Old 12-05-2012, 01:57 AM   #225
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Hahhaha oh man. That sounds DAMN GOOD! I've sent them a query.
stevo_12v is offline   Reply With Quote
Old 12-05-2012, 05:24 AM   #226
stevo_12v
Japan Parts order placed :D
Well.. it is done. Greddy x Rocket Bunny Tra Kyoto Diffuser... here I come!
Oh yeah.. I ordered the TRD umbrella too
And get a FREE teddy bear.. and a FREE 86 Catalog
Here is a 'walk around video' of the car. Check...
[ame="http://www.youtube.com/watch?v=XC2z4Hvy4yU"]超~カッコイイ86発見! #lovecars #videotopics #GT86 #fr-s - YouTube[/ame]
Old 12-05-2012, 05:58 AM   #227
KAOS86
Drives: Magna V6
Cool
Good job man glad I could help your awesome thread/build, also dam now I want one of those STI bears .
Diffuser & Under Panels get will I. (Fighting the urge to stop buying every bargain I see... )
P.S. Injen air intakes are cheap at the moment $250-267 if you where thinking about a dif intake.
KAOS86 is offline   Reply With Quote
The Following User Says Thank You to KAOS86 For This Useful Post:
stevo_12v (01-13-2013)
Old 12-05-2012, 11:31 AM   #228
stevo_12v
The Godfather
The Godfather just added me to his friends list on facebook. My 86 journey is *almost* complete. I say ALMOST because I haven't got my AVO turbo yet
The Following User Says Thank You to stevo_12v For This Useful Post:
trinitron (12-06-2012)
Old 12-05-2012, 01:35 PM   #229
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Congratulations, that is truly an honour and a priviledge bestowed by the Master of all things 86.
Demandred7 is offline   Reply With Quote
The Following User Says Thank You to Demandred7 For This Useful Post:
stevo_12v (12-06-2012)
Old 12-06-2012, 12:33 AM   #230
stevo_12v
I also got 7-Tuned...
Hahahaha I've been 7-tuned!! Well, the lil' ol' 86 has.
Obviously.. there is always that one hater comment.
At least I must be doing something right!
[ame=http://www.youtube.com/watch?v=e7z_ztMxBgk]Katt Williams Pimp Chronicles Pt. 1: Haters - YouTube[/ame]
I wonder what's next? Maybe Francine Dee or Amy Fay might want a FB friend request
Old 12-06-2012, 12:48 AM   #231
Mr Franky
Drives: Vehicle
There will always be haters (or people with opinions). I personally would not change a thing. Every single mod you have done, would be duplicated by me if I had the money.
Mr Franky is offline   Reply With Quote
The Following User Says Thank You to Mr Franky For This Useful Post:
Old 12-06-2012, 04:05 AM   #232
stevo_12v
Shoulda got a lowered racking jack from the start..
Got a call from City Subaru.. Rhys there told me my nuts had come in.
Lesson well learnt here, double check and then triple check to make sure everything is tightened down/torqued to spec.
While I was out, I decided.. fuck it.. I'm going to buy that $660 Aluminium racing jack from MALZ. The car has been up and down on jack stands so many times. Went there and asked if I was able to check if it would fit under the front of my car. Turns out one of the managers there has bought an 86 too Guy was asking me all about it.
Bad news is that the $660 jack doesn't fit under the front of the car.
Good news is that they have a better model and CHEAPER than that one(although not aluminium) but it also only takes 2-3 full pumps to go full height, and it has a longer nose.
Lowered Height: 63mm
Max Height: 500mm
Much better stats than the $660 one(95mm-470mm)
They are out of stock, but the guy there said it should be in tomorrow, so tomorrow I will yet again raise the car and take off that midpipe.
Old 12-06-2012, 04:38 AM   #233
stevo_12v
Forgot to upload these
There were taken a couple of days ago. They are the new fogs I received from @KI_ZN6. Very happy with them. They are slightly less 'blue' to the light too.
It looks blue from afar, but when you bring your hand or a piece of white paper up to the fog light, its pure white.
Old 12-06-2012, 09:03 AM   #234
Nikkojoe
Nikkojoe's Avatar
Drives: IS200/AE86 2dr/White 86 GTS 6MT
Max Height: 500mm
You probably have mentioned it, but which Malz do you go to? If it's Balcatta then I find it amazing we haven't run into each other yet :P
As for the jack I found it only really matters (most of the time) if the tallest part of the body of the jack will clear the car and that how the pump arm/lever is pivoting. However I need a light jack now as the one I got (similar specs to yours, well not as low) is too god dam heavy
Something like this probs would be best:
http://unitedtools.com.au/products2....=877&catID=162
Nikkojoe is offline   Reply With Quote
Old 12-06-2012, 09:53 AM   #235
stevo_12v
I went to the Cannington one. Do you work at MALZ? The guys at the Cannington store said that Balcatta had some of those jacks and that they'd be getting them from there tomorrow for me. And the guy who served me(Carl) said one of the manager has an 86? That could be you?
Old 12-06-2012, 10:33 AM   #236
Nikkojoe
Nikkojoe's Avatar
Nope! I don't work at Malz, but I go there enough to be questioned
I'll have mine in 3 weeks though so I might look at getting another jack
Old 12-06-2012, 02:56 PM   #237
stevo_12v
Niiiice ok. Hahaha another SWP GTS!! YEAH!!
Are you on the FB group??
https://www.facebook.com/groups/WA86BRZCLUB
Join up if you haven't already
Old 12-07-2012, 07:59 AM   #238
stevo_12v
Forgot to reply
Originally Posted by Hawk77FT View Post
Oh ok, I want to do a hybrid between the KDT926 and the Perrin 'stiffy' so I hope it all goes well. Someone said that it might not fit properly as in I will have to make the KDT926 hole slightly bigger to accomodate the Perrin shaft. I will check tonight. If that is the case, than I will have to find the best possible way to make the hole larger. Any suggestions? I was thinking a very fine knife or hot hole puncher or something.
You won't have to cut the KDT926 bushing, the hole in that is massive.
I'd like to see pics of the cradle brace though once setup. Because the flat part of the WL bushing looks about 2mm thicker than it should be(imho).
36yroldvirginscar, keyboardwarrior, trd
Dumb idea to get auto tranny? tinnyms3 BRZ First-Gen (2012+) General Topics 85 06-22-2012 06:22 PM
After this last winter is RWD such a bad idea Nate219BRZ Great Lakes 3 03-14-2012 06:03 PM
Any Idea of U.S. Pre-Order Numbers? markemark24 Scion FR-S / Toyota 86 GT86 General Forum 1 02-21-2012 01:29 PM
I have a great idea! ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 56 07-24-2011 12:14 PM
Marketing Idea for the FT-86 JDMluv Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2011 06:29 AM
