Old 09-18-2012, 02:10 PM   #57
themadpants
Drives: .
Just for clarification:
In North America since 1986, a central brake lamp, mounted higher than the vehicle's left and right brake lamps and called a "Centre High Mount Stop Lamp (CHMSL)", is also required. The CHMSL is also sometimes referred to as the "centre brake lamp", the "third brake light", the "eye-level brake lamp", the "safety brake lamp", or the "high-level brake lamp". The CHMSL may produce light by a single central filament bulb, a row or cluster of filament bulbs or LEDs, or a strip of Neon tube.
The CHMSL is intended to provide a deceleration warning to following drivers whose view of the vehicle's left and right stop lamps is blocked by interceding vehicles. It also helps to disambiguate brake vs. turn signal messages in North America, where red rear turn signals identical in appearance to stop lamps are permitted, and also can provide a redundant stop light signal in the event of a stop lamp malfunction.
The CHMSL is generally required to illuminate steadily and not permitted to flash, though U.S. regulators granted Mercedes-Benz a temporary, limited exemption to the steady-light requirement so as to evaluate whether a flashing CHMSL provides an emergency stop signal that effectively reduces the likelihood of a crash.
On passenger cars, the CHMSL may be placed above the back glass, affixed to the vehicle's interior just inside the back glass, or it may be integrated into the vehicle's deck lid or into a spoiler.
The height of the CHMSL is also regulated, in absolute terms and with respect to the mounting height of the vehicle's conventional left and right stop lamps. Depending on the left and right lamps' height, the lower edge of the CHMSL may be just above the left and right lamps' upper edge.
So that means the flashing brake lights mod people are doing is the most likely source of a fix it ticket. And that you cannot remove the factory third brake light, unless the replacement is above the standard brake lamps.
No mention of any legalities regarding a 4th brake light below the factory brake lamps from my research, so you should be good with this mod, as long as your bulb fits this specification:
In North America, the acceptable range for a single-compartment stop lamp is 80 to 300 candela
themadpants is offline   Reply With Quote
The Following User Says Thank You to themadpants For This Useful Post:
DrDuquette (07-29-2013)
Old 10-04-2012, 10:57 AM   #58
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Any videos at night driving on road? I want to see if all 4 brake lights looks like too much..
VADER is offline   Reply With Quote
Old 10-28-2012, 09:38 PM   #59
Gorgz
Drives: 86 (ZN6)
Does anyone know if this would work in the Australian model? (FT-86)
I wouldn't mind trying it but I'm just concerned I may kill the front fog lights or "daytime" lights as they call it
Gorgz is offline   Reply With Quote
Old 11-12-2012, 01:39 AM   #60
Kentonic
Kentonic's Avatar
@ZILLA Love this write up. I was shocked when I picked my FR-S up that this rear reflector wasn't even used!! Very upset... couldn't wait to do this DIY. I like yours better than the other ones even went out and got the dual 194s too. Hoping I get time tomorrow to do this.
Kentonic is offline   Reply With Quote
Old 11-14-2012, 12:46 PM   #61
Kentonic
Kentonic's Avatar
Originally Posted by cto424 View Post
Zilla, any condensation issues with the sockets that you used?
Day 1 after my install it's actually really cloudly today here and my light assembly has condensation issues... Anyone know what I can do to fix this?
Old 11-14-2012, 02:11 PM   #62
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Just take the bulb back out and let the condensation evaporate out. When you put the bulb back in use a small amount of silicone on the seat of the socket and it should seal up just fine.
Chances are the socket isn't pulled tight enough to the housing to make the o-ring seal.
kask2_6.0 is offline   Reply With Quote
The Following User Says Thank You to kask2_6.0 For This Useful Post:
batboygotoj (01-24-2014)
Old 12-12-2012, 04:19 AM   #63
DIGERATI
Drives: 2009 BMW Z4 SDrive35i
Great DIY!
Love the way it turned out, especially with the blinker module.
Will be doing this too, and post more pictures/videos
Originally Posted by cobrabyte View Post
I used the LEDs that you can purchase at AutoZone/O'reilly's. Thought they were referenced in ZILLA's original parts list.
cobrabyte, ZILLA's originally list was referencing to 194 bulbs, did you use the same? Or did you use LED? If so, which type did you use? (I like the brightness level of yours)
I prefer LED if possible, due to the concern for overheating.
Since the blinker module is for LED only, I'm guessing you used LED and not the 194 bulbs....
Thanks in advance for the info!
DIGERATI is offline   Reply With Quote
Old 12-12-2012, 11:49 AM   #64
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Originally Posted by DIGERATI View Post
Great DIY!
I did use LEDs because I didn't want to have to swap them out for a very long time.
The ones I used are here: http://www.autozone.com/autozone/acc...er=436567_0_0_
Hope that helps!
cobrabyte is offline   Reply With Quote
Old 12-12-2012, 12:01 PM   #65
DIGERATI
Hope that helps!
thanks for the confirmation and bulb info!
I'll probably start working on this after xmas!
Old 01-08-2013, 04:26 PM   #66
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
Hey @ZILLA
I am doing this set up and I have the exact same socket as you pictured. Am I correct in assuming that the black is live and the brown is ground?
tbwoodlee is offline   Reply With Quote
Old 01-12-2013, 05:13 PM   #67
Mo707
Mo707's Avatar
Did you use white or red LED's ?
Mo707 is offline   Reply With Quote
Old 01-12-2013, 05:14 PM   #68
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Red
Old 01-20-2013, 09:39 PM   #69
Mo707
Mo707's Avatar
does it matter which one is the + and witch one is the -?
And where did you put the ground wire?
Old 01-27-2013, 12:28 AM   #70
Mo707
Mo707's Avatar
Anyone?
custom, fog, fog light, foglight, rear fog light
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 10:48 PM
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 03:47 PM
Third brake light out? Longhorn248 BRZ First-Gen (2012+) — General Topics 21 11-23-2015 04:23 PM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) — General Topics 12 06-06-2012 08:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 04:53 PM
