| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: fast
my thoughts about break in
i know everyone has their own ideas, but to me it doesn't seem like it would be good for the engine to never see revs above 4k for the first 1000 miles and then all of the sudden be taken up to redline and driven much harder.
since i've hit 500 miles i've been pretty much observing the 4k limit, but will occasionally let it go up to 4500 rpm, and as i increase in milage i will be slowly increasing my rpm limit. i'm at 700 miles now and i will sometimes let it get up to 5k rpm at partial throttle. i'm still staying below 4k for the most part, and not doing any full throttle acceleration till 1000 miles. but i'm occasionsly letting the engine reach higher revs. a gradual build up to redline and adding more throttle slowly seems like it would be better for it than babying it and then all of the sudden flogging it at 1000 miles. thoughts on this? |
#2 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#3 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
My thought? I always figured the people that wrote the owenrs manual knew more about the topic than I did since I missed class that day. I take the easy route and stay within the lines (follow the instructions)
#4 |
My dealer said the same thing. Keep it under 4k for the first 1000. I intend to do it since I care about the car, not whether or not it is necessary.
92 mph is 4k rpm just fyi. (Fastest toll road in the US in Texas, 85 mph speed limit, SH 110!) |
#5 | |
Drives: 2013 Asphalt FR-S
Sometimes I take it home even though it adds about 15min/10mi onto my trip time |
#6 | |
Drives: FR-S MT
| The Following 3 Users Say Thank You to FRiSson For This Useful Post: |
#7 |
Drives: 1991 Acura NSX, 2013 Scion FRS
This ^
#8 |
#9 | |
Drives: '23 CWP BRZ
Proof: http://www.fuelly.com/driver/stiex/frs |
#10 |
Track Junkie
Drives: Faster than the Stig!
I bought mine on a friday and tracked it on a sunday. I put 500 miles on her and did an oil change before tracking her. Ive got around 3.5k miles and most of them are track. I have not had a CEL or any other problem so i think what ever i did worked
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
| The Following User Says Thank You to track_warrior For This Useful Post: | Surok (01-01-2013) |
#11 |
Drives: SSM LT MT BRZ
my engine saw redline in the first 100 miles...all my engines (most of which I build personally) see redline either during breakin on the dyno, or in the first 100 street miles, an understanding of metalurgy and the surface finishes in the bore will tell you why this is not only OK but preferable.
Break in is the period of time where the motor "seats" the rings to the cylinder walls, repetitive friction on a surface "work hardens" the material, what you ideally want is the rings to use the minimal abrasive action from the cylinder finish hone to normalize the ring shape to the individual cylinder wall, this requires cylinder pressure to force the rings against the cylinder wall, WOT and high rev's create cylinder pressure. and are therefore REQUIRED to create the best ring seal possible, before you work harden the cylinder walls and the ring faces. (which are already appreciably hard) There once was a time before what is known as plateau honing, that you could wear out the hatching left in the cylinder with too much cylinder pressure during break in, but those days have long since past. So why is there a break in procedure then (because i know you all think im stupid by now...obviously) well because the Manufacturer knows that you will still get an acceptable ring seal driving gingerly, worst case scenario you lose some cylinder pressure and a few HP, maybe burn a bit more oil consumption (with a mfg specified 1000 mile break n procedure) but the manufacturer has a lower chance (albeit slight) of brand new car engine failures. Also the clutch really does need about 300-400 miles of nice easy engagement without significant shock to ensure optimal life. Take with a grain of salt, but remember always that corporations rarely have you or your property's best interest in mind, when they write literature, it is to cover their ass...not protect your investment. |
| The Following 7 Users Say Thank You to SkullWorks For This Useful Post: | baldolera (03-05-2013), boredom.is.me (12-17-2012), ftc~brz (03-01-2013), Guff (03-01-2013), ill86 (12-15-2012), sierra (01-01-2013), Supermassive (12-30-2012) |
#12 |
Drives: Raven FR-S
my friend is a mechanic and he told me the process was just a myth.. so i drove my car pretty hard after 500.. up to 7k rpm on shifts
#13 | |
Drives: 17 Alfa Romeo 4C
Only time will tell. |
#14 |
| ECU reset after Break-In | paros28 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 02-19-2013 05:41 PM |
| Break in | ipothas | Issues | Warranty | Recalls / TSB | 11 | 10-21-2012 04:41 PM |
| End of break-in! Now where do we go play? MTL | QC-FRS | CANADA | 3 | 06-29-2012 10:05 PM |
| How did you break in your engine? | WolfsFang | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-05-2012 01:12 AM |
| Break-in question | Baldeagle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 03-31-2012 02:28 PM |
