Kouki-Monster
If a guy was to swap a KAAZ/Cusco etc 2-way locker in .. would there be any issue with the VSC/TC? Would you have to just leave both disabled?
The torsen is not too bad, but it just doesn't sen the tor the way I'd like it to.
Rich Anderson
EMPOWER AUTO |
#2 |
If you're going to replace the stock diff, I'd suggest a 1.5 way unless you're mostly interested in drifting.
I can't see how it would mess with the electronics, the stock diff is 100% mechanical so you shouldn't have any issues.
#3 |
Kouki-Monster
Daily driving a 2-way is no biggie... and the reason would be for drifting.
Rich Anderson
EMPOWER AUTO |
#4 |
Drives: car
I think where you are most likely to run into some issues is driving on split-Mu surfaces. I'm talking about when one side of the vehicle is on a slippery surface and one side has significantly more traction.
The stability control system was calibrated with the bias ratio of the stock differential--its torque transfer characteristics. If you change that by switching to say a clutch-type, you could have instability in some situations if the calculations have been thrown off. |
#5 | |
Kouki-Monster
If I lose the tires .. I lose the tires at a point where the correction from TC/VSC is going to just make the other end of the car hit the wall. I've gotten more comfortable correcting the car with all driving aids off. You lift, you die.
Rich Anderson
EMPOWER AUTO |
| The Following User Says Thank You to empower-auto For This Useful Post: | Matt Andrews (12-06-2012) |
#6 | ||
| Aftermarket Cams | usptwins | Engine, Exhaust, Transmission | 20 | 08-03-2013 07:54 PM |
| Aftermarket Amp Kit for FRS | kombatlion | Electronics | Audio | NAV | Infotainment | 7 | 11-06-2012 02:03 PM |
| OEM mic w/ aftermarket headunit | Powered By Jay | Electronics | Audio | NAV | Infotainment | 0 | 07-21-2012 07:59 PM |
| Aftermarket HU and XM | beefalo | Electronics | Audio | NAV | Infotainment | 0 | 06-30-2012 01:31 AM |
| Aftermarket products | davey90 | AUSTRALIA | 18 | 05-22-2012 06:10 PM |
