Old 12-10-2012, 07:32 PM   #57
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by ScionFrsFan View Post
Agreed. I was extremely interested until I saw that.
youll never maximize gains without a tunes its been proven time and time again. the mods will show improvement but like i stated already ive gotten datalogs from customers who already had a tune and the afr was 1-1.5 afr richer than prior to installing the pipes. i expect that since removing the secondary cat richens up the system quite a bit. and running too much fool limit power output. this is why all the ecutek tunes removes all the excess fuel and we gain 10+whp. too rich="bad" if you had. adversely i did notice that with just the pipes the car on the stock air box leaned out ebough that it gained power but afr was in the high 13s which explains why a stock car shows gains with the pipes only before an intake is added. granted the gains are there but high 13s isnt going to be healthy over the long run.
FA20Club.com is offline
Old 12-10-2012, 07:33 PM   #58
FA20Club.com
Originally Posted by JoeBoxer View Post
Is there a dry flow filter option? Congrats on the numbers you know my setup do you think the intake would be worthwhile?
ill check to see if AEM offers a filter that will fit behind the bumper without crunching
Old 12-10-2012, 07:36 PM   #59
FA20Club.com
Originally Posted by GTB/ZR-1 View Post
What part of FL are you in? Thx
Im in the ft lauderdale/palm beach area
Old 12-10-2012, 08:02 PM   #60
Turdinator
Señor Member
Turdinator's Avatar
One thing I'm not clear on, if i purchased the intake only would i require a tune for it to run safely and with good drive-ability?
1974 TA22 Celica
2013 86 GT
Turdinator is offline
Old 12-10-2012, 08:05 PM   #61
2forme
Does the intake require any cutting or removal of that plastic clip on the upper radiator guard?
2forme is offline
Old 12-10-2012, 08:14 PM   #62
FA20Club.com
the intake tube diameter doesnt mandate a tune. and will still yield the standard gains of 8-10hp i would honestly say that these hg gains will be more consistent on road speeds feeding cooler air from outside the engine bay.
The Following User Says Thank You to FA20Club.com For This Useful Post:
Turdinator (12-10-2012)
Old 12-10-2012, 08:15 PM   #63
FA20Club.com
only thing we removed for install was the fatory intake tube for the airbox
Old 12-10-2012, 08:37 PM   #64
mike2100
mike2100's Avatar
Drives: 23 BRZ
Originally Posted by FA20Club.com View Post
DYNO Chart
Green Line: Stock With Overpipe, Front Pipe & CAI Installed Untuned
Blue Line: Overpipe, Front Pipe & CAI Tuned +19-21WHP over untuned results
Red Line: Overpipe, Front Pipe & Stock Air Box Tuned +10WHP over untuned results
So with the overpipe, front pipe, and intake (but no tune) the car maxes out at about 130 whp.
And you say the intake makes a "standard gain of 8-10 hp".
So this car maxed out at about 120 whp on your dyno in completely stock form? (my definition of stock is "no mods")
mike2100 is offline
Old 12-10-2012, 08:47 PM   #65
mike2100
mike2100's Avatar
Drives: 23 BRZ
The car lost power without tune adjustments.
Color me confused
mike2100 is offline
Old 12-10-2012, 08:56 PM   #66
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by mike2100 View Post
Color me confused
This is what i wasn't sure about. But if you read carefully its the exhaust that requires the tune
The car lost power without tune adjustments. I have noticed that most customers who install the over & front pipe contact me with datalogs running extremely rich from their current tune and complaining of a loss of power.
1974 TA22 Celica
2013 86 GT
Old 12-10-2012, 09:05 PM   #67
FA20Club.com
I will have all the parts off the car in the morning to run the car bone stock untuned i would assume it should make somewhere around 145hp and it should make around 155hp with the intake. those are the only 2 dyno runs i have let to do. to finalize all our baselines. im sure once we get at least a full tank of gas run through her she'll make more power baseline as well as with the mods. remember guys this car is fresh off the lot with only 80 miles on her.
flippy (12-11-2012)
Old 12-10-2012, 09:21 PM   #68
1strwdcar
Drives: 2013 scion frs Whiteout
i have an injen intake and perrin pulley along with a Q300 catback my catless front pipe is on the way. My car does feel stronger. are you saying with the catless front im going to richen up and lose power??
1strwdcar is offline
Old 12-10-2012, 09:48 PM   #69
FA20Club.com
ft86 speedfactory can get you one of our tunes since you shop with them. but yes the catless version cause a richer overall mixture. youll probably pickup power since you already have an intake though but if you went with front pipe and catless pipe you would be on the rich side.
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
1strwdcar (12-10-2012), FT-86 SpeedFactory (12-11-2012)
Old 12-10-2012, 10:59 PM   #70
1strwdcar
Thank you ill give it a try but your tune is next ony list. Car feel strong right now
MXP EXHAUST and FRONT PIPE FRS BRZ in stock ready to install or ship AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 0 11-08-2012 09:09 PM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 01:10 AM
