View Poll Results: Coilovers?
KW Varient 3 160 47.20%
BC (what varient should I get?) 48 14.16%
HKS Hipermax IV GT 21 6.19%
Cusco (what varient should I get?) 15 4.42%
KSport Kontrol Pro/D2Racing RS 10 2.95%
Megan 12 3.54%
Tein (what varient should I get?) 54 15.93%
Tanabe Sustec Pro 1 0.29%
Stance 18 5.31%
Voters: 339. You may not vote on this poll
Old 12-10-2012, 09:41 AM   #99
Racecomp Engineering
Originally Posted by Snoopyalien24 View Post
Going WAAY off here, but, anyone prefer lowering spings over coilovers, especially since some might never track it?
Opinions? Advice?
Yes lowering springs are a great value but not if you want to slam the car. With a mild drop (20mm) you'll have good ride and handling, especially if they include replacement bump stops like our springs...but go much farther beyond that and you are on the bumpstops at rest.
- Andrew
Old 12-10-2012, 10:34 AM   #100
gmookher
I have the H&R Supersport coils at present, waiting for car return to put on my GC Coilovers, but they felt great and increased the capabilities from stock with a very acceptable ride, no chiropractor needed
If it was a DD I may have just chilled there. bigger bumps do bottom to bumpstop, so if you are a NYC driver, you may be better off with a taller coil like the RCE yellow, which probably match the oe dampers better for bigger hits
Old 12-10-2012, 11:14 AM   #101
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
I see the KW's are leading the poll, I'm thinking of grabbing the GC coilovers also. Wonder how they compare to the current leader ?
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-10-2012, 11:40 AM   #102
gmookher
I cant answer that, what I'd love to see is a BRZ wearing the same rubber with KW3+sturtbar of choice, driven back to back to a GC setup.
the spring rates are different between the two, I dont know what options for rates KW offers, but there are softer and firmer setups from GC. I plan to order some extra coils.
Why doesnt the poll have GC listed?
Old 12-10-2012, 11:47 AM   #103
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I would like to see the same and for your second question...
Because they needed seperate choices for Megan, Ksport, and BC even though they are all pretty much the same thing.
It's also amazing that Tanabe has no votes, i would place them well above some of those others.
Old 12-10-2012, 12:56 PM   #104
dabocx
dabocx's Avatar
Drives: Scion FRS
GC seems to be my current route just because it comes with the camber plates and is ready to go out of the box.
The fact that my rear camber will go nuts does bother me though but i want whiteline to come out with their RCA
dabocx is offline   Reply With Quote
Old 12-10-2012, 01:21 PM   #105
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Ok, here's another question... GC or KW? GO!!
VADER is offline   Reply With Quote
Old 12-10-2012, 01:27 PM   #106
dabocx
dabocx's Avatar
Drives: Scion FRS
X2
Old 12-10-2012, 01:37 PM   #107
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
any word for the HKS Hipermax IV GT?
MSTiFK8R is offline   Reply With Quote
Old 12-10-2012, 01:39 PM   #108
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
- Andrew
Ah thanks! I hope to go 1.5"- 2" low, nothing slammed, but nothing too high.
Seems silly to pay $2k for lowering it only if I am never going to track it (imho)
Snoopyalien24 is offline   Reply With Quote
Old 12-10-2012, 01:56 PM   #109
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
I spoke with Adam earlier @ GC and got a go ahead for shipping to Canada
I just noticed you had posted pics earlier in the thread of yours. I'm looking at similar color choices
Just debating whether or not to get the optional Truss bar and rear shock mounts. These will be used for street use only, so I'll probably pass
2URGSE
Old 12-10-2012, 02:01 PM   #110
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Get some quality shortened dampers then...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-10-2012, 02:01 PM   #111
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
1.5-2" (38-51mm) i would say you might want coils going that low, could run in to bottoming problems with lowering springs. 2k for a good set of coils is a way of preserving oem like handling i little stiffer but otherwise very compliant (not saying that other slightly cheaper ones aren't good either) it comes down to budget i guess, 2k for a shock you know is going to perform well in all circumstances or lowering springs that may or may not have travel problems IIRC most lowing springs don't go more than ~1.3" most staying arount the 1.1 area (some exceptions obviously)
my .02 :happy0180:
FreshFRS is offline   Reply With Quote
Old 12-10-2012, 02:12 PM   #112
There may be a few new quality coilover options next year under that price range, but right now there aren't many options.
- Andrew
DIY BC coilovers RWD-boxer DIY (Do-It-Yourself) Guides 1 11-05-2012 09:07 PM
Bc br coilovers whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 10-20-2012 11:44 PM
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 02:45 AM
Coilovers vs Springs – What are coilovers and what’s better? phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-30-2012 12:24 AM
D2 coilovers F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2012 03:50 AM
