Old 12-10-2012, 09:32 AM   #127
RavSpec
Drives: Rx7
18x9.5 - 23 lbs
18x11.5 - 24.4 lbs
RavSpec is offline   Reply With Quote
Old 12-10-2012, 09:33 AM   #128
RavSpec
Drives: Rx7
A disk will clear Brembo caliper. O disk for stock caliper.
Old 12-10-2012, 11:39 AM   #129
ebphoto
Drives: FR-S, NA8, S13
Originally Posted by mr. slim View Post
props man!
this is a great set up!
what disk are you running?
Originally Posted by RavSpec View Post
if u are running stock caliper, O disk all around will work.
im running O disk... but it looks like a decent amount of room for brakes in all honesty... need to try them out on a local car that has sti calipers.
ebphoto is offline   Reply With Quote
Old 12-11-2012, 10:14 AM   #130
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
My fronts are going to be 18x9 +28. Waiting to back from Work USA because if I can roll O disc up front and slip on a 5mm spacer and clear the brembos that's what I'm going to do
Sent from my PC36100 using Tapatalk 2
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 12-11-2012, 11:58 AM   #131
RavSpec
Drives: Rx7
O disk need at least 10mm spacer to clear.
But A disk will clear.
Old 12-11-2012, 12:29 PM   #132
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Specifically with the size I listed above or generally?
18x10 front & 10.5 in the rear. From other pics looks like O disc front & rear... I find it hard to believe hes running a spacer on top of that width and judging by the dish still low et rim itself
Omar GC
Instagram: 2jzus
Old 12-12-2012, 11:24 PM   #133
jserman
Drives: 97 DB8
Love the look EB...
jserman is offline   Reply With Quote
Old 12-12-2012, 11:27 PM   #134
RavSpec
Drives: Rx7
Can't judge disk type and offset just by looking at the pics.
It's only 10mm of caliper and lip size differences between the two disk.
Caliper clearance for meister s1r are based on disk type, not offset and width.
Mark
Old 12-13-2012, 03:44 AM   #135
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Dude forget about the people hating on your car... You possibly have the best wheel selection and fitment out of the majority of cars on here and I think the majority of people reading this would agree. Well done.
Want to see MOAR!
JordanWho is offline   Reply With Quote
Old 12-13-2012, 05:03 PM   #136
sal
sal's Avatar
Drives: 16 FRS
Can we see more pictures?
sal is offline   Reply With Quote
Old 12-13-2012, 05:40 PM   #137
ebphoto
Originally Posted by jserman View Post
Love the look EB...
thanks
Originally Posted by JordanWho View Post
Want to see MOAR!
i have a build thread with a few more pictures in it.
Old 12-13-2012, 05:59 PM   #138
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Photoshoot time. Let me know the time and place.
Old 12-14-2012, 10:09 AM   #139
ebphoto
not this week but next?
Old 12-14-2012, 04:03 PM   #140
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Sounds good to me.
Wheel Directory: Advan TC III 18x9.5 +40 PRORICAN Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 03-20-2020 12:03 PM
Work Wheels: CR-Kiwami / XD-9 / Meister S1R / Meister S1 3pc Touge Factory Wheels and Tires 141 06-09-2015 07:35 PM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 03:15 AM
FS/TW : Work Meister S1R -aggressive - 18x9.5 +25 w/225/40 ebphoto Wheels and Tires 40 08-09-2013 01:58 PM
Wheel Directory: Work Meister M1R 18x8.5 +?? / 18x9.5 +?? DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-03-2012 02:45 AM
