Old 12-06-2012, 07:24 PM   #29
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by jshadeck View Post
If u can make that the same size as a toyota/scion/subaru logo ill buy two
Not really looking to get into business, but if you tell me the dimensions you want I'll do a test print to see how it comes out.
Old 12-06-2012, 07:42 PM   #30
jshadeck
jshadeck's Avatar
"I de-baged mine already. And was at the office and wanted to buy Toyota badges....
I am home now and just measured the old scion badges.
Front: 4 and 3/8 inches x 3 inches
Rear: 4 and 1/8 inches x 2 and 6/8 inches
Used a ruler - not 100% accurate, but 99% accurate."
jshadeck is offline   Reply With Quote
Old 12-06-2012, 07:44 PM   #31
jshadeck
jshadeck's Avatar
But the 86 being a circle, id say just make them to match the smaller dimensions while retaining the circle shape so.. Just two at 2 and 6/8 should work just fine
Old 12-06-2012, 07:48 PM   #32
ggpaul
socalsouthbay_86
ggpaul's Avatar
Drives: Scion FR-S 2013
Shit if I had a 3d printer I'll just make myself a Lamborghini lol.
ggpaul is offline   Reply With Quote
Old 12-07-2012, 01:51 PM   #33
neutron256
neutron256's Avatar
86 Badge
Okay played around with my design to make it work better as a badge. Changed the taper, and crowned the top.
Here it is printed at 0.1mm layer resolution. I've cleaned it by giving the top a quick sanding to remove ridges left from the build process.
This is a 3" diameter. Next to my BRZ badge for a sense of scale
The Following User Says Thank You to neutron256 For This Useful Post:
SkAsphalt (12-09-2012)
Old 12-07-2012, 01:55 PM   #34
jshadeck
jshadeck's Avatar
Hmm. I really like that, but the circle peg in an oval hole might not look right. How much for 2?
Old 12-07-2012, 02:22 PM   #35
neutron256
neutron256's Avatar
I agree a circle in an oval spot probably is not going to look great. It might work on an FR-S bumper if it was just the right size since it's badge indent is more open ended. It certainly doesn't work on the BRZ bumper.
Honestly I'm just playing around with this, not looking to get into business. I would probably have to charge more then people are willing to pay to make it worth while.
Just out of curiosity though how much do people think they would be worth for a set? Keeping in mind that they require some finish sanding, and probably some sort of painting (PlastiDip?) which I'm really not getting into.
Old 12-07-2012, 03:12 PM   #36
jshadeck
jshadeck's Avatar
Id be willing to pay 50$ for the set as circles, if you were able to do a perfect matching oval w the round 86 inside of, possible more.
Old 12-07-2012, 03:21 PM   #37
Xenocide117
Xenocide117's Avatar
Drives: 2008 Honda Fit Vivid Blue Pearl
Eh? Eh?
Xenocide117 is offline   Reply With Quote
The Following 2 Users Say Thank You to Xenocide117 For This Useful Post:
Freeman (12-13-2012), soros151 (12-08-2012)
Old 12-07-2012, 03:45 PM   #38
neutron256
neutron256's Avatar
Originally Posted by Xenocide117 View Post
Eh? Eh?
Aww come on you need to work he scion logo in there too.
Old 12-08-2012, 01:29 AM   #39
Xenocide117
How much more busy does it really need to be?
Old 12-09-2012, 11:00 AM   #40
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
Turn the busy up to 11. That would be 1 more busy! How durable are these parts? I'f I wanted to use this build custom a-arms, skid plates and other RC related parts, would they hold up or is the material too brittle for that?
Jedi1 is offline   Reply With Quote
Old 12-09-2012, 11:11 AM   #41
neutron256
neutron256's Avatar
That depends on many factors.
-They type of plastic used (PLA or ABS)
-They accuracy of the 3D printer used
-The the software used and its ability to control the build process (wall thickness, fill %)
They won't be as strong as injection molded parts but can still be very strong especially if you take certain factors into account in your part design. There are some major advantages when it somes to lightweight parts because you can create hollow structures that are impossible to achieve any other way.
Old 12-28-2012, 04:55 PM   #42
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I got my Asphalt yesterday, so today I was working on the piston rendering. Well I found out that the arc of the piston area is the same as the arc of the outer 86 ring (the ring that is connected to the pistons).
Toyobaru Vs. Volkswagen GTi? Eureka FR-S / BRZ vs.... 115 08-11-2015 06:05 PM
New 3D laser scanner and printer what to make? SpeedR Scion FR-S / Toyota 86 GT86 General Forum 69 06-11-2013 08:14 AM
Toyobaru own the Speedhunters Poll mattles Scion FR-S / Toyota 86 GT86 General Forum 9 05-12-2012 02:18 PM
GT 86 VS BRZ: WHO 'OWNS' THE TOYOBARU? tripjammer Scion FR-S / Toyota 86 GT86 General Forum 8 03-29-2012 11:49 PM
What would you name the toyobaru? PuGZoR Scion FR-S / Toyota 86 GT86 General Forum 561 07-16-2011 12:41 PM
