Old 12-12-2012, 12:44 PM   #57
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Been following this thread but just to clarify, the process would be to:
1. Buy the JDM Bezels from nigel and Subaru Legacy Housing (available in the US)
2. Remove OEM Bezel, put in JDM bezel - mount OEM turn signals and Subaru Legacy housing to JDM bezel (with H11 bulbs).
3. Make a wire harness to a switch somewhere in your car, or buy the wheel stalk from nigel
4. Fogs!
Does that sound about right?
cdo221 is offline   Reply With Quote
Old 12-12-2012, 01:32 PM   #58
NemeGuero
In for GB on Bezels.
NemeGuero is offline   Reply With Quote
Old 12-12-2012, 02:09 PM   #59
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
How much would the set up be installed if your in so cal?
mr. slim is offline   Reply With Quote
Old 12-12-2012, 02:17 PM   #60
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
4. Fogs!
If someone could figure out how to wire in the stalk im in too. But it cant be that plug and play easy.How hard is it to make a harness and run wire to your steering wheel and tap into something if thats the case.
rhood168 is offline   Reply With Quote
Old 12-12-2012, 02:18 PM   #61
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
4. Fogs!
Sounds right to me. On Nigel's website, it seems like he is selling a harness with his option packages although I am not sure if this is an OEM harness or one built by his hookup in El Monte.
Nigel, could you please confirm? Also, on your website are you selling the Toyota plastic lens or the Subaru glass lens?
Thanks,
Brian
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 12-12-2012, 02:31 PM   #62
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
couldnt wait for this gb im making this happen now!
can someone with wiring expertise figure out the stalk harness please
im looking through the BRZ FSM and theres alot of wire groundwork in the harness thats related for the main stalk and im afraid its not in the FR-S main harness
my goal is to have this stalk activate the front and rear fog light
GT86drifter is offline   Reply With Quote
Old 12-12-2012, 02:38 PM   #63
NemeGuero
Where'd you source the fogs from? Seem about 50-60 each side.
Old 12-12-2012, 02:43 PM   #64
GT86drifter
Drift Specialist
Drives: 180SX,GT86
my local subaru delear has em for $56 a piece i'll be picking them up next week until i find it cheaper online shipped to me either way its prob $5-$10 difference
Old 12-12-2012, 02:55 PM   #65
NemeGuero
http://www.subarupartsforyou.com/cp_...p?partid=19073
The Following 2 Users Say Thank You to NemeGuero For This Useful Post:
*KID* (12-12-2012), Bluecille (12-22-2012)
Old 12-13-2012, 11:20 AM   #66
toddj55
I'd like in on the GB for bezels and stalk too. I'm still not clear on the wiring harness though. Is there an OEM harness from the factory? Is the harness Nigel is selling necessary? Can it be bought from him separately?
toddj55 is offline   Reply With Quote
Old 12-14-2012, 06:05 PM   #67
NemeGuero
Nigel said no go on the Bezels GroupBuy since they're already priced so low.
From his website it says the harness is aftermarket.
I doubt that OEM is a seperate sub harness, you'd probably have to swap out the entire engine bay harness and probably the underdash one as well.
email/PM him about buying stuff seperatly. He'll accomodate.
The Following User Says Thank You to NemeGuero For This Useful Post:
nigel-jdmparts (12-19-2012)
Old 12-14-2012, 11:28 PM   #68
Fantum's86
Fantum's86's Avatar
Drives: Toyota GT86 TRD
Originally Posted by SpecPer View Post
Just use the Subaru legacy fog lights housing which are glass and you will be good. Keep in mind that the oem Toyota 86 uses the same plastic fog light housing as the brz here in the U.S. Also, once you use the Subaru legacy housings it will also change the bulb to a H11. Much better.
have you used the legacy light? does it work/ attach to the Toyota fog light bezel? is everything exactly the same as the Toyota 86 ones expect for it being glass?
~thanks for your help!
Instagram: Poetic_Delinquent
Fantum's86 is offline   Reply With Quote
Old 12-15-2012, 05:18 PM   #69
NemeGuero
http://www.ft86club.com/forums/showt...t=20788&page=3
Old 12-19-2012, 07:40 PM   #70
Cjs_
Cjs_'s Avatar
In for the bezels.!
@nigel-jdmparts sent a PM to you..
Cjs_ is offline   Reply With Quote
The Following User Says Thank You to Cjs_ For This Useful Post:
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
Gram Light equipped white GT86 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 34 02-17-2012 03:20 PM
