Old 12-08-2012, 08:54 AM   #43
gmookher
Originally Posted by Gen View Post
Several of us noticed the same sound after installing the Crawford AOS.
does uninstalling it get rid of sound???
Old 01-07-2013, 06:45 PM   #44
Zach
Drives: 13 FR-S Black MT
just a bump, I have had this since new and at about 13k miles now.
Anyone get anywhere with it?
Zach is offline   Reply With Quote
Old 01-07-2013, 06:51 PM   #45
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
the paranoia has multiplies exponentially in my absence of this thread...
driftartist is offline   Reply With Quote
Old 01-07-2013, 07:04 PM   #46
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
sounds like induction noise, but does have a nice slap to it.
Jesse is offline   Reply With Quote
Old 01-07-2013, 07:25 PM   #47
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I keep watching it and I'm not too sure..is the noise you describe that "slap" you each only once per pedal press (and NOT in between throttle)? A tune would change the way the throttle valve operates and remove any sorts of stock open/close tapering, which is what happens to improve throttle response. That being said, if that's the noise you are worrying about it sounds like the valve closing shut real quick each time you release the throttle, very mechanical sound indeed. Having an intake will only accentuate that noise, and normaly with a stock box, it muffles it pretty good.
EDIT: Some car will let you play with the throttle even when the engine isn't running, I don't know about the FR-S I would go check out but it's pretty cold outside :P. Put the key on the on position with the engine not running and give the throttle some good taps, if I'm right..well you know it's just the throttle butterfly.
Rayme is offline   Reply With Quote
Old 01-07-2013, 09:53 PM   #48
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yomny sold his car, so now we will never know...
Clutch Delay Valve? ashtray Engine, Exhaust, Transmission 72 11-18-2015 01:10 PM
Apexi SMART Accel Controller 808Raven Engine, Exhaust, Transmission 2 10-11-2012 08:54 PM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 10:10 PM
ecu face slap ToxicSneakers Scion FR-S / Toyota 86 GT86 General Forum 15 09-16-2012 04:59 AM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 07:17 PM
