Old 12-10-2012, 12:32 PM   #43
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by UncleFester View Post
I'm interested in the intake. I'm still looking for one to finish my STX build.
When you post dynos, could you do a stock vs. intake installed vs. ecutek tune & intake installed? I'm curious what power it makes with a tune.
ill see what i can do but that was the whole intent of todays dyno session.
FA20Club.com is offline
The Following User Says Thank You to FA20Club.com For This Useful Post:
number1Tango (12-10-2012)
Old 12-10-2012, 12:39 PM   #44
jm1681
Drives: MKVI VW GTI
Originally Posted by FA20Club.com View Post
thats the sway bay and its way above it. so those who want to use a larger diameter sway bar will have zero issues...
Ah, gotcha. Thanks
...pipe is 2.5" outer wall thickness 16 gauge
Same size as the Perrin and a whole lot cheaper This is one of those times where I simply can't believe that there is some reinvention of the wheel going on, to justify an additional $50 ^_^ Hoping to pick one up ASAP.
jm1681 is offline
Old 12-10-2012, 12:54 PM   #45
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
What part of FL are you in? Thx
GTB/ZR-1 is offline
Old 12-10-2012, 12:59 PM   #46
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
they are in broward county (South)
lbroskee is offline
Old 12-10-2012, 02:35 PM   #47
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
The only thing I don't like about the intake is the fitment of the air filter. It looks off to me, but maybe the clamp wasn't tightened down in the pictures. Looking forward to dyno results and pictures of the finished product with some powder coating!
EDIT: Also the MAF sensor wiring looks dangerously close to the AC pulley and accessory belt... What are you guys doing about that?
ATL BRZ is offline
Old 12-10-2012, 04:36 PM   #48
Craig
Craig's Avatar
Drives: Asphalt FRS
In for dyno
Edit: Saw the dyno, apologies
Craig is offline
Old 12-10-2012, 06:35 PM   #49
FA20Club.com
Dyno chart posted on 1st page from todays short test session.
Craig (12-10-2012)
Old 12-10-2012, 06:51 PM   #50
FA20Club.com
maf sensor harness is still secured to the factory clip mount its out of harms way. filter was for a lrger tube. i installed the correct filter this monring before dyno.
Old 12-10-2012, 07:01 PM   #51
Zadkiel
Drives: CBS BRZ Limited 6MT
Not digging having to pop off the bumper to clean the filter. That's what drove me away from the Perrin unit.
Back in (Crystal) Black.
Zadkiel is offline
Old 12-10-2012, 07:01 PM   #52
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Is there a dry flow filter option? Congrats on the numbers you know my setup do you think the intake would be worthwhile?
JoeBoxer is offline
Old 12-10-2012, 07:07 PM   #53
swift996
swift996's Avatar
Does the CAI draw heat from the radiator? Also does the extended length of the system reduce throttle response?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 12-10-2012, 07:13 PM   #54
Zadkiel
The one big thing I don't dig is the requirement of a tune to make the advertised power.
Zadkiel is offline
Old 12-10-2012, 07:27 PM   #55
ScionFrsFan
Agreed. I was extremely interested until I saw that.
ScionFrsFan
ScionFrsFan is offline
Old 12-10-2012, 07:27 PM   #56
FA20Club.com
throttle response is already turned up with on of our flashes so its allot crisper than stock
MXP EXHAUST and FRONT PIPE FRS BRZ in stock ready to install or ship AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 0 11-08-2012 09:09 PM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 01:10 AM
