Even 24 hours after washing, rolling the window down, then back up, the window picks up water again.
CircuitJerk is offline   Reply With Quote
Old 12-12-2012, 11:58 PM   #7
Ben_G
Drives: Blue BRZ
I noticed that too. I see it even with just the window movement from opening the door, so I assumed that it has to do with the fuzzy seal at the base of the window retaining moisture and somehow causing the window to freeze to it (yes, I know that doesn't really make sense, but a lot of the problems with this car don't make sense!)
If (and that's a massive if) the above is true, then I figure that a heater would be enough to either a) prevent the freezing, or b) keep it melty enough that any freezing doesn't overcome the jam detection.
Old 12-13-2012, 12:02 AM   #8
Asphalt~86
Drives: Asphalt AT
Pam.
Asphalt~86 is offline   Reply With Quote
Old 12-13-2012, 12:07 AM   #9
Dusky
Dusky's Avatar
Drives: X3, 350z
Yeah, we need a solution. I am tired of resetting the windows every fracking day.
<a href=http://i1146.photobucket.com/albums/o524/dhpinoy/Flip86-bigfatflip.jpg[/IMG*] target=_blank>http://i1146.photobucket.com/albums/o524/dhpinoy/Flip86-bigfatflip.jpg</a>
Dusky is offline   Reply With Quote
Old 12-13-2012, 12:42 AM   #10
CircuitJerk
Pull my finger...
The heater doesn't seem like a practical solution. If anything I would be worried about damage or a fire hazard.
In order to avoid freezing you'd need to heat the cabin up significantly for it to warm the air pocket in the door.
I hate to even consider chemicals as the implications are not only messy but could cause other unwanted side effects.
LOL@ Pam
Old 12-13-2012, 01:46 AM   #11
Razz
Razz's Avatar
Drives: Fast
You can program the windows so they don't auto open. Problem solved.
Razz is offline   Reply With Quote
Old 12-13-2012, 11:43 PM   #12
BRZnut
Drives: BRZ DGM Limited
How??? And won't that make it hard to open the door??
Old 12-14-2012, 04:31 PM   #13
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I'm pretty sure they have to move down based on the design of the door/trim
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 12-14-2012, 04:38 PM   #14
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Serious question... why not live with it???
I have YET to get a car that the windows don't get frozen shut on cold morning, they eventually warm up during the day/driving.
Mines are frozen almost every morning...and it doesn't affect anything else.
Rayme is offline   Reply With Quote
solution to the ugly taillights beirouty Cosmetic Modification (Interior/Exterior/Lighting) 107 05-04-2014 04:42 PM
Front License Plate Solution? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 72 03-16-2013 03:00 AM
Frozen Black Matte Paint TIE Pilot Cosmetic Modification (Interior/Exterior/Lighting) 8 03-07-2013 03:09 PM
My Front Plate Solution Flat Black VW BRZ First-Gen (2012+) — General Topics 55 11-06-2012 10:07 AM
My Exhaust solution for the moment Scooby South Engine, Exhaust, Transmission 42 06-18-2012 08:26 PM
