Old 12-06-2012, 02:32 PM   #449
Hanakuso
Anyone using or thinking of installing titanium shims? Just been looking around and it seems to help but not really required. If there is no negatives and only positive effects, I see why not right? Hardbrakes.com makes them specifically in the shape for the CP8350 caliper.
http://hardbrakes.com/index.php?main...roducts_id=122
Sample pic
Hanakuso is offline   Reply With Quote
Old 12-06-2012, 02:44 PM   #450
OrbitalEllipses
Drives: Attitude
Originally Posted by Hanakuso View Post
Got mine installed. Thank you Jeff for helping me out with the issue I had! Btw, I noticed a clicking sound (Sounds like putting a card in the spoke of a bicycle) and I narrowed it down to the contact between the pad and rotors. Is this normal? I'm thinking its coming from the J-hooks. I did notice Hawk HPS pads have 1-2mm more depth then the C300 so it's constantly making contact to the rotors. Maybe that's why it's clicking but I'm not 100%
Edit: Btw I checked the clearance with the OEM spare tire and it fits with a 20mm spacer. I'll double check later to make sure clearance is good enough.
In the case of a front tire blowout/flat, put the spare on the rear and move the functional rear wheel to the front so you don't need a spacer; common thing done on WRX's with Brembo swaps that didn't buy an STI spare tire.
From what I understand about these calipers the pad should always be contacting the rotor due to the anti-knockback springs (IIRC this system does use the springs).
Old 12-06-2012, 02:47 PM   #451
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm not a fan of mismatched tires on an LSD axle...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-06-2012, 02:50 PM   #452
Hanakuso
Like what Dave said, I would never want different sized tire/wheel on the rear. The only other solution if you don't have wheel spacers would be to carry 2 spare tires so that if the fronts needed replacing then at least the rears would have even skinny spares. My plan was using the OEM wheel with spacer but if the spare tire works then it's more trunk space.
About the noise, it's probably normal and another member mentioned he has the same clicking. It's been getting a tad quieter in the 50-100 miles i've driven since it's been installed.
Old 12-06-2012, 03:06 PM   #453
OrbitalEllipses
Drives: Attitude
All the tire calcs I know only go to 145 tread width and I believe our spares are T135/80/D16. The spare tire diameter should be close to the stock tire diameter...and as long as you're within 2/32" diameter, there shouldn't be a problem with blowing up the diff? I don't see a way to get this done without spacers unless you have a full size spare or change the temporary spare to something that matches your current tire diameter.
Old 12-06-2012, 03:35 PM   #454
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Most of us are probably not running OEM diameter tires either so depending on size that could be quite a bit off
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-06-2012, 03:41 PM   #455
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Attention all Competition Kit owners...just wanted to let you know that you are in good/serious company! One of our other customers stopped by our booth at IMIS today to talk brakes.
I'll give you a hint...he drives this:
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 12-06-2012, 04:32 PM   #456
OrbitalEllipses
Drives: Attitude
And most people should be using tires that are within 3% diameter of stock (24.6x IIRC) in order to retain proper speedo readout.
Old 12-06-2012, 04:48 PM   #457
CSG Mike
CSG Mike's Avatar
That's not good for the LSD...
Old 12-06-2012, 05:37 PM   #458
robispec
Drives: Black frs project
Torsten/quaife type is completely unaffected buy this diameter difference...one of the pluses of the design.
robispec is offline   Reply With Quote
Old 12-06-2012, 05:47 PM   #459
OrbitalEllipses
Drives: Attitude
3 people don't need to say it. See my reasoning several posts up, please.
Old 12-06-2012, 06:08 PM   #460
CSG Mike
CSG Mike's Avatar
I know of a few cars with factory Torsens that recommend against it to avoid damage to the LSD... although in all reality, it should be the same.
Old 12-07-2012, 12:25 PM   #461
Hanakuso
Well I ended up emailing the guys at hardbrakes about the titanium shims for the Essex kit and they can do a GB discount. If we have enough interest I could always create a new thread to make it more organized. This is what they had to say,
We'd be happy to set up a group buy. For 5+ buyers we can do a 10% discount, for 10+ buyers we can do a 20% discount. In order to make this work with our ordering system, we'd need to put a fixed time window on the sign up process (no more than 30 days). Let me know if there is interest and we can set up details.
If someone else can chime in and mention there opinions on these shims that would be great. It seems the only real negative effect would be the small weight added and money spent, but everything else seems great about them
Old 12-07-2012, 01:52 PM   #462
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Ask him his thoughts on turn 1 at Road Atlanta with regards to brakes.
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
