Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 12-11-2012, 12:35 PM   #1
v3rgil
Drives: Toyota 86 Black (Standard)
10 Little Toyota 86 Things
Like #1: You can fit four wheels in the back. In case you get lots of punctures.
Not really (the puncture bit). But Toyota made sure the "enthusiastic driver" could fit four spare wheels in the back for those track day visits. Nifty.
Like #2: The story behind the 86 badge.
Oh yes, there is one. As well as saying "86" in a kind of clever way, the four little cut outs are supposed to represent four wheels drifting. The pistons on either side of the badge represent the horizontally-opposed boxer engine.
Like #3: Frameless rear vision mirror.
You know how rear vision mirrors normally have a black bezel, frame thingo around their outside? Not this one - it's mirror right to the edge. And it's a world first, according to Toyota.
Like #4: the traction control and ESP.
Turning them off, we mean. Happy times guaranteed. The 86 is hilariously easy to slide.
Like #5: this tube here.
Let us explain why it is good. The tube is attached to the 86's air intake and goes into the footwells of the cabin. That way, you hear more of the 2.0-litre four-cylinder's rather delicious induction noise when you're mushing accelerator pedal into carpet. Above 4000rpm, the engine is noticeably louder. We'd like to thank the arm for pointing this out.
Random Toyota 86 thing we didn't know: the engine's bore and stroke is 86x86mm.
Like #6: Distinctive 86 triangle pattern.
See the weird triangular outline of this here rear foglamp? It's a special 'I'm-a-Toyota-86' thing. C why next
Like #6: Distinctive 86 triangle pattern (continued)
Not only is it on the rear foglamp, but it's also on the fake carbonfibre on the dashboard. But wait, it's everywhere...
...it's also on the seats! Highly enthusiastic 86 nerds (currently incubating in the car culture womb) will make t-shirts out of this pattern. You watch.
Like #7: the insanely unToyota instrument cluster.
A Camry's tacho and speedo are as exciting as potatoes in water. We can't believe that Toyota - Toyota! - made an instrument cluster with a centrally-mounted tacho. We really dig how far counterclockwise '0km/h' is on the speedo. Very supercarish.
(Nerds will also spot that triangular pattern here again.)
Like #8: Stig-friendly headrests (continued)
Some say Stig gets a sore neck (all of them) when he normally drives cars. That's because his helmet rubs up against the headrest. Not in the 86, which has been designed such that you can swap around the headrests (like this) when going to a track day, to better accommodate your helmeted head. Very, very nifty.
Random Toyota 86 thing we didn't know: it goes on sale June 8. Or the 8/6. Get it?
Like #9: sexy raised bonnet bits - look closely.
You know when you're driving a 911, because you can see the tops of the headlights raised up through the windscreen ahead of you. Well, weren't we quite stoked to see a similar thing in the 86! Because it uses a low-lying boxer engine, Toyota was able to sink the middle of the bonnet down low, giving way to sexy creased edges above the front wheels. Nice.
Like #10: rollcage-friendly door handles.
More good news, trackday TopGearers! According to Toyota, the door handles have been strategically positioned to facilitate the easy fitment of a rollcage (otherwise you'd install your rollcage and then become trapped inside your 86 forever, apparently).
Random Toyota 86 thing we didn't know: the exhaust pipe diameter is 86mm. How nerdy.
And there you have it! If you're still craving Toyota 86, we can help you.
v3rgil is offline   Reply With Quote
The Following 2 Users Say Thank You to v3rgil For This Useful Post:
draggin_az (12-13-2012), finch1750 (12-11-2012)
Old 12-11-2012, 02:30 PM   #2
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Scary that I knew all of that, except for #8.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 12-11-2012, 02:43 PM   #3
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Badass I really didn't know about number 8 but knew most everything else.
tuckdaddy is offline   Reply With Quote
Old 12-11-2012, 02:52 PM   #4
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
you forgot the little bump on the center dash so you always know the center of the car attacking corners
GT86drifter is offline   Reply With Quote
The Following 2 Users Say Thank You to GT86drifter For This Useful Post:
finch1750 (12-11-2012), Spartan65 (12-11-2012)
Old 12-11-2012, 04:11 PM   #5
sav
sav's Avatar
Cool, I didn't know that either.
95RON SAV Tuned
Old 12-11-2012, 04:42 PM   #6
GT86drifter
Drift Specialist
Drives: 180SX,GT86
also for #9 real reason the arches are there so you know exactly where the front wheels are so you can keep your line as tight as possible on the track
Old 12-11-2012, 04:59 PM   #7
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I always thought the arches were there as necessary space for the front suspension.
whaap is offline   Reply With Quote
Old 12-11-2012, 05:51 PM   #8
jshadeck
jshadeck's Avatar
Agree w all but #7, i really liked the instrument panel in my is300 and the lfas cluster is a-ma-zing
jshadeck is offline   Reply With Quote
Old 12-12-2012, 04:16 AM   #9
Thavash
Drives: Red Hachiroku
Agreed - Toyota have always made some funky instrument clusters. Like the original IS200 which looked like a watch. Even the 3.0l Cressida's in the 1980's had a crazy digital dash.
Thavash is offline   Reply With Quote
Old 12-12-2012, 07:37 AM   #10
jshadeck
jshadeck's Avatar
Was the orginal is200 different than my is300? Heres what mine had
Old 12-12-2012, 07:55 AM   #11
sav
sav's Avatar
That looks cool. I still think the 86's analogue speedometer is a massive fail because it's so hard to read quickly. They should have given them all the digital speedo and used that space for oil pressure and temp.
95RON SAV Tuned
The Following User Says Thank You to sav For This Useful Post:
nzer (12-13-2012)
Old 12-12-2012, 09:11 AM   #12
jshadeck
jshadeck's Avatar
Completely agree w the analog speedo, but appearance wise i like the twins cluster. Function wise, yes it would be nice to have oil and maybe boost gauge in that location
Old 12-12-2012, 11:30 AM   #13
gmookher
A la Porsche
Old 12-12-2012, 11:37 AM   #14
travace
travace's Avatar
Drives: Scion FR-S
the headrest thing is cool.
travace is offline   Reply With Quote
A few things I didn't know about the car Neilus AUSTRALIA 14 06-22-2012 11:25 AM
10 things you need to know phenoyz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-30-2012 11:02 PM
What little things you want to see Maxim Scion FR-S / Toyota 86 GT86 General Forum 310 10-12-2011 07:16 PM
Things I wish for.... Please Toyota! EJ20 Scion FR-S / Toyota 86 GT86 General Forum 80 10-11-2010 11:56 PM
FIVE THINGS TO NEVER DO TO YOUR CAR Raiden Other Vehicles & General Automotive Discussions 11 08-27-2010 08:55 AM
